Tesla Resonant Transformer
  • Tesla Resonant Transformer
    IT'S ONLY $7 SO GET A COPY TO HELP COVER ERIC'S TRAVEL COSTS TO DO THIS PRESENTATION!
    Crystal Radios are free energy devices because they don't need batteries. They are powered by the very AM radio waves that they're tuned in to. This is a profound concept, but has its limitations because by the time the energy transmitted in those radio waves are received by the crystal radio, there isn't much left. There is barely enough to just power the headset so you can listen to the station. Some people have lit LED lights with Crystal Radios but its not really anything to write home about.
    These AM radio waves are electromagnetic in nature and are known as Transverse Waves. These waves conform to the Inverse Square Law, which means that energy is diminished by the square of the distance. The further the waves are from the radio station, the less energy there is at the receiving end. So, if you wanted to power something significant at the receiving end, this is not the route you want to take.
    Nikola Tesla figured out a more fruitful path many years ago and the concept is very simple. Every AM radio station not only transmits Transverse Waves through the air, it transmits Longitudinal Waves through the Earth! What is significant about this ground transmission is that it does not conform to the Inverse Square Law. The energy between the AM station and the receiver for this ground transmission does not diminish by the square of the distance. That means that the energy in this ground transmission has almost no loss between the transmitter and receiver. Therefore, if you wanted to power something significant from an AM transmission, this IS the route you want to take.
    Get your copy now: Crystal Radio Initiative
    In addition to the ground transmission being nearly lossless, it is also faster than the electromagnetic waves sent through the air. The electromagnetic waves are moving just about at light speed so if the longitudinal ground transmission gets to the receiving end faster, what does that tell you? It is not subject to light speed limitations. It is not faster than the speed of light, it is instantaneous for all practical purposes and is therefore Extraluminal.
    To experience exactly what Tesla had his hands on, which obviously overturn the conventional apple cart, what you need is not just any Crystal Radio but a Tesla type Crystal Radio using a Tesla Resonant Transformer. It is similar to a regular Crystal Radio, but it does not have an antenna - that is all build into the coil and it connects to the Earth. It is also actually very simple in principle and you can figure out how to build your own real Tesla Resonant Transformer with nothing more than junior high school basic algebra.
    Months ago, we gave out a free video presentation by Eric Dollard called the Crystal Radio Initiative along with a free 300 page book with all the notes, schematics and discussions on this open source project - that book and video are now part of a new package that has a brand new presentation.
    Recently, Eric came here to Washington to work on some projects and to give a presentation teaching anyone how to calculate a real Tesla Resonant Transformer. And, you're going to learn it by the most authoritative expert in the world on the subject. It can be used for this Tesla Crystal Radio project, a Cosmic Induction Generator (another one of Eric's projects) or a multitude of other projects relating to the Tesla sciences. With one coil or a set of coils, you can do countless experiments just like what Eric has demonstrated over the last several decades.
    Aaron
      Crystal Radio Initaitive
      Thanks for your support!
      There are a few errors that I'm correcting now 31:40-34:49 and 44:09-45:36 and 54:09-56:03 - it's just been uploaded. Download the 2nd video again.
      Those coils are all dR-Greens!
      We will work on doing more of these classroom/tutorial styles. I'd like to have better lighting, etc... but at least it can be seen and is easy to follow. I'll see Eric again in 2 months - not sure if we'll have time to do much, but will plant the seed for another presentation on something. It might be the mag amp project.
        Tesla Resonant Transformer edit
        We have yet another edit of the 2nd video for Crystal Radio Initiative ready for download, which teaches you how to calculate a Tesla Resonant Transformer.
        This video is the one where Eric gives some coil calculation examples on the whiteboard.
        At 31:40 to 34:49 - the frequency is 570kc (kilocycles), which is 570,000. The formula showed 20 / square root of 0.57 * 10 ^3.
        Conventionally, the 0.57 would be multiplied by 10 ^3 first and then we would find the square root of that product.
        However, Eric has actually simplified it and we find the square root of 0.57 first and then we multiple that square root by 10 ^3 and that gives the right answer.
        So, the 0.57 under the square root sign is correct. However, the number x 10 to -2 power was incorrect and we corrected that.
        From 44:09 to 45:36, same thing is corrected.
        From 54:09 to 56:03, we originally thought that the number under the square root sign had the same issue, but the way Eric shows it is correct.
        The corrections in the video will be obvious when you watch it.
        You will then have the corrected version. We apologize for the inconvenience but want to make sure that the information is as accurate as possible.
        A & P
          Tesla Coil Quantum Entanglement.
