Your Basic Coil
  • Watch out!
    From a comment on the other forum made by MileHigh:
    Starting at about 20:00 minutes into the clip you have the most dramatic "acceleration under load" when the 10-ohm resistor gets changed to the 1-ohm resistor. Luc even acknowledges that the electrical load decreases when he does this.
    With the 10-ohm resistor, the total electrical load is about 1.58 watts.
    Then the load resistor is changed to 1-ohm, the prime mover speeds up, and the total electrical load is about 0.98 watts.
    So, "acceleration under load" is really "acceleration (to a higher final RPM) under reduced load." In that sense there is no "effect."
    So with a RESISTIVE load, after the RPM increase (which Faraday tells us will lead to an increase of the induced EMF) we end up with less electric power.
    Watched again Erfinder's videos and one question comes to mind. Is this phenomenon related to what has been called "Reactive Cross Section"?
    Regards.
    PS: A conclusion though. It is apparent to me that acceleration under the load is not an end game goal, but only a tool inviting us to inquire more.
    • Many Thanks!!
      Thanks guys for all the support. I do sincerely appreciate it. I have also added another member to my ignore list. I am sorry I had to do that. But some people just don't leave you a lot of choice.
      Thanks again for your support.
      Carroll
        Carroll
        How does a guy come up with girls name like Carroll?
        • Originally posted by Allen Burgess View Post
          How does a guy come up with girls name like that?
          Same way I am a man and got the name Kerry....
          What are you 12?
          IGNORED
          • Kerry.
            What are you 12?
            IGNORED
            Not a cookie cutter build. Got a bo bo maybe?
            • a DWP offence
              Allen
              Its time to call it a night Bud
              Drinking While Posting can lead to the "very sorry morning after syndrome"
              BE that change !!
              • Boozing.
                Allen
                @Ramset,
                Go jump in a lake bub.
                • Deleted
                  Thank you.
                  • Free wheeling with neos
                    Hi Dave,
                    Yes I did watch that. Sorry I got busy and forgot to reply. That was nice to see that it worked just like you thought it would. I do want to try that same idea with the pump motor coils like I said in the email. Just need time and some more magnets. Looking for a couple of packages in the mail and I think I will have everything I need to try that. Thanks for all your help.
                    Carroll
                    • Originally posted by erfinder
                      On the other forum where I am no longer privileged to post, I introduce the audience to a concept I referred to as "Infinite Harmonic Resonant Self Oscillation"
                      Which forum do you no longer have privileges to post?
                        V
                        General D.Eisenhower
                        http://www.nvtronics.org
                          V
                          Thanks, learned something new!... I didn't know of the existence of that forum until today.
                          Luc
                          • Zero Force Generator.
                            @Gotoluc,
                            I did some tests a few months ago spinning a 120 volt microwave "Carousel Rotor" sideways against the windings and astonishingly measured "Lenz Free Output".
                            Try this with your coil core setup: Just slip the pickup coil air core hole over the diametric tube magnet rotor attached to your Dremel Tool, and see how much output your generate? This is sideways; But any output you get will be "Lenz Free"! Try speeding the magnet rotor up with your Variac and see what you get.
                            Any output harvested this way can be multiplied by packing diametric magnet coils side by side; Only one central magnet spinner needs to be powered, the remainder will spin by magnetic induction! Nested Lenz free "Mendicino levitator" output coils can go on forever.
                              Destructive acceleration is facilitated through the proper balance of parameter variation, impedance matching and mismatching, and Ferroresonance. This combination brings about the inversion of the motors own CEMF allowing it to augment the applied EMF.
                              My dogma......
                              What Gotoluc shared was a clever test bench for the parameters that ER describes.
                              So the problem is ERfinder's use of terminology and not luc's test bench.
                              The core can be hollow but the slide mechanism would require modification
                              to eliminate the iron round stock and use some slide mechanism relocation
                              outside the coils perimeter. Being adjustable should greatly enhance the project
                              an appropriate response is "thank you"
                              The correct concept uses an open system pathway because most are uncomfortable with the term FTL (faster than light) the concept of FTL CEMF interfacing the conventionally driven basic coil EMF is mistakingly confused with all kinds of strange ideas.
                              A unidirectional FTL EMF basic coil. What ever that is ? more importantly what effect would it have on the grid ?
                              • Zero Force Genertor.
                                Looking at the angle of solinoid windings from the POV of a diametric core spinner, we would notice a slight degree of slant. The winding is not strictly oriented to the magnet field at exactly 90 degrees. This may be enough to induce the output we collect. Nevertheless, the magnetic pole formation of the solinoid is from end to end, so the "Lenz Generated" reverse pole is directed away from the diametric magnet rotor field.
                                Luc is "Out to lunch" on any new ideas, but this is something anyone can try. I Invented a "Spiral Toroid" coil that runs "Lenz Free", have a look:
