"Honda's VTEC-E ("E" for economy) valve timing and lift system runs leaner than ever, in part because of a new air-fuel sensor than can detect mixtures as lean as 25:1. The electronic control module maintains a lean mix below 2500 to 3200 rpm (depending on throttle position and load). Above this range, the VTEC opens the second set of intake and exhaust valves".
I tested this 2000 Insight with an onboard Hydrogen electrolyzer, and got a 50% increase in MPG. The incredible thing I discovered was that the Insight continued to get the increased range even after I turned the Hydrolyzer off. I surmised that the motor began to power itself off the atmospheric humidity after the air fuel sensor adjusted the timing to utilize the hydrogen. I simply ran the hydrogen directly into the manifold air intake pictured below on the right.
I believe simply attaching a metal hydride Hydro-stik to the air intake the same way would condition the electronic control module to burn atmospheric moisture as fuel the same way! The efficiency of the IC motor alone went from 55 MPG to 80 MPG with the hydrogen. I believe that when the air fuel sensor detects the hydrogen and accepts it as fuel, it then directs the control module to accept atmospheric humidity as fuel also! You'ld need to prime the engine with the hydrogen after every new start to reset the computer controlled timing to get it to burn moist air for gasoline.
