Spiral machine
Leverage only.....
Ted,
Having worked on dozens of Gravity Engine designs over the years, I am fairly sure this one can't work, no matter how perfectly you build it. The machine design produces a balanced leverage equation approximating the following statement:
Can four weights on a short lever lift one weight on a lever four times as long? The answer is NO, it just creates balance! There is no energy to be gained by this process.
So, with bearing friction and rolling friction of the weights, you will always be 1% below breaking even.
Sorry.
The ball weights on the spiral do NOT build up angular momentum because they are NOT spinning, they are just DROPPING along the ramp. Your Milkodini machine is on the right track, because it also harnesses the centrifugal force of the spinning weight. Work that one out as it is much more promising than other designs that ONLY use gravity.
Peter
Thanks for the input Peter.Originally posted by Peter Lindemann View PostTed,
Sorry.
Peter
I'm still working on the other machine, but I'm waiting on some parts so I put this thing together.
I beg to differ on the point of angular momentum. I purposely built these tracks so the balls would ride closer to their axis of rotation. This builds up a much higher rate of spin than if they were rolling on a flat surface.
I realize that gravity alone won't make these wheels work. My original thought was to use a disk shaped weight with an axle that rode on the rails and developed enough angular momentum that when it got to the bottom, that momentum could be put to use getting it back up (but I only had these ball bearings). If the rim of the weight were to be used as the motive surface once it reach the bottom, it could quickly pick up a lot of speed for the trip back up the ramp.
If I get the parts in this week I should have Milko II running by the weekend.
Cheers,
TedLast edited by Ted Ewert; 11-05-2007, 06:24 PM.
My Gravity Chain
Hi Ted, Peter, and everybody!
First of all......Peter, you have worked on DOZENS of gravity
chains? AMAZING! Is there an alternative energy you are
not an authority on?????? (compliment)
Secondly, here is my idea for a gravity chain, but to understand
it fully, I suggest you watch this Youtube video showing the ability
of small magnets ability to make large magnets totally defy gravity.
YouTube - Magnetic Launcher
It is also largely based on the "Murilo Luciano" gravity chain here:
http://www.panaceauniversity.org/D21.pdf (page 7)
Anyway, here is my idea/photo. I wish I knew how to make those
cool 3-D videos that some of you guys do. The mechanics of this
are still being tweaked, but try to imagine all the balls below circulating
inside of a clear plastic tube. On the outside of the tube are the smaller
magnets propelling the larger magnets similar to the Youtube video.
Basically, magnets lift the weights on the right hand side of the chain,
and several forces drive the weights down on the left of the chain. The
sprocketed wheel at the bottom can be used to drive a generator.
I am pretty sure that it will work, but I just have NO CLUE what kind of
force it might produce. It could obviously be scaled up, or scaled down,
but as it is drawn, the small 1/2" square magnets are only about .50 cents
each, but those large 1.5" magnets are very pricey at around $35 each!
(somebody please tell me if you can find them cheaper)
This is not to scale at all, nor are the number of magnets, but hopefully
you all will get the idea.
Thoughts please.
Thanks, Bob
