Splitting The Positive
  • Originally posted by Turion
    You have a given cost in watts to even run your motor. When you add a rotor to the shaft, you have an increase in cost (watts). If this cost can be maintained, you will have a machine with a COP much greater than 1.
    How do you control those costs when you are going to put iron cores in front of the rotor magnets that will cause magnetic drag? Well, you make sure that the machine speeds up under load, so as long as you are running loads, that additional cost is almost completely neutralized.
    So now you are back to zero, but no gain, so over time those tiny losses will add up. What else can you do to lessen the attraction to the iron cores?
    Replace them with ferrite? Move the coil away from the magnets? Change the configuration to reduce magnetic attraction? All of the above.
    Yes that is a good way to put it. Measure the energy it takes to rotate
    the rotor over and above idling costs, next measure the drag/cost of
    bringing the static field of a coil into close proximity of magnets, next see
    if shorting the coil returns the rotor to zero drag costs, collect the energy
    and return it to the input to get OU?
    Then keep adding a coil til high COP is reached.
    If more reactive core materials harvest more energy then use them.
    Iron is fine for 60hz but what about 300hz? Also tinned wire has been
    a known way of collecting extra energy with a little bit higher frequency.
      The more magnetic drag you eliminate the higher the COP will be.
      Then keep adding another coil til high COP is reached.
      Saturation will cause drag.
      Drag is something we could work on to lessen. Placing magnets and
      coil poles so that with the motor or generator turned off, the rotor
      can free wheel without cogging is one answer.
      • Hi all, Hi mike, i think the idea is that the capacitor causes a phase shift.
        This comment by life is illusion from youtube is interesting:
        "The capacitor will cause a phase shift. This is exactly what we use in induction motors to shift the phase of second set of coils to kick start the induction motor. Even if you get to shift the phase by 3 degrees, you go around Lenz's law. By adjusting the capacitance of the capacitor, you can create any degree of phase shift that you want. You can go totally 180 degrees out of phase and then the Lenz's law will work for you, not against you. This is very similar to the regenerative acceleration method. Really amazing way of going around the problem of Lenz's law"
        I may try a transformer, as i don't have any mechanical generator, set up at the moment.
        peace love light
          peace love light
          Yes there is something to what you are saying, THE ROTOVERTER is the
          word I am looking for. Many claim that by using caps to tune a 3 phase
          motor a window of opportunity arises to harvest a degree of energy
          IF and only IF the load is tuned to the the phase shift.
          From what I understand no one to date has successfully used this
          idea to develop practical amounts of energy. According to the advanced
          experimenters in this field, tuning in a very narrow band is easily thrown
          out of wack then retuning must be done.
          It is a great thought and I have heard of a couple who hung in there
          and played with the tuning long enough and he claimed he used it on
          one circuit in his house to start out.
          It is possible according to some. The rotor-verter experiment has been
          on the books for decades and is what we are talking about.
          Good to see you around.
          • I am not suggesting to go full Muller but this video gives us more
            than a few lines of text about cogging in visual form.
            MOGEN, NEOGEN whatever ya wanta call it.
            https://www.youtube.com/watch?v=W9-oqMcsZGE
            • Anti cogging ideas. With this approach the huge start up amp
              draws are eliminated as well as the run cogging drag while still
              getting the magnets past the coils to produce full power outputs.
                I didn't bother to go to YouTube to see if this individual actually builds things or just draws pretty pictures and talks a lot.
                This drawing is NOT balanced and does NOT neutralize magnetic cogging. I know because I HAVE built it. One of many, many rotor designs. Every magnet in the picture shown has its direct opposite except two. By this I mean that as one magnet is leaving a coil, it has a direct opposite that is approaching a coil at EXACTLY the same distance.
                The two exceptions are the magnet at 12:00 and the one at 6:00. When the magnet at 12:00 is locked onto the coil core, the one at 6:00 is exactly between two coilss. This means it is being pulled equally in BOTH directions. This does not counter balance the magnet at 12:00 that is locked onto a coil core
                With this arrangement there is always ONE magnet that is aligned to a coil that has NO magnet that balances it. A setup with ANY even number of rotor magnets and an odd number of coils accomplishes the same thing.
                Thanks Man TURION-MAN
                AS usual in my haste I jumpped to conclusions but I do know better
                after looking it over. BRB
                • I looked at it again.
                  It is pretty much what I was thinking should work actually. One magnet
                  leads and one lags at exactly the right degree to create a balance.
                  I have not built this one. Just using magnets and steel blanks it seems
                  like it would be close to balanced except for the 12oc vs the 6oc as
                  you pointed out. It is like people post stuff that gets put around the
                  web to throw people off keeping them running in circles.
