im jsut gonna double post here. youve not shown a vortex. you have not prove the concept of a vortex. there is no vortex in that video. you got it? now my point is that its not real.. your just, well.. i dont know. theres no such thing as a vortex and you dont know how a magnet works. like the claim you made that its a vortex. a vortex is a concept
ENLIGHTENED MAGNETISM (The Full Proof of Ken Wheeler's Theories)
Mhd
Originally posted by Ufopolitics View PostHello to All,
[VIDEO]https://www.youtube.com/watch?v=65SaRqdcdng[/VIDEO]
The set up is very simple...a glass container, a strip of copper surrounding the inner mid section and connected to positive. The Electrode was a brass rod connected to negative.
The reason why I chose to connect the electric field developing inside electrolyte to be that way is simple...a Magnet Vortex is Centrifugal, meaning it evolves from center to outer space...so I wanted to reproduce the E-Field that same way in order not to be opposed which case could mess up reading in directions of vortexes for each polarization. So, if Electrode is at very center of container, electrons will travel outwards (centrifugal as well) towards the positive closed copper plate.
The main chemical to add to water is the Potassium Hydroxide (1 Tablespoon). However, the only available concentrated drain cleaner I found had also Sodium Hydroxide (kind of a salt, but very caustic)...but it worked out just fine.
WARNING: PLEASE DO NOT HANDLE THIS ELECTROLYTE WITHOUT RUBBER GLOVES SPECIFICALLY DESIGNED TO WORK WITH THIS TYPE OF CHEMICALS!!
This chemicals will eat your skin, making it first very soapy like...as it will damage any plastics or electronics like a Camera.
As you could realize...non of this additives to water is Ferromagnetic, therefore, there is absolutely no magnetic influence to any of the observed floating/moving/spinning particles, which majority are debris from reactions to the copper strip plate catalyzed by the E-Field (Electron Bombardment) action.
I believe spinning direction is clearly observed for each polarization....I used an HD Cam...and tried that all the video formatting process did not affect viewing details in high quality.
I am not that happy with illumination though...I wanted to be able to observe bubbles much brighter...and you noticed when I am moving a front light trying to...
Original tests supposed to have all power connecting metals to be 100% Stainless Steel, I did not had those at the moment...so debris was created with copper. And instead of a strip...it was a whole stainless bowl as container and positive conductor...but then camera could only have a top view, which is not what I wanted.
Also, 12 Volts is the recommended voltage...
I hope you enjoy seeing a Vortex on a Magnet...since Lorentz disregarded this possibility many years ago, since it does conflict with his mathematics...However, Vortex is there...and clear.
Ufopolitics"Doesn't matter how many times you kick the coyote in the head, it's still gonna eat chickens". - EPD
Really big magnetic field
Hi Ufo,
Did you notice this?The images of magnetic fields are particularly interesting to me. I don't see a vortex and do not see the field behavior at the equator that you claim (ie. dielectric plane).Originally posted by Franco malgarini
WRT the swirling liquid in your video: Have you considered it is due to the currents flowing in the stationary magnetic field?
Nice research.
Hello Bistander,Originally posted by bistander View PostHi Ufo,
You will not see a Vortex in a Stationary picture...ever.
Like I have shown on the Magnetism Particle Dynamics video...the Higher Pressure Lines traveling from N to S and from S to N are located in the Outer "Shell" of Magnetic Field...It is also shown on Ken's Book...understand that up to here?
Well, if you cover up the Magnetic Field with ferromagnetic Filings/Powder, in the immediate space where it is located...like a piece of paper on top of magnet...then this particles will actually Stick to this outer shell, freezing, pausing any vortexing activity...As well as blocking Visibility of the Internal Structure of Field, where the Mid Pressures which are the ones who defines the Equator or Inertial Dielectric Plane would be completely occluded by ferromagnetic filings.
Can you visualize/understand that part so far?.
Could You visualize a 3D Layer over a 3D Shaped Object?...Then Imagine the whole Field as that object...imagine the field does have "internal components" defining its inner moving parts/vortexes...while having an outer 3D Layer where the HP lines Fluctuate/Travel...Now dust it up with ferromagnetics...like spray painting the "Invisible Man"...now what do you see?
If You paint with a solid color paint (like the iron particles are, very solid) the outer 3D Layer of Field....you will never, ever see its internal components.
I do not think so...WRT the swirling liquid in your video: Have you considered it is due to the currents flowing in the stationary magnetic field?
Why currents flowing through any kind of static, rigid shape object... will ever cause the liquid (plus debris) to generate such high speed turbulence?
I believe we could even set inside there a Turbine Propeller...static...with the most aerodynamic fins design ever conceived/constructed....and still...there will be no turbulence created.
That is the reason why I tested a piece of iron cylinder with the same exact shape and mass...but non magnetized...nothing happens...Calm.
On another question to you...Why does the direction of Turbulence changes when I flipped Magnet?...If that "Static Field" is so Symmetric, and so evenly distributed straight lines from N>S...then why fluid vortex reverse directions so radically?
Nice research.
UfopoliticsLast edited by Ufopolitics; 04-26-2016, 02:03 PM.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Liquid armature
I was referring to currents or moving charges in the liquid solution. Like a motor with a liquid armature.Originally posted by Ufopolitics View PostWhy currents flowing through any kind of static, rigid shape object... will ever cause the liquid (plus debris) to generate such high speed turbulence?
Originally posted by bistander View PostI was referring to currents or moving charges in the liquid solution. Like a motor with a liquid armature.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
The field lines defining the structure of the magnetic field are similar to those of a simple bar magnet, as illustrated in the following figure.Originally posted by bistander View PostThe images of magnetic fields are particularly interesting to me.