          "I have defined in my Tesla Coil Quantum Entanglement proposal the concept that the Tesla Coil can be considered a macro sized quantum electron since its field can emulate the field structure of an electron. This can be achieved by carefully selecting the coil length to be the inverse of the height of the tesla structure divided by the square of 2 times the atomic fine structure constant. Thus, as a quantum particle, its identical twin at an arbitrary distance communicates phase change relative to each other instantly. The external fields in space become irrelevant. The action between the coils is non-local as a result and also form the requirement for what I have termed in my papers online as the electrogravitational force of action. The external fields are indeed a local action. I think you may have misunderstood my understanding of quantum entanglement".
          Respectfully, Jerry E. Bayles
            New "Tesla Coil" Itation from Bayles.
            "The ordinary EM wave has the E field and B field 90 degrees to each other spatially and the direction of propagation. The E and B fields are in phase with practically zero degrees difference time-wise in free space. As a result, the power is multiplied by the cosine of the angle of zero degrees which is unity. Thus the power is real and can interact and heat up nearby organic material such as evidenced by the microwave oven.The tesla coil does not have the same field. The E and B fields are shifted time-wise by 90 degrees and if an organic object is in that field, the net power transferred is close to zero. Tesla demonstrated many times how the field of his coils allowed the 'power' of thousands of REACTIVE watts to flow over his body without harming him. The power is equal to the cosine of 90 degrees times the power apparent which is zero real power. Pure reactive power does not do work.Yet, it is demonstrated that there IS an external field that interacts with another like Tesla coil at some arbitrary point distant. Shifting the phase in the receiver Tesla coil by 90 degrees allows for REAL power to be demonstrated once again at the receiver end, allowing for the lighting of lamps and running motors, etc. Further, since the field operates as if it were a standing wave in free space, the REAL and observable field velocity is zero. IT IS NOT AN ORDINARY EM WAVE! IT IS A STANDING WAVE IN FREE SPACE! However, it also acts as if it forms its own boundary waveguide. Its group velocity is almost zero but its phase velocity is almost infinite. The phase wave is frequency dependent for distance while the group wave is amplitude dependent for detection purposes. Thus the true Tesla coil field acts as if it has both a zero velocity and also an infinite velocity. This satisfies the nature of a quantum particle. It is phase change between the points of interaction that is important for communication, not the amplitude".
            Respectfully, Jerry E. Bayles (Quantum Mechanic)
            Electrogravity
              Can anyone help explain to me how one shifts the receiver coil phase by 90 degrees?
              "Shifting the phase in the receiver Tesla coil by 90 degrees allows for REAL power to be demonstrated once again at the receiver end, allowing for the lighting of lamps and running motors, etc".
                if you have resonance, can you move the physical location by 1/4 wavelength ?
                I also remember some thing in tesla's notes about the driven coil being driven 4 times faster than resonance
                and if it mattes, this view makes sense,
                time, electric fields, and magnetic fields are all at 90 degrees to each other
                  Where was it written?
                    Here's an answer I got from "Seet Hing Long" of the Bayles group:
                    "Shifting one antenna by 90 degrees will change the signal, and that's a very basic rule of radio. Placing R and T at 90* out of phase with each other attenuates the signal received, this has been known since the early days of valve radio. "A standing wave in free space" describes any resonant modulated energy that has zero phase motion. "Zero phase motion" is a situation that is Most Desired when building an oscillator, but the noise has got to go somewhere.
                    You cannot have power transmission in this manner because the distance dependency of your phase wave relies on exact distance from the transmitter. Your idea of free power generation and having a Tesla coil do it is also way too dangerous, in that it does heat up flesh very easily, functioning at 2MHz or so.
                    I have to ask that you prove yourself with math that says a Tesla coil is a superluminal device that can cause QE. I can prove they're c-limited devices, any ARRL Radio Amateur's Handbook (misnomer, it's a doorstop) can tell you that. I have both a 1947 and a 1976, and the Antenna Handbook. I've assembled coils, and phasing them always changes the signal, no matter if it's an antenna system or a Tesla coil. These devices are limited by c".
                      I also purchased this presentation and would like to say THANK YOU!! All the confusion in the forum is totally cleared up. I also really appreciate the classroom style..well worth it IMHO
                        Jerry Bayles.
                        The quote from Jerry came from an email news letter you can sign up to receive here:
                        (subscribe at: [email protected]
                          CRI type coils construction pictures
                          1
                          2
                          3
                          4
                          5
                          6
                          7
                          8
                          9
                          10
                          11
                          12
                          13
                          14
                          15
                          • #14
                            16
                            17
                            18
                            19
                            20
                            21
                            22
                            23
                            24
                            25
                            26
                            27
                            28
                            29
                            30
                            • #15
                              31
                              32
                              33
