Magnet switch torque amplifier.
  • #31
    8X rung
    3rd and 4th Tiers; 8 and 16 times the magnet force per input pulse as one: We can half the input by scaling the primary down one tier. Starting off with an 1/8th inch alnico and Neo, we would end up with a 4" diameter neo and 32 times the magnetic force.
    • #32
      NTesla
      "The past few days I have been thinking about a similar concept! Essentially an Ecklin generator that uses toroids as flux switches instead of the mechanical 'flux blocker' i.e a solid state Ecklin generator (which in many ways is like the M.E.G).".
      Could these torodal flux gates be replaced by a pole reversing "Alnico/coil"? Just flipping the hinge.
      • #33
        MEG ladder
        The output from the stator coil should surpass the power required for the trigger pulse: This device has to run itself at some level of scaled up proportion. 2 caps and a DPDT switch. The bottom stator can be wraped with output windings too.
        • #34
          Enlarged output coils
          Enlarged output coils. Enough to store and return it's own trigger pulse?
          • #35
            circuitry.
            One diode and one capacitor in series between the output coil electrodes, and a DPDT blade switch with a neutral position. We need to charge the capacitor to start the amplifier; Then, the capacitor is discharged to the alnico coil through the DPDT switch, first in one direction, then the other just flopping the blade switch back and forth. A surplus charge accruing in the capacitor would act as compelling proof of Overunity!
            • #36
              Wiring.
              This is the final wiring componants.
              • #37
                Here's the finished circuit:
                • #38
                  Double ratio.
                  A third gate halves the size of the Alnico coil and the input: Picture of four rungs from different angle: This design needs no external power source to run itself outside the switch energy. There's lots of magnet flux outside the windings that can be put to work.
                  • #39
                    internal tier.
                    It would help to tuck the protruding gate to the inside to eliminate the obstruction to the flux stators. It would look like an "L" from the top. Two of them facing one another could reciprocate a magnetic armature and generate motor power.
                    • #40
                      New generator.
                      Here's a 220 pound free energy machine for sale that's nearly identical to the configuration in the current project. He's got a rotating magnet wheel.
                      The magnet wheel is using both poles of the stator to power alternately placed NS magnets on the wheel. The axis of rotation is between the stators! The magnet wheel is using the stator windings as output coils. Pretty ingenious.
                      • #41
                        Generator video.
                        This is just a scaled up "Flux Gate". We get a good look at the spinning rotor shortly into the video: The rotor studs are probably just high perm magnetic ferrite material working on attraction, not magnets:
                        • #42
                          Trapizoidal magnet arch.
                          Three magnets thick would equal 15 powerful neo's in the arc: Many times the force of a cylinder.
                          • #43
                            Purchase.
                            "Innova Tehno, INNOVATEHNO1943 d.o.o. – Research and experimental development on natural sciences and engineering., in Croatia has just released a working free energy device to the public. They released a video of their working unit on their Youtube Channel. Their device, called the IPP7.4 is an electricity generator delivering an output of 7530 W at 220V without using any fuel for it's work".
                            I'm trying to buy one of these generators: The outfit's in Croatia. The deal is; They deliver, set up and let you run the generator non-stop for 30 days in your space. They then return and recover it if you don't care to purchase, but you get stuck for the return charges. They ask that you post at least that much with them in advance. The unit's currently priced at 3800 Euros.
                            They only deliver to specific parts of Europe: Like 150 km radius of Munich Germany. The customer needs to prove he will reside at least one year at the set-up site. I have a friend in Ravensburg Germany. I'm trying to arrange a delivery there. The company maintains they use this generator to run their own delivery van.
                            • #44
                              It looks like a copy of testatika.
                              • #45
                                Testatika.
                                @elbinario,
                                We can see the similarities in the depictions below:
