@wayne.ct - yes, the PVM12 is from amazing1.com. It's a handy little device, mainly because it's tunable. Inside it has an SG3524 chip driving two MOSFETs in a push-pull configuration into the HV transformer. Also seems pretty robust, at least my experimenting has not damaged this one so far.
@ricards - no, I hadn't seen that thread, thanks. I'm pretty sure at this point that Tesla knew a lot more than he ever stated publicly, and you really have to study the designs themselves. The more you understand yourself the more it becomes clear how advanced he really was. I'm fairly sure the magnifying transmitter was intended to produce the same kind of effects the Don Smith device is. The wireless transmission through the earth has certainly been demonstrated, and if you're sending power with a radiant characteristic then the receivers should operate overunity and it would be possible to tap arbitrarily large amounts of power from any point. Essentially the normal electricity just acts as a carrier wave for the radiant part, which apparently Tesla had also figured out how to use for broadcasting voice and data!
And yes, the current output configuration is with bucking coils, wound CW/CCW. I have tested and verified that just the dual partnered bucking coil configuration doesn't seem to make any difference over a single coil. When I briefly had the battery self-charging working, it did seem to exhibit the self-correcting behavior Don talked about, I wondered if anyone would bring this up. I could increase the load by changing the frequency on the PVM12, the battery voltage would dip a little, then go back up nearly to where it was in just a few seconds. It acted exactly like Don's system on the video, so I was excited about this.
still working with the charging capacitor speed, the reason for this is Don Smith himself talk about the explosion came from short circuited capacitors bank ( very big and dangerous ... ) , i don't expect any significant output unless the capacitor banks has it, this is my opinion .
