Originally posted by Pot head
Mechanical Magnetic Torque Amplifier
I currently have 153 vidoes of builds posted on my youtube channel; The functioning "H" bridge oscillator is the latest:Originally posted by Pot head View PostShow your build!!! Prove it!!!
Im calling you out!!!
Adams kickback
Look at the spacing of these two Adam's rotor N facing magnets. They're attracted to the steel core of the relay coil, the reed switch masks the attraction with a coil pulse, then the Lenz reverse kicks the second magnet with a repulsive force:
The coil inductance would determine the distance between these two magnets. The same ratio applies to the MMM Adam's throw:
The space between the 10 O'clock magnet and the center of the secondary U core is a function of the primary coil inductance and would equal the Adam's resonance throw if the coil were part of Luc's MMM.
A ratio of that segment of the arc factored by the coil inductance can calculate the travel of a 10 pound coil.Last edited by Allen Burgess; 05-20-2019, 09:46 PM.
4 Kg levitating rotor
The 4 Kilogram coil is levitating:
Here's a video of lateral Mendocino Adam's resonance
Originally posted by Pot head View PostOk Allen go ahead and do your thing.
In the end, if you are above board and truthful about this information and you build it here with your photos then, just then, maybe, I might change my mind.
Core saturation
The levitator magnets at the ends of the ferrite core would saturate it and the weightless coil and core would have the same inductance as they would if the coil were traveling on a fixed core.
Look how Kundel generares rotary motion with a small linear oscillation:
An Adam's resonance Mostly Magnet Mendacino linear oscillator with Kundel rotary motor would be Ideal to replace a Diesel motor and ballast in a sail boat. Silent and vibrationless. 750% approximate efficiency after conversion losses.
The throw is in Adam's resonance range for the kickback; The width of a ring magnet on the rail:Last edited by Allen Burgess; 05-23-2019, 05:27 PM.
