New concept searle effect
Last edited by antigraviticsystems1; 04-04-2017, 10:07 AM.must first understand the nature .... and then imitate -
Brilliant! Only one question - instead of the comb, why not put a metal ring on the outside, and draw charge from that instead?
En vez del peine, por que no utilizar otro anillo - metalico - por el perimetro, o sea afuera de los imanes, y colleccionar la carica de voltage desde alli' mientras giran los imanes?
Bob
Last edited by antigraviticsystems1; 02-15-2017, 06:07 PM.must first understand the nature .... and then imitate
Last edited by antigraviticsystems1; 04-04-2017, 11:54 AM.must first understand the nature .... and then imitate
I am convinced that the configuration is wrong, the truth has been misrepresented so that it is impossible to materialize positive results.
If you experience this idea mine already has in your favor:
* Generation of hundreds of thousands of volts.
* Extreme ionization.
* Plasma creation.
* Concentric capacitor charged only with rotation.
(TTBrown)
* Surface polarization of Teflon and Nylon.
* Creation of forces of lorentz which push the charged particles in the direction of rotation.
* No need for external high voltage power supply.Last edited by antigraviticsystems1; 02-16-2017, 10:10 PM.must first understand the nature .... and then imitate
"... Spontaneous acceleration
The spontaneous accelerating rotation above critical frequency can
be understood as being to a Lorentz torque acting on the radial Ohmic
em and
Z
0
currents in rollers and roller ring. Above the critical fre-
quency the Lorentz torque, which is proportional to rotation frequency,
becomes larger than frictional torque, and spontaneous accelerating..."must first understand the nature .... and then imitate
