Electromagnetic Repulsion Motor
  • Electromagnetic Repulsion Motor
    to the Electromagnetic Repulsion Motor thread.
    Please share your designs.
    VIDBID
    Hi
    I just repeat this:
    Originally posted by seaad View Post
    . . I advise you to use BOTH sides of the ((magnets AND )) the coils simultaneously. .
    Pls see this: https://www.youtube.com/watch?v=wAYsAN5QPnA
    Attraction seems to be better?? I have seen someones answer to that in some thread. I think the youtube film was there too.
    Best regards
    Arne
      Hi
      I just repeat this:
      Best regards
      Arne
      Repulsion works great, too.
      VIDBID
        This should be an great thread.
        One of the earliest electromagnetic machines by Joseph Henry 1831.
        It has been described as a rocking motion. A logical modification
        to repulsive mode might use more electric magnets.
        To get angular momentum shown vidbid repulsion by re-arranging the solenoids
        into a different configuration. With a slow pulse like every two seconds it could be found with
        intuitive feel. The reason for backing up is there is another angular momentum design.
        It might share some properties. It looks like stacked saturn rings. possibly the ratio of
        12 negative electrons to 1 positron forma a structure where they spin faster with
        a small amount of repulsion and when they (are kicked) they detach forming current.
        the force arrows
          Both repulsion and attraction give good results but if you use attraction, provided you create a return path, it keeps the flux within the core of the coil and can be more efficient. I have used the attraction method in the past.
            However, in terms of repulsion, I think repulsion works best.
            VIDBID
