Walter Russel / Utron research
  • Walter Russel / Utron research
    Hi all,
    I'm trying to do some research on the Utron en Walter Russels concepts ..
    After years of reading al the stuff.. I have some idears i wanted to test.
    I'm not claiming anything, just sharing some of the fun while doing it.
    Im still building a basic test setup, and trying to keep het modular, to make easy changes.
    Here is a little overview:
    [VIDEO]https://www.youtube.com/watch?v=10Jg8u-NgLs
    [/VIDEO]
    Here is the first attempt of spinning things up.
    [VIDEO]https://www.youtube.com/watch?v=JZh8h9UViqA
    [/VIDEO]
    Still some wobbling and things to improve... But i'm happy ! : )
    There are two hollow axis inside so i can turn independetly or run wires true.
    In the spinning video i just spin the central core axis and the Utron with disc and the ball on the outside only move due some friction and drag.
    Next step is some wiring.
    Wiring start
    Starting some wiring of : )
      Little tests
      As i am building.. I also do little tests in between for fun and to see what i can observe. One of them below
      You can see the setup is very rude and simpel.. and not finished..
      I just could not resist spinning al little up : )
      [VIDEO]https://www.youtube.com/watch?v=taXHnG3_AvQ[/VIDEO]
        I remember buying info on that long ago,
        and it had conflicting data
        it seems to either have been made of acrylic plastic or solid aluminum
        but because I could not figure out what one it was, I never built either
        not to hard to make either,
        I should have tried each of them to find out what they did
          Hi Spacecase, dou you still have that information? That would be intrestring.
          Im testing now if i can set up some kind of magnetic field inside.
          Only half done.. but some testing anyway
          [VIDEO]https://www.youtube.com/watch?v=yk0Zu90zuFg[/VIDEO]
          [VIDEO]https://www.youtube.com/watch?v=s1e7NJV1YeU[/VIDEO]
            I do have the "poor-quality photocopies" mentioned at this link
            Otis T.Carr: The Utron Electrical Accumulator ~ Articles, Model Construction Plans, US Patent # 2,912,244 &c...
            have run across them a few times in the last 30 years, but can't seem to find them at the moment.
              I know this ones , but tnx anyway !
                the poor-quality photocopies they had when writing that link appear to be missing pages,
                mine sure was missing a page when I got it, but it appears to not be the same page they have missing
                  I agree, the more info the better.
                  But for know i'm not making an exact copy , Im just using it as a guideline for some of my ideas.
                    Some new testing
                    Doing some testing with electrostatics and the Utron
                    [VIDEO]https://www.youtube.com/watch?v=Hc63ieqb_Bc[/VIDEO]
                      what tests are you running ?
                      any results ?
                        any results ?
                        I'm gonna try all kinds of different setups.
                        Now i have a base to start, i built a more stable test bench .
                        I have made different Utrons, some as a capacitor, in different configurations.
                        Next step is to create a magnetic field around it.
                        I have something i my head... Wich i'm trying to build.
                        The electronics part is hard stuff for me, as i'm not that experienced in electronics.
                        But i', having fun and i'm learning.. we will see what happens : )
                          Double Utron test
                          Here i'am testing a double Utron rotor
                          One with large plates for torque, the other with small plates for speed.
                          [VIDEO]http://www.youtube.com/watch?v=Y1PIOBXqGls[/VIDEO]
                          • #14
                            • #15
                              Small update
                              [VIDEO]https://www.youtube.com/watch?v=OjChKvA5tCM[/VIDEO]