Its rotation winds up the magnetic field into a large rotating spiral, known as the Parker spiral, named after the scientist who first described it.Originally posted by bistander View PostI don't see a vortex ...
Al
TinManPower doing similar MHD...
Bob Smith brought this link to my YT Chanel...
[VIDEO]https://www.youtube.com/watch?v=-37Ecjd7FQQ&feature=youtu.be[/VIDEO]
magnetic vortex using full current loop anode
Video Description:
Published on Jul 20, 2014
In this test,i am using a full current loop anode.this will give an even flow of current to the magnet through the full 360*.The whole thread can be found in the link below,As you will see,there is much heated debate going on about the magnetic vortex theory.The work belong's to a member by the name TheoriaApophasis. I am mearly doing some reserch to see if there is any truth to the theory. So far,all my results say that the PM is what is producing the spin-but more test to come.
UfopoliticsPrinciples for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
A 200 + Years Arrest...
[IMG]
[/IMG]
Imagine an invisible Swiss watch, the finest ever built...a perfect machine, accurate movements, lot of components constantly moving...However, by being invisible, we could only feel it to the touch...but we can not see it...
So, some bright minds decide to dump some colored liquid concrete inside its machinery and outer embodiment...and yes, now we see it!...but only its outer cover...and it stop functioning...
That is exactly what we have done to the Magnetic Field for more than 200 years...
Is it that hard to understand?Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Earth's magnetic field
Hi al,
Yes, I've seen the bar magnet-Earth example many times.
This applies to the Sun with its Solar wind. I do not think it applies to the Earth's magnetic field. However the Earth's magnetic field is distorted by the Solar wind, obviously.
Existing model is not wrong
I guess it is hard for me to understand how something (our existing model) you say is "wrong" has worked so well and been so useful to mankind for the past couple of centuries. I am not saying that existing model is 100% complete and accurate, but it is far from being proven wrong and it is the most useful tool we have for this field of science and engineering at the moment. May there be more to it? Hidden surprises which enable better understanding, use and machines? I hope so. But I do not see anything which proves existing theory wrong.Originally posted by Ufopolitics View Post
As always, you're entitled to your opinion; I'm entitled to my opinion. No need for name calling. Just proceed with your proof. Thank you.
The wrong Model
It is exactly that way...Like you've said...it is not 100% complete and accurate.Originally posted by bistander View PostI guess it is hard for me to understand how something (our existing model) you say is "wrong" has worked so well and been so useful to mankind for the past couple of centuries. I am not saying that existing model is 100% complete and accurate, but it is far from being proven wrong and it is the most useful tool we have for this field of science and engineering at the moment. May there be more to it? Hidden surprises which enable better understanding, use and machines? I hope so. But I do not see anything which proves existing theory wrong.
The existing Iron Chained Model does give us an Outer Look of the Magnetic Field...but lacks to:
1-Show Field Vortex dynamics.
2-Show Field inner components.
There are more...but let's see just these two for now.
Out of those two "hidden and locked by iron" properties of magnetic fields...I will affirm that the worst one to be ignored is number one...the Spiraling/Vortex Properties.
The Magnetic Field could have been much more useful to mankind...than just the use we have been giving...due to this chained model as a guideline.
I could also say that the Gas and Diesel Engines have been very useful to mankind right?...They have transported mankind all over the planet...given us all kind of motoring power, tooling, home, industry...etc,etc
However, the Internal Combustion Engines are about 20-40% efficient?(Gas is 20%, Diesel is about 40%)
For God sake!...that is a very low efficiency!!Most internal combustion engines are incredibly inefficient at turning fuel burned into usable energy. The efficiency by which they do so is measured in terms of "thermal efficiency", and most gasoline combustion engines average around 20 percent thermal efficiency.Apr 14, 2014
So, in conclusion...we have been running all this time...on a 20% efficient ICE...
And so we have been using maybe only around 20% from Magnetic Fields full capacity, due to this wrong Iron Chained Model.
Of course I do have them...I said it before.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
So what? The magnetic field is just an interim step, or conversion, in our ultimate electromechanical energy conversion machinery (motors and generators). And the electric to mechanical and mechanical to electric machine conversions are very efficient; on the order of 95 to 98% for higher power levels. I do not understand why you compare that to 20% fuel burners.Originally posted by Ufopolitics View PostAnd so we have been using maybe only around 20% from Magnetic Fields full capacity, due to this wrong Iron Chained Model.
If you cut the losses in half for a 96% efficient 100kW electric generator, you save 2.08kW. If you cut the losses in half for a 20% 100kW gas engine, you save 200kW. You want to improve the energy consumption, maybe you should look at the real waste, not the electric machinery.
This is a perfect example of how we could just be so conformed (abide, obey) to such "solution" to A very clever Problem...Originally posted by bistander View PostB field is vertical. Your "disk" is liquid. The result is a force, F, as seen in Fig. 1, rotating the liquid disk around the shaft.
I left the link in native language.
The Fleming Right and Left Rules...are just a REFERENCE METHOD to obtain results on one variable, knowing the other two...
But it completely lacks to give us THE REAL EXPLANATION as to WHY this takes place like it does.
And here is when no one could be able to explain the reason why of these Three Dimensional exchange of forces based on the three axis or three fingers.
I guess it would be a point where this 3 fingers/axis will not be even "applicable"...then what do we do?
This example above is just one way of many we have been "moving ahead" in evolution, thinking we did find the answer through a Reference Method, a "Patch"...but not having the right and real explanation(s).
Getting back to your example...yes, that could be a possibilityMaybe the ONLY REAL EXPLANATION...would be that the B Field is nothing more than the center Bisector of a Spiral Vortex of Force my friend.
UfopoliticsLast edited by Ufopolitics; 04-26-2016, 06:54 PM.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
