  • Here is the way the stupid leaders treated Thane in Ottawa.
    It's the same ole "TOY YOYO" of "it aint so" retards certifying
    brain dead hopeless flunkies. And that is putting it nicely.
    THEIR CONCLUSION stated " lot of self-promotion " calling Thane names
    of course such as a failed student. Completely and deliberately ignoring
    the facts. This is as simple as it gets, so if you can't read this tiny
    document, you are in the wrong field.
    Concerning University leadership. THEY are put into power based on
    THEIR plagued allegiance to the current system of power, promising
    never to go outside this box. THEY are yes men not smart people.
    http://www.ottawaskeptics.org/2013/09/20/in-this-town-we-still-obey-the-laws-of-thermodynamics/
    • Originally posted by Turion
      In the testing Matt Jones did with his
      original 2 coil setup and a STOCK motor, which I replicated, the
      speed up under load was ADJUSTED by adjusting the frequency of
      the pulses to the motor from the 555 timer. This allowed Matt to
      reduce the INPUT to the motor while maintaining the ORIGINAL
      RPM and therefore the EXACT SAME output.
      Yes I have been in thought the past few days remembering these
      details given before. The stock motor I just assumed is a commutator
      DC scooter motor? Then the pulse works great off a 555 time making
      a square wave that regulates the amount of excess power that might
      be getting wasted at a wide range of so called "sweet spots".
      Without the graphic display.
      Anyway back to business, the AC motor is another animal that can be
      adjusted with a Variac to pull back or move around to find the most
      advantageous operating node.
      These are thoughts of optimization, so what would be the circuit to
      use to pulse an AC motor?
      In the generator side AC in produced, also motors like AC, but I can't
      think how you would pulse an AC motor so it didn't rattle like a tin
      can. A ZVS circuit does produce a sort of modified wave good for
      driving ac devices but nothing as efficient as a pure sinewave unless
      I am mistaken.
      Here is what I know. One day I connected my window AC unit up to my
      3000/6000 watt inverter that runs off of a 3000ah battery pack. It worked
      like crap. The small AC unit did not like the modified wave the inverter
      produced so instead of needing 40 or 50 amps to run at 12vdc because
      the unit runs at 4 amps @120vac, it needed 90 amps.
      Motors hate modified waves, they want a pure AC.
      Now if all you have are DC motors then that is another subject entirely.
      I know Tesla could get it to work with either AC or DC.
      Motors of all kinds react in different ways. Some AC motor pull 65 percent
      of their maximum rated capacity whether you use it or not. The Variac
      allows the AC motor some adjustment room to find a more finely tuned
      range for any load. If I drop volts to 60v the amps go to 2400ma.
      This is not good for efficiency either, but 80v is good for a 1700ma
      range on this motor. Maybe I can pulse this? And save?
      Same thing with a DC motor, you can't lower the voltage but you can
      change the time of that voltage getting to the motor.
      The AC motor uses a VFD that is like a 555 timer on a DC motor.
      BTW the rpm stays the same all across the voltage ranges of 85v - 105v
      under average load, so this does work the same. With no rotor this motor
      ran at full speed on only 500ma but with the rotor about 1500ma.
      With the coil added 1700ma. However the RPM's do not change from
      80v on up for such light loads. This motor is rated at 2700ma and probably
      runs at 2200 or 2300ma all day long.
      It is not uncommon for homes to have deficient wiring where 95v to 100v
      is all that people can get, the power producers design for low line
      conditions as a safety precaution. This enables motors to still be around
      the same efficiencies at voltages above and below 100v.
        the speed up under load was ADJUSTED
        by adjusting the frequency of the pulses ,,,,,,,,,,,to reduce the INPUT
        to the motor while maintaining the ORIGINAL RPM
        Under no load conditions this 3400rpm AC motor ran at max speed
        on just 500ma or less. Under this test if I turned the Variac higher
        the amps and volts changed slightly but no change in RPM's.
        I can see that I need more testing on this subject.
        One test I made with no rotor ran near the max speed at 44v.
        Most motors are built for a specific task based on the max needed
        so most of the time a motor ALWAYS needs to produce over half
        of that. Dialing back is no problem.
        In one test with only 11 strands activated the prime motor current
        dropped from 2100ma down to 1700ma and produced power of
        it's own. Estimates were 30 watts. Not as good as Matt's.
        • Here is an updated test. So the meters do not read AC right or
          I am missing something. The meter clearly read 100ma yet
          when you do OHMS LAW formula it comes out wrong.
          So like you say, converting to DC to read values is a must.
          My wire just came in today and I have almost finished my counter
          jack shaft and mini platform...........Much to do, the fun is just beginning.
          PS a note to all of our viewers, Matt and Dave test for years before
          releasing any data and in my case I am letting each other of you see
          all of my baby steps, blunders and successful tests live in real time.
          I can appreciate and respect their great results and method of delivery
          time to the public, each man is entitled to his own way of doing things.
          In my case I am not so concerned with people calling my testing
          adolescent and am not going to patent this. I need no funding, just
          time to verify the THANE HEINS replication that has been greatly
          altered in the coil section.
          The speeding up under load phenomena is not a new one, others far
          and wide have already accomplished this on youtube for many many years.
          What I am doing is finding the most advanced investigators such as Matt
          and Turion to see what else could be done then proceed to build and
          add one idea to another of which they have led the way.
          Even now I am only following their lead. Often I sound off random thoughts
          as so many ideas are coming and going, but I will settle in over time.
