counterspace and a flawed conventional premise
You're talking about people looking at conventional theories that have their own foundation based on flawed fundamentals. Basic equations for work, etc. work just fine for most of what people need to calculate and because they do work for most practical things, it gives a very false illusion that they are somehow correct - that is a common human trait, but it is psychologically defective at face value.
mgh (mass x gravity x height) is used to determine the potential energy in an object of a certain weight at a certain height. In the popular conventional model, the context that is used it to show how much potential energy is claimed to be stored in the object as it was lifted to that height. Because this equation does indeed properly show how much energy will be demonstrated by the object once it is released back to the ground in heat, etc. it is believed that potential was indeed stored in the object as it was lifted to that height. The equation gives the right answer as to how much energy will be dissipated on impact so the equation does work for practical use, but the premise for the belief of where that potential resides is completely false and this is an example that applies to those "brilliant minds" that have been over the conventional theories you're talking about.
100% of all the energy used to lift the object is 100% gone at the peak of the lift and is dissipated right back to the environment. Nothing is stored in the object and the what the input work did was create a new potential difference between the object and the ground. When the object is released, energy will be dissipated when the object hits the ground. None of that potential came from the energy input, it came from gravity. How can you store potential energy when you just used it all up when lifting the object? You can't - and the premise that is broken, which needs to be FIXED is exactly what is explained above. 1 unit of energy in the lift and we get 1 unit of energy as a freebie from gravitational potential and it is indisputably measurable as a total of 2 units of work and we input 1.
The Einsteinian garbage paradigm wants to make the energy and potential energy intrinsic to the object and magically storing potential energy in an object when potential energy cannot be stored to begin with shows that the "brilliant" minds reviewing the conventional theories are the real crackpots who believe in magically storing potential and disbelieving that gravity is a source of energy. Conventional theory falls flat on its face and does not explain where the energy comes from when the object is dropped. Again, it did not come from lifting the object because that energy was used up to lift the object - common sense.
Sorry, but the conventional theories do not cut it and are wrong in their very foundation and what is being proposed to you does not make sense to you as you said because you are appear to be committed to the same flawed premise as these "brilliant minds".
Furthermore, you are simply unwilling or incapable of allowing yourself to listen to anything I have said and are only talking in circles. Counterspace is not an area void of the aether - we have already determined that Eric's use of counterspace does not mean that and I have already stated that I should refer to that as a void or as a true vacuum, but not counterspace even though it is the inverse of space, literally.
Your multiple bulletpoints show that you have taken what I have said and simply made it mean what you want it to mean disregarding everything said about it thus far making it look like what I have defined is counterspace when it is not. Again, I have already conceded that my original use of counterspace terminology is not what Eric is using, you even pointed that out and your bulletpoints also throw out what Eric said counterspace is. This is looking more like planned confusion than a conversation.
I am always thrilled
He is a smart man
