The Learning Curve...til it gets "straight"...
Hello to All,
I have been conducting several testings...and I mean several, as they involve all kind of different cores and coils sizes and gauges...different winding methods, etc,etc.
All along this development I have faced downward curves (disappointments) as going up curves which give me some hope...until I start riding a straight line going up and up...that is where I am now.
Like I mentioned on my latest video...Exciter Coils are wound in a very different way...than conventional means, all leading to improvement, where we use the MINIMAL ENERGY to excite STRONG CHANGING FIELDS.
And so, I finally refined the way the "Collecting Coils" or "Secondaries", or "Induced Coils" are wound AND CONNECTED.
Secondaries are wound also different than conventional, in order not to have amps losses (Decay) to gain higher voltages as pulsations increase (which translate to "FIELD CHANGES RATIO")
I built two secondaries with same number of turns, same gauge...same resistance, but one being "conventional" and the other one "improved"...In order to compare results, and the difference is outrageous.
When I write conventional related to Secondaries, I meant layers back and forth along core length, following same direction of winding...this conventional method tends to decrease amps as I split wires to read out at different layers. EVEN if all turns are wound same direction, the currents directions fluctuate from one extreme of core to the other in every layer, if we look at "translation along core axis vectors", which renders a constant opposition of vectors from identical spinning of currents flow directions.
Therefore, I made it in order that just one directional flow is wound through different layers acquiring induction...then all "return" conductors between layers, travel in a fashion which do not get induced by field changes since they are not "turned" around core, but straight.
I also refined the whole device as to make it as compact as possible...and of light weight as possible.
You will see the whole thing soon...
Hello to All,
