Originally posted by Gambeir
PS: Sorry I'm a little tired. I could probably restate this more simply given a little more time and thought as well as explain the other evident anomalous demonstrations shown in the video, which btw is excellent. So bottom line is that I think it validates the existence of the Aether and does not invalidate the idea that centripetal force exists. Again, the timing here is spot on because what's missing from the Authors understanding is that there is a field of energy acting on the gyroscope which is officially denied energy. Once you add that in then the seeming manifestations of an un-explained phenomena are made whole and understandable. Hopefully this garbled gibberish will enable something like that. Right now I have to take a nap. Old dude ya know. We sleep a lot.
Centripetal force is important since it relates back to Einsteinian Physics as the reason for gravity. This is some very tricky and slippery stuff but I'll give it a whirl. Now the author of the video's seems to be asking if centripetal force exists because of the behavior of the gyro.
Now, either centripetal force exists as we understand it or it does not, and if not then we have problems, but it's also a problem if they admit it does exist and have to then explain how when these video's seem to strongly suggest it does not exist and the reason has to do with the idea that the Aether is real and all encompassing.
Gravitational descriptions neglect to mention a number of complexities when it comes to the crux of the matter which involve centripetal force. For example, first off the so-called centripetal force has to be brought about by an acceleration force exerting a pressure force on a specific point on the face of a curved object. Remember here that a gyro at rest isn't the same as gyro spinning. This means that a fluid like substance must be acting on the face of the gyro in order for a centripetal force to manifest, and the reason is that a fluid will climb a hill, and or a rotating object can draw fluid up a hill. For the force to exist there must a similar ability otherwise we would have a centripetal force upon all tangent points on the face of the gyro, and so the question is; do we have an infinite number of tangential points whereby a centripetal force is exerted upon the center of the gyro?
Now a centripetal force is a supposedly an inwards force formed on the point of center on a curved object. Read that carefully once more "on the point of center on a curved object." Now one might reasonably presume this means there are infinite tangential points all around a rotating spherical object and whereby this so-called centripetal force projects inwards, but that is not the case when we add a fluid to the reaction, and there we get a specific point of center which correlates back to the fluids direction, speed, and so on.
OK, so now saying that centripetal force is exerted at the point where center lies on a curved object isn't quite the same thing as saying an infinite number of tangential points because the gyro is round unless, of course, there actually is a sort of fluid striking the face of the gyro from all angles, and that would tend to validate the idea that the Aether is a fluid like substance surrounding and acting on all bodies from all angles. So now this understanding would imply that an exterior field acts upon the face of the curvature of a gyro, and the behavior of the gyro might then be caused by self-cancelling counter centripetal forces coming in from all angles; so now you have a problem with how to explain the behavior of the gyro without admitting that there is an Aether.
This is what the author of the video's seems to calling in to question and asking; does centripetal force exist? For a point on a curved face to become the point where a centripetal force is exerted requires movement on the part of either the object, or a substance such as a fluid, or both. If no evident centripetal force exists then one might tend to think this is because the gyro is actually spinning in an all encompassing fluid like substance and so no specific point exists where any measurable centripetal force can be observed. In my opinion his video's seem to validate the idea that the Aether is an all encompassing substance acting on the body of the spinning mass from all angles at all time.
So I don't think that it invalidates the idea of centripetal force but it does seem to present a problem about denying there is an unseen exterior field which is acting on the gyro.
I found this link as well
View this post on Hive: 🔬#MESExperiments 5: Gyroscopes Precess UPWARDS on Ice with ZERO Centripetal Force! #RealPhysics by mes
the Centripetal force would also link back to what wilbert smith called a tempic field. and what steve quayl calls a torsion field
