It is my understanding from the general consensous of this board that a very large antenna or pan is needed to get any amount of reasonable electricity to be practical for useage in an aerial setup. I have access to a very large steel roofed building that is shaped like a cross if seen from the sky. It is made of 8 Atco trailers with a hallway in between and a common area in the middle. It is also raised because of the sloping ground. This is part of an old logging camp turned mining camp. The wiring system is all underground and was supplied by a pelton wheel turbine of 60kva normal running and can be set to 160kva.Its a Thompson and Howe installation. The turbine has been out for repair and in the mean time I still need power to run a few things.So my thoughts are to use the roof as the antenna because it has some major square footage for surface area, and I would use the ground wire in the ground as the grounding point. Obviously I will be dealing with high voltage of which I have some experience.I only have basic meters for measuring tools digital and analog. Who has experience in this sort of research or projects and what can you suggest for a circuit to drop the volts to a useable level? I have a fair amount of stuff here at my disposal. I can report back with the results as I work on it.I want to put in a kill switch for total shut off .reason being this area I am in is in the mountains of British Columbia.There are few thunderstorms around and You always know they are coming long before they hit the area.The rocks are heavy in pyrites,magnetite and hematite,shists and granite.There are pyritic ores behind me and in front on the next ridge that are pure pyramidial crystals of about 1/4" in size in shale.Usually there are fires every year from the lightening hits.So I need to shut the system down when the storms are coming which is about 2 weeks total in the year.
I have a power shut off switch already.lots of wiring,a few radio style tuning caps and one big one from a piece of navy equipment.and a lot more parts to play with.So if any one is interested in working with me where by I do the work and you do the suggesting,internet research,suppling info,etc then let me know and we can see what kind of trouble we can get into.
Thanks for any input.
Andre
Andre
hey I still have some 8 tracks too!!
