Hi Ufo,
first I'd like to confirm If I'm visualizing the same magnetic field ken wheeler portrays in his book is the same as yours..
as you can see here, in your model posted by melonhead, you have only portrayed the inner part of ken's graphic of the magnetic field.. and as I see it (and understood it) you missed the part of "magnetism Forms closed Loop upon themselves" meaning if the "Dielectric Inertial Plane" as ken termed it (or simply the bloch region) is large enough you would have 2 spheres separated by that bloch region and would have a magnetic field geometry other than that of the Iron filing method (no closed loop)..
the iron filing method only got skinny because the iron was attracted, but that doesn't mean that is the actual field of the magnet..
its more stretched outward.. it has appeared like that because magnetic flux can be "guided" and the original magnetic field is not as what the "Iron filing" method has been showing..
I have worked, experimented and played with magnets with varying strength and I should know how to visualize the field not the same as is exactly as the iron filings show, but that doesn't mean the experiment was BS.
If you and ken and other think that what we see from the Iron filing method magnetic field geometry is what we visualize it as it is portrayed by the filings, you're mistaken..
but.
what we think you are visualizing in the ferro+light+magnetism, and are trying to reinstate from our minds are a mistake
here is a page in ken's book..
he states that light is being "displaced" by the magnetism.
but can the light actually be "displaced" or "Bent" by magnetism?..
I saw this video, https://www.youtube.com/watch?v=iY7hsXxbb0Q .. and read the comments where the inventor clearly states the Fact of what is truly happening..
If you guys are portraying the magnetic field in a "Bigger picture" including the light, then that is where the problem arises..
the bloch region indeed can be clearly depicted by that experiment but that's because the Ferro fluid is just attracted to both the north and south pole and causes a "Voidance"(got that term from ken
) of ferro fluid in the bloch region because of the attraction of magnetic north and south poles of the magnet in which ken also claims to be none existent (attraction)..
I have read his book before and I have read it again for the sake of this discussion to be sure I'm not misinterpreting anything. I do not agree with how he redefines "linear" into "radial" and "radial" into "spatial" and "counter spatial" there are some parts that I agree with (like gravity) and parts that I don't simply because I have other references that makes much more sense...
I have watched your videos and find it fascinating even though ken tries to Redefine "Magnetism" he still uses the "Lines of force" and unfortunately looks like he is contrary to your video.
but.
) of ferro fluid in the bloch region because of the attraction of magnetic north and south poles of the magnet in which ken also claims to be none existent (attraction)..I have read his book before and I have read it again for the sake of this discussion to be sure I'm not misinterpreting anything. I do not agree with how he redefines "linear" into "radial" and "radial" into "spatial" and "counter spatial" there are some parts that I agree with (like gravity) and parts that I don't simply because I have other references that makes much more sense...
) for the last two centuries with the development of the CRT...
