Lunar Wheels.
  • #16
    NY Pizzagate fridge
    Originally posted by Allen Burgess View Post
    Tycho crater:
    It's a fridge.
    In fact, the exact same fridge as in the basement of the NY Pizzagate place. Somehow it is all connected. Maybe a wormhole of some kind they keep hiding from us in order for the MIB to exploit the moon.
    Good find. Keep them coming!
    All the best,
    Slick
    • #17
      City on Mars.
      Incredible capture inside a Martian crater:
      The second picture on the right is a cluster of Lunar builldings.
      • #18
        Clementine
        Look at how "Technothanks" de-smudged this enormous building from a Clementine photo: You can see it's an Oz surrounded by a huge city of square buildings and partially smudged over skyscrapers in the foreground:
        This photo is one of 9 released by NASA out of the 1.8 million taken by the Clementine satellite.
        This city is on the far side of the Moon just behind the South Pole adjacent to the Zeeman crater, not visible from Earth like the lights of Aristarchus. This huge building is the size of Manhattan Island!
        • #19
          Hale Crater.
          Here's an ESA satellite photo of Hale Crater Mars, downloaded directly from their web site ESA by me on the right, and a magnification contrast adjusted version from my "Photo Program" on the left: The "Tower" is visible in the lower center portion of the wide angle photo. Zoom in on the right photo!
          • #20
            Martian size
            Mars is 2.66 Earth's gravity; This explains why Martians are not as tall:
            • #21
              enlargements.
              Look at these enhancements:
              • #22
                Martian hieroglyph
                Here's a better screenshot of the "Martian" and "Flying Saucer" hieroglyph. Take special notice of the "Fourth Planet" pictograph recorded in "Arabic Numerals" beneath the figure on the left; (The number "2's" written the nearly same way as present) (The "4" is inverted and on it's side under the circle) and perhaps a leftover piece of mining equipment from some ancient era of Mar's distant mining past on the right:
                • #23
                  "4th" Planet
                  Look how the number "4" appears in black when the symbol from under the planet is reversed and straightened up, drawn under the Alien's left foot below:
                  • #24
                    Photo from Falcon 9
                    Here's a recent unedited photo of a UFO from Falcon 9: Maybe someone has us under very close observation?
                    • #25
                      Martian.
                      This photo resembles the guy in the Egyptian Hieroglyph. What are the chances the photo is real? Look at that the similarities between the eye, the brow ridge above the eye and the pointy chin! We could be vastly outnumbered by this alien race, as if surrounded by a field of barnacles on a group of shore line rocks.
                      • #26
                        Third physiognomy.
                        What kind of coincidence is this? Compare the likeness to the two photos above: Is this crop circle face some kind of psychic archetype, or could there be some other truth?
                        • #27
                          200 million years?
                          This "sub-surface" Martian civil engineering pattern is partially covered by a 200 million year old lava flow. The ancestor of Homo sapiens was a ground burrowing shrew that far back in time!
                          • #28
                            Where did this craft originate from? Photographed over Orlando Florida last week by multiple cameras, and published on youtube by "Thirdphaseofmoon".
                            https://www.youtube.com/watch?v=uCy9cwCTw1U&t=153s
                            I've been so self absorbed that I've not had time to look through the forum, but I had not seen these images before.
                            First off, it's likely this same type of vehicle has been spotted and even filmed. Once over Mt Baldly in CA. However the poster removed the video. When questioned if he had been visited by govcorp officials he only said to forget it, that it must have been swap gas or a weather balloon.
                            Around mid July I was outside and happened to look up and see a black triangular ship hovering nearly overhead. I got a clear view for about 2 to 3 seconds, at which time the vehicle took off at such a high rate of speed as to essentially vanish. However it hadn't vanished but had moved out at an unbelievable speed. I'm guessing easily in excess of mach 6. So fast that your eyes only registered a partial frame every second.
                            Now of course I'm surrounded by military contractors and the military itself. The vehicle I saw moved directly towards McCord AFB, about 15 miles by the crow, which it gained in less than 2 seconds I'm quite sure.
                            A Man In Auburn, Washington Spots A UFO With Fins | Latest UFO sightings
                            2 See Erratic Flying Black Triangle. -
                            Triangle-Shape (early reports):
                            1960 September 8 Tyneside, Britain
                            British researcher Victor Kean, who started Project Triangle on the world wide web tracked many triangle reports in Britain that took place in the 1990s, but pointed out that his first reliable triangle report dates from September 8, 1960. This was a "triangular-shaped craft with three white apex lights and a red light underneath," seen in Tyneside, Britain and two other locations that evening, all within a 10 mile radius and within 75 minutes of each other. Did someone invent flying triangles in the 1950s?
                            1965 September 3 Damon Texas
                            One triangular object 150-200 long, 40-50' thick at middle and dark grey, with a long bright, pulsing, purple light on the right side and a long blue light on the left side. Came from a distance to 150' off highway. Purple lighting illuminated ground beneath object and interior of police car. Driver felt heat on his left arm.
                            1975 07.25.Camino Island, WA
                            Triangle craft appears to crash. Multiple witnesses. As the witnesses relate their encounter, they remark that the object they observed, was like the one observed in North Carolina at about the same time.
                            1975 09.08.
                            This recording is significant because it is a very early flying triangle report.
                            1975 09.09.Seattle, WA
                            Triangular shaped craft appears to crash.
                            1975 09.27.Seattle, WA
                            Triangle UFO observed. This was the third report in the area of these new shaped UFOs being sighted and causing a new chapter on ufological research that continues to the present.
                            1976 01.04.Fort Ord, CA
                            Flying Triangle observed for 30 minutes.
                            1976 10.20.Snyder, NB
                            Police Officer and Sheriff's Deputy observe a triangular-shaped object at low altitude, move West to East and then hover. Object remained stationary for awhile and then proceeded E to W.
                            1976 11.28.Tyler Texas
                            Triangular object hovers over car.
                            1977 03.13 Pleasanton, CA
                            Weatherman his wife and son, observe a huge triangular object. Object emits bluish-green and red lights flashing along its leading edge.
                            1977 04.24 Golden Grove, CA
                            Armada of 12 triangular objects pass near a drive-in theater. Two witnessses observe slowly move away, while one maintains a hover over nearby trees. Objects had four lights. Four lights on each object.
                            1977 05.19 Newman, CA
                            Two police officers report a triangular object with red and blue lights hovering next to the PGE power generating plant. Officers withi 60' of objectbefore it took off at a hig rate of speed.
                            1980 Hagen, Germany
                            Hagen, Germany 1980 triangular craft filmed by Mr Marrs Dommin.
                            • #29
                              Telescope shot of Herschel Crater
                              Here are two contrasting shots of Herschel Crater; One taken by a store bought 8" reflector telescope pictured below on the right. In the center, we see the photograph taken through the telescope; A NASA shot of the same crater appears on the left:
                              • #30
                                Lunar City.
                                Look at this color adjusted photo of a city in a crater crevasse in "Montes Apenninus": This photograph was taken through a backyard telescope by Bruce Swartz.
