ENLIGHTENED MAGNETISM (The Full Proof of Ken Wheeler's Theories)
  • Magnetic Interactions Elasticity... seen through ferrocells
    Ufo,
    It is illogical to conclude that magnetism bends light from viewing images made using ferrocells. I don't believe that the images which I've seen from ferrocells are an accurate representation of the magnetic field.
    Bistander,
    I have gone a bit further than Ken viewing magnetic fields through Ferrocells.
    Ken remains observing single magnets under ferrocell which gives you a stationary field.
    I have played a lot with magnetic interactions of many different combinations, maybe because my work (electrodynamic machines) depends on constant magnetic interactions to help me visualize the field better...
    It is a completely different behavior when you approach either two opposite or two like magnetic polarizations under ferrocells. You can observe very clearly the Elasticity and real Volume from both fields...just like a "Soft Bubble"...where both either compress into each others...or simply "blend" into each others forming one single bubble...then you realize the Field is not only about the curvilinear brighter lines seen on the static, single field...but the whole 3D Volume it forms through them.
    It defines very differently behavior on both Main interactions, Attract and Repulse.
    I have filmed it...but it is not the same as to do it yourself...plus cameras must be very HD...and mine is...but I guess it is required even higher definition.
    Did you see the one from MRIguy holding the ferrocell in the MRI? It's on the ferrocell home page. Too bad he doesn't come around this board anymore. You can believe anything Ken tells you. I'll stick to what works.
    Nope, I have not seen it...I will try searching on ferrocellusa home page....
    • "Doesn't matter how many times you kick the coyote in the head, it's still gonna eat chickens". - EPD
      • Originally posted by Sputins View Post
        Okay, now a similar arrangement is made, same magnets, same washers but instead of the washers being sandwiched between north and south poles of each magnet, we spin one magnet around so we force two like poles together with the iron washers in between. With the hole through them we can bolt them together with a stainless steel nut & bolt. So we have North-Iron-North. Call this arrangement Magnet Set B.
        When one makes these magnet arrangements A & B, the iron washers of set B have incredible magnetic strength, compared to that of set A. (or even the a single magnet).
        Q1, Is this because the iron washers in set A are more or less in the dielectric plain of the magnet or the (blotch wall to use another term) thus the magnetic strength is weaker here? Set B have the two north fields forced into the iron washers, giving rise to double the magnetic strength?
        Q2, Has this opposing fields forced together been viewed with a Ferrocell?
        Magnet Set B is like the Boyed Bushman magnet drop experiment concept and similar in principal to Magnetic Beam Amplifier. I think Bedini has done something similar too.
        Okay given all that, leads me to the important Q3: What would be an electromagnetic analogy or equivalent circuit of the principal behind Magnetic Set B??
        https://www.youtube.com/watch?v=hvUiQ3IMHMUhttps://www.youtube.com/watch?v=iUy_9jDKDvo
        I can now go and cook up the project in mind, now that I have the special sauce required for the recipe.
        • Crickets
          Hi Sputins,
          I was going to reply but decided to let the crickets or Ufo address your post. I believe in the old school magnetic theory, meaning no imaginary planes or walls in the middle. I like the flux lines. In the following link you'll find femm animated simulations. #1 is of two magnets moving together N to S. #2 is N to N. Having a couple steel washers between makes little difference. The important thing to notice is the density of the field lines in the middle where the magnets meet. Much, much denser with the N-N case. The greater the number of these field lines linking a test iron sample in the field, the greater the force exerted on the sample.
          Magnets in Motion
          No doubt Ufo will have a different take. More discussion can be found on page 9 of this thread.
          • My "take"...
            Hello Sputins, hello Bistander,
            Sorry about the crickets...am swamped.
            Sputins,
            That CRT test and his conclusions are right on.
            Repulsion fields compress each others, energy compressed.
            Now thinking of spinning fields... two like poles will spin opposite when facing each others (repulsion)....while, when poles are alike (attraction) and facing each others they will spin (both) in the same direction. From here we could realize how this whole thing works...
            For a long time we have used the Single B-Field convention, based on a single flow magnetic field...and this is wrong, North have a B-Field as well as South have another B-Field within the same magnet...or coil (electromagnet), and they originate at the very center of their embodiment.
            Putting a piece of iron in between, whether for attract or repulse, will just expand the Spatial Interaction magnetic center into the ferromagnetic material, but it would not change it in any other way.
            I read all this two pdf plus the other video...and yes, this guys I could say are "warm" into finding out the truth...but they are still bound to some old conventions which keeps them from reaching the whole thing.
            Bistabder,
            Yes, Repulsion is definitively a much more "dense" field...so, yes, I agree to that...
            So, my "take" was not that different so far huh?
