This video shows the turn throw down to maybe 1/4". This is in the "Adam's resonance" range: the limit switch can glue to the floor of the glass case and a small hole can be drilled through it for a tiny rod to the ferrite piston.
Mechanical Magnetic Torque Amplifier
Pi/po
When the limit switch is released and the current is interrupted to the coil, the power coil generates 8 volts and the rotor spins 180 degrees.
The second 180 degree turn of the rotor is provided by a D.C. pulse at 12 volts.
What's the co-efficient of these two factors? Amperage is the ratio variable.
Efficiency may result in a factor very close to unity as my test results show on earlier builds.
This is the simplest electric motor (Moving Magnet Voice Coil) and gearless rotor combination with the unrecorded "World's Record" highest efficiency rate of any electric motor rotor in existence.
Combined output from the alternator may deliver an overall COP of 2.
20 hertz
I got the oscillator to start up and run with the micro wave limit switch over the piston. It's running fast and strong at around 20 Hertz. That should spin the tub style alternator at 1200 rpm and generate 40 volts.Last edited by Allen Burgess; 06-26-2019, 04:21 PM.
running oscillator
oscillator running in Adam's resonance; magnetic gate spring solenoid;
Neo sphere
The rotor needs a start up spin to sync with the oscillation frequency. The wash tub rotor is impossible for me to start from a dead stop with the oscillation alone.
I am modifying it to spin a Neo Sphere The frequency of the oscillation is high because the magnet spring is strong. It is no problem to spin a Neo sphere up to sync speed with a flick of the wrist. The tub motor would need an auxiliary motor to start it.
I'm certain I can spin the sphere in Adam's resonance which I estimate at around 1200 RPM.Last edited by Allen Burgess; 06-28-2019, 01:17 PM.
Microwave door limit switch secure and service doored:
the Neo sphere can spin inside the plastic box;Last edited by Allen Burgess; 06-29-2019, 01:49 PM.
Edgarinventer generates twice the force in his magnet array when he turns the block faces from side to side: 2 x's force on each side: It looks like he's getting twice the kick!
The SPDT switch turned out not to work well. A mosfet with a hair wire contact like the one in the video works much bettor. The inventor looks as though he has a trigger coil at work too:
Mosfet
n's facing out and down, field opposite north facing side.
The placing of the stationary cubes. Imagine 5 cubes and one diametric ring; Turning the center ring in one set of 3 would reverse the combined field strengths.Last edited by Allen Burgess; 07-04-2019, 11:21 PM.
Hallbach field
n's facing in and up, the field is on the n facing side only opposite polarity;
Halbach array
New "Warp Factor Quantum Leap"!
What we see at 1:38 in this video is an evidence of Overunity!
Quick and dirty Halbach magnet switch; A wash tub drain motor stator, 4 ceramic blocks, N facing out and the diametric cylinder in the middle; Works fantastic.
5 magnet twin
This would produce a N,S field together on one side with the curl between the opposite facing diametric cylinders. A second array facing the first with a double strength reverse "Horseshoe Curl" would exert a powerful attraction when the other's magnets were switched on.
Here's the question: Would the attraction strength between these arrays, load a spring with sufficient force to throw the lever on the turn magnets?
