Originally posted by Ben2503
If we were in a stage of Higher Civilization scientific levels...where we all have recognized the Aether back again as the main force that creates and moves everything at universal scale...then I could explain that difference easily...but I will try in the best of my ability without perturbing other closed minds...by keeping it all still in a "Theory"...
Say that every time we create a Permanent Magnet by dumping a fast and high DC-Coil electrification to a ferromagnetic mass...we are not just "aligning" straight all particles into microscopic domains within that object that run from end to end without any recognition of domain walls typical explanation from old concepts...But instead all we are doing is opening a permanent Aether gate that concentrates right at the center plane of that volume...to create both known polarized and spatial ends...and vualá we have a Magnet.
Then we could conclude that an Electromagnet is just a Permanent Magnet in a starting process... where that "Aether Gate" is just a "momentary" one, because we have not provided the required energy dump to open it permanently...and it is dependent upon the fluctuations of our source feeding that coil...for example, if it was an AC Source, the sine wave +/0/- fluctuations will cause gate to open-close-revert...if it was a pulsed DC +/0/+...then open-Close deal...or if just a straight, linear DC...that does not reach the top values to fully open it...resuming that in all three cases of electromagnets, the gates would be very different than the one formed permanently on a magnet. Therefore, none of their projecting fields would be the same.
However, an electromagnet has properties that a permanent magnet could never do, just because its permanently situation...
But then again...that was just "Theorizing" ....