          I have built a winding table, 2 Matt Mod Mtr's, 2 AC motor setups, 2 clutches
          another winder, a counter for the winders, litzing winder, AC variac mini
          with inductor and the list goes on forever..................................
          I am a man with a spinning head right now, bare with me awhile, the fun
          is coming.
          I am on my feet 12 hrs a day with rejoicing. My wife wonders
          if I am ever coming in? Nope my race is almost done is my reply "No Time"
          • Conductor Size Data
            • I have not studied POWER ANALYZER operation so I have a question.
              WHY does his input read AC volts on his screen? He emphatically states
              that his input is pulsed DC yet the reading shows AC.
              This is Thanes late video
              https://www.youtube.com/watch?v=1LFGBqnR6tE&t=10s
              • Thanes new EBIKE brought to life.
                STEpper mtr that runs on AC. Crotch rocket with unlimited range.
                https://www.youtube.com/watch?v=H92qe2-tq6w
                • Looks like I answered my own question about why Thanes analyzer
                  always shows AC when he states the motor section runs on pulsed
                  DC. I should have remembered that Thane always uses a variac and
                  in this picture you see the power strip coming off the wall.
                  So you see Thane is not showing a complete package. I was under the
                  false assumption that Thane was using batteries to run his motor circuits
                  and then generating more out than the input.
                  I was wrong. Thane is running power off the wall, showing his PF cos
                  that comes off his variac. There is a bridge rectifier and a flyback
                  recovery box. His source is the power company.
                  And best his video's are educated conjecture. Now if he had used
                  batteries to run his motor and then used the generator to send some
                  back we would then have an idea. That would and has always been
                  the criteria for "LOOPING"
                  It is as if his video's are a form of trickery. He constantly focuses on
                  the amps coming out and the amps going in. Rarely does he point out
                  that the 2 amps his circuits take to run the motor requires 70 volts
                  and how the 2 amps generated is only 14v.
                  Then there is the issue of a real world circuit where power comes out
                  of the battery and power goes into the battery. Nothing even close
                  to that is being shown. It is merely a quick easy way to demo but the
                  real figures will not reflect his youtube showmanship.
                  I have realized now that it is a youtube brochure so to speak, a come
                  on to get investors. It is time to move on because to get the answers
                  we need require level playing field of batteries powering something while
                  also being charged.
                  Thane is not doing that and for some strange reason i trusted him to
                  be showing us a more completed picture. Now i feel let down. It is
                  almost dishonest the way he played the viewers on the amp draw
                  stating that he is getting more back than he is putting in.
                  I guess he figures he is advertising to mental midges who see his
                  video results and never ask any questions of which he never answers.
                  Thane has very few followers and hardly anyone comments. He ignores
                  everyone. Here is Thane variac. What a dummy I have been to think
                  these demo's were set up like an EV using batteries. Like a carnival
                  trick. He is after people with money.Most of them don't have the
                  slightest idea about the engineering hurdles.
                  This is a setup that runs power out of the wall to charge batteries.
                  Some mechanical left over using coils that assist rotor action. Great
                  working principle but nothing practical. No conclusive figures.
                  More like investors speculation
                  • CAN YOU BELIEVE THANE STILL WANTS MORE MONEY FROM
                    INVESTORS? HE LOOKS RICH TO ME ALREADY.
                    https://www.youtube.com/watch?v=BASQju5X09o
                    • Thane is kicking booty in his teaching video's again ATTA-BOY
                      I am sure the red tape is piling up as poor ole aging Thane waits for
                      his patent to go thru.
                      Nice work Thane we love you here.
                      https://www.youtube.com/watch?v=t6i2eLnDVS0
                      https://www.youtube.com/watch?v=3KSPlGAAJoI&t=2s
                      https://www.youtube.com/watch?v=EKxxXNq_r9k
                      • REGENX MOTOR COILS TO GENERATOR TRANSFORMERS
                        Video's 1 & 2 cover AC operation and DC feed transformers
                        https://www.youtube.com/watch?v=QdcStiR1tDg&t=228s
                        https://www.youtube.com/watch?v=mPn8zl_q9_g
                        • Conventional power wasting topology which were Tesla's early
                          designs. When Tesla improved his designs to make motors run
                          for free his life's work went up in smoke courtesy of the Morgan
                          mafia thugs who were only interested in builds that waste power
                          thus costs went up for the demands of fossil fuels.
                          http://www.proliberty.com/observer/20070405.htm
                          I will be back to share my views about what Thane Heins teaches
                          in his board talks. Thane also uses advanced switching formats that
                          turn the coil on and off at the right time to lower power wasting he
                          calls RegenXtra. For now let's look at these systems without that
                          Xtra circuit.
                          Below is shown our present day power wasting motor strategy
                          • Here is what Tesla had in mind in Patent
                            https://patents.google.com/patent/US512340
                            Unless you can understand the implications of his statement
                            "neutralizing its self-induction"This
                            may require more studies on your part.
                            What I claim as my invention isn l. A coil for electric apparatus the
                            adjaent convolutions o'f which form parts of the circuit between which
                            there exists a potential difference sufficient to secure in the coil a
                            capacity capable ot neutralizing its self-induction...............
                            • So what Tesla stated was that the way motors were chosen to be
                              built was done so deliberately and not under his full direction and
                              Tesla's advice is still ignored to this day. Notice how he says that
                              motors were built to give rise to FALSE CURRENTS so if everyone
                              has rejected this information for the past 100 years, who am I to drive
                              this point home?
                              • a current of given frequency and potential...
                                Tesla somehow was able to compute the resonant frequency and required potential !
