Hi bob, thanks for the reply, yes the cen-tech seems to work really well.
I have been watching the other threads for sure and studying your results and others, though i don't have a boost converter yet, nor sufficient batteries yet, so i can't make similar tests yet.
However, i am learning much from the setup i do have at the moment.
This setup is showing very promising results, using the 20 cell nimh battery pack, with cen-tech inverter splitting positive between 12 volt tractor battery, then off one of the 115vac output plugs, a transformer with 24 vac step down, then full wave bridge, with 12 volt-4 watt yard bulb splitting positives to 12 volt charge battery.
This setup seems very efficient and is for sure recovering just about all, if not more, the energy that came from the 20 cell nimh battery in split positive phase.
One thing i notice, the 12 volt charge battery should be discharged enough before the split positive phase, otherwise, the energy is not absorbed well enough, if it is too close to fully charged.
So, i am powering the 12 volt-4 watt yard bulb, essentially for free, for sure.
I also definitely see the need for a decent sized charge battery bank.
I also see the need for good wire connections, thick, low resistance wire preferred.
Hi turion, oh, i have no doubts at all, based on what i am seeing and at some point, i will have what i need to make similar replication.
Thanks for all your efforts to share turion.
peace love light
peace love light
I am thinkin keep doing that to see