                  I got to think about this and draw it out. BRB
                  PS thanks for keeping me on the straight and narrow path so i don't
                  have to waste years building other folks wet dream pictures. Makes
                  me so mad.
                    So think about this....
                    It is ONE of the solutions I came up with, but NOT the one I chose
                    to use. I didn't like all the switching required because I am
                    electronically challenged.
                    I feel like the kindergartner who asked what comes after "A"
                    "electronically challenged"? Who wants more complication than needed?
                    We could build circuits that function within a very narrow range based on
                    how the optics are set up, that stuff takes huge amounts of time.
                    I my case i think the best way is to place one core around the rotor
                    at a time adding and collecting ideas. I can't even produce another
                    idea at this moment.
                    What comes after "A"?
                    I have been doing some chicken scratch on paper at least?
                    • Looks like somebody got the grinder out as one fix.
                      Anti-Cog Technology
                      http://www.machinedesign.com/motorsdrives/how-ironcore-motors-defeat-cogging-and-find-new-uses
                      • Anti-Cogging Ideas
                        He calls Muller designs a "HOAX"
                        https://www.youtube.com/watch?v=7ZIiRnncLMQ
                        • Hi all, has anyone here tried air coils and achieved zero affect on rotor speed or rotor acceleration when generator coils are loaded.
                          I seem to recall erfinder saying he had done that.
                          Air coil would seem the best route to take.
                          If indeed, bifilar or multifilar coils, with the strands in series can increase the capacitance of the coil and cause a neutralization or speed up under load, sounds like the way to go.
                          I think i have to set up a simple neo magnet rotor with a single coil and start making some tests myself and i will swipe one of the brushless motors from one of me rc planes with speed control.
                          peace love light
                            peace love light
                            Let me know on what you did test. The cogging is the subject at
                            the moment that greatly effects COP. Air cores also cog but not as
                            bad however they don't generate as much current unless the windings
                            are 10X as long as an iron core model, then your cogging would be
                            just a strong as before I assume.
                            Turion went to the patent and made some TESLA coils and said that
                            is the way to go. I am not sure what they looked like. I'll have to go
                            read that patent again.
                            Anytime cogging can be reduced is good as long as you are not trading
                            it for generated power, that goes without says it.
                            • A study on inductors and core material.
                              https://www.youtube.com/watch?v=3b8Wol-X4tE
                              https://www.youtube.com/watch?v=6681mgFNomc
                              https://www.youtube.com/watch?v=MMnpw2UcEHc
                              • When we consider core material inductance and saturation as
                                well as different unorthodox coil impedance designs we can see
                                how cogging effects are increased and decreased.
                                As a point of reference when I wound my first large quad filar
                                spool of 7lbs, I learned that as an air core the frequency was
                                high for a simple oscillator circuit such as JOHN BEDINI had shown
                                us in the 70's.
                                The amp draw is also something to note. When using bolts, welding
                                rods, coat hanger wire and misc the amps will increase dramatically
                                as compared to the air core. Also when using the large coil at a
                                productive output of 1-3 amps 12-24vdc input the iron cores will
                                heat up slightly.
                                Heat is loss of energy. It worked well for pushing the envelop getting
                                lots of high end spikes at the increased output just the core itself will
                                induce into the system without changing resistors.
                                Then something great happens when you switch to ferrite. If you use
                                cylindrical hollow beads 1" long stacking them up 5 or 6 at a time having
                                (In my case) a diameter of 3/4", you can replace your iron core.
                                RESPONSE
                                You are in for a good RESPONSE. Your same inductor will output the same
                                amount of energy for far less input and that makes it worthwhile. For some
                                strange reason, all the little dust particles of a wide variety of exotic
                                metals, including iron dust will out perform a chunk of iron with a little
                                sand in it, any day.
                                Performance means response time. Response time improves the fields
                                ability to reverse without lagging behind which is waste and does cause
                                small amounts of undetectable heat losses. I say undetectable because
                                the average guy will feel the core material and say he does not feel
                                any heat.
                                Whatever the case and regardless the amount that tiny bit of energy
                                is translated directly into output therefore raising the operational
                                efficiency of the black box.
                                At the same time cogging is reduced at the poles because the raw iron
                                is not there to create a response lag anymore. The output in greater and
                                the cogging is brought way down.
                                One of John Bedini's latest videos shows an air core motor. It has tiny
                                amounts of torque, huge coils using infinitesimal amounts of energy to
                                run with limited cogging.
                                John taught us everything we need and he demonstrated each effect
                                separately stating that we should learn each one and then add them
                                together if possible to evolve any design.
                                No single effect holds the answer.
                                I posted those engineering video's for your pleasure and I have been
                                looking for an American who is capable as only the Indian people are
                                generally doing this work that is nearly impossible to understand.