              • Crt
                CRT screen image with opposing fields, flux lines contract into the magnetic conducting medium: https://www.youtube.com/watch?v=hvUiQ3IMHMU
                OK, to both Ufo and Sputins,
                I think I saw agreement between the three of us over the last several posts (an unlikely event) that the external magnetic field is greater when the two magnets are brought together with like poles facing, N-N. And a weaker external field when N-S.
                The CRT pattern shrinks when he moves to the N-N and expands with the N-S. Seems to me that the larger external magnetic field produces or has a smaller influence on the CRT. This is interesting because it supports my reasoning that the CRT doesn't display patterns representing magnetic fields, but patterns which opposes the magnetic fields placed on the outside of the screen.
                Just an observation and opinion.
                And I did not follow that fellow's talk about the coils. You say there's a pdf. Link?
                • Internal and External
                  Bi,
                  Not sure if there is a total agreement as yet, but almost... But at least we can discuss it like gentlemen.
                  The CRT pattern I think is displaying correctly. Not opposing the actual magnetic fields. - Here's why I say that:
                  The two like poles, N,N or S,S shows a weaker external field on the screen and an expanded magnetic field on the screen with N,S or S,N. - All true.
                  But the N,N or S,S is the set that has the concentrated magnetic flux density, ie put it on some metal and it "sticks" with two or three times the force than the N,S or S,N.
                  That is because the like pole's field is an internal concentration, or compression within the metallic lattice. While the the opposite poles have an expanded external magnetic field.
                  Proof is via a very simple experimental test: The opposite pole magnet set attract another magnet or steel washer from a further distance away than like pole set do. - By a reasonable amount of distance too. So it is an expanded magnetic field.
                  The like pole magnet set you have to bring them much closer in order to attract another magnet or steel washer. But when it does stick, it is very strong indeed.
                  So N,S or S,N produce an expansive external field and N,N or S,S produce a internal compressional field.
                  So we do seem to have one expansive direction and another contracting direction to magnetism.
                  It is actually fairly simple and it is now much more clear in my mind now! The penny has dropped for me i think.
                  You could do these experiments yourself...
                  When I have time I'll document this photographically & by measurement using scales to measure the pull force of each magnetic set and also an attraction distance test...
                  Here are the links I hinted at, found when you expand the description on the video:
                  http://www.hyiq.org/downloads/guidel...ng%20Coils.pdf
                  http://vixra.org/pdf/1204.0084v1.pdf
                    Bi,
                    Hi Sputins,
                    Thanks for the links. From the second pdf:
                    The power can be delivered with zero input current ...
                    I'd say that is pretty unlikely. Are you going attempt to replicate it?
                      Hi Sputins,
                      I have not tried the configuration shown within the said pdf as yet, but I have been playing around with some microwave oven transfomer (MOT) cores and rewinding them to suit.
                      I'm not after OU as such but for use with a particular application I have in mind.
                      • Hey Sputins, my pleasure.
                        Take a look at Ken's Book page I brought up below...and before as well...
                        From the right image (repulsion under iron dust) He writes:
                        "Far right are two likewise spin fields causing deflection; this is mirror membrane Ether deflection, this is
                        literally extremely high-pressure space
                        • Crt...
                          • highly pressured space
                            • Reality & truth
                              The thing here is so simple...so much SIMPLICITY (like Feynman said on that video...)...and ALL is blocking US ALL from understanding and reaching the pure white light...is this darn old "classic theories" about magnetism...otherwise the entire world would be making their own energy anywhere...
                              Hi Ufo,
                              Or, if you consider the facts, "classic theories" are valid, then your statement looks like this:
                              The thing here is so simple...so much SIMPLICITY ...and ALL is blocking US ALL from understanding and reaching the pure white light...is this darn old "reality" about magnetism...otherwise the entire world would be making their own energy anywhere...
                              Or:
                              The thing here is so simple...so much SIMPLICITY ...and ALL is blocking US ALL from understanding and reaching the pure white light...is this darn old "truth" about magnetism...otherwise the entire world would be making their own energy anywhere...
                              • Simplicity...blocked for 200 plus years
                                Hi Ufo,
                                Or, if you consider the facts, "classic theories" are valid...
                                But they are not valid, not to the real magnetic Field, they could be "valid" for a theoretical, mathematical formula which is only true within that wrong model of a dynamic field under arrest and rusted out by iron particles sprinkled all around it...and the completely non sense Single Flow Theory only from North to South...
                                Then the way to look at Induced EMF is -of course- also wrong...deriving from this twisted theoretical model based on "Imaginary Lines of Force"...
                                Lorentz concluded that magnetic fields are not rotational, nor divergent...and man, was he wrong about this...but of course...he was paid to do so.
                                To keep believing all this was and still is fine, perfect and "valid" keeps blocking you from seeing the simplicity of the real thing.
                                That simple!
                                Time will tell...soon.
