Motor Generators
Adjustable bearings for generator shafts needing high tolerance values such as the brake rotor of a car. In fact the wind turbine builders are using car rotors and tapered bearings to insure air gaps are stable while being very tiny
A twin tapered bearing for a rotor shaft makes the side to side adjustment possible
Actually 900 MORE feet of wire is 30% more than the 3,000 feet I have now. I am going to use bobbins that are longer so that the back end of the coil is FLUSH with the plastic when the coil slides into the coil holder. I won't need those spacers I show in the video. These bobbins will be approximately 1" longer than current bobbins. Hopefully 30% more wire will give me a solid increase in voltage.Originally posted by BroMikey View Post
My original TEST coils were, I believe, three strands of #23, 1200 feet in length and the coil output at 2800 rpm was 130+ volts. I wanted to drop that down to around 110-120 volts and cutting 200 feet off the wire dropped the voltage down to what I wanted. But that was with iron cores, not permalloy. So adding 300 feet to permalloy coils may not give me anywhere near what I need. I'm going to live with whatever I get and go ahead and put the machine all together. I just want to be DONE with this project.“Advances are made by answering questions. Discoveries are made by questioning answers.”
What kind or cores do you have up your sleeve this time??600ma per strand or from 3 parallel strands? So that would be 200ma per strand
Cool video
I'm going to stick with the permalloy cores. They don't heat up during long runs, and I need that, even if they don't put out as much power. You can always get additional power simply by adding more coils or another rotor and more coils. If that's what has to happen, then that's what we will do.“Advances are made by answering questions. Discoveries are made by questioning answers.”
I saw your video where speed up came at 1400 rpm, do you think going back to a 12 strand might find a better amp output? you know 3 strands of 600ft X 2 in parallel? Or something like that. It would be nice to double the amps since you might only need half the wire at 2800rpm. But that is your department. Any combinations in mind?Originally posted by Turion View Post
Interesting video from tinman admitting physics can be broken.
Magnetic neutralization = 7th grade science experiment.
bistander says he did it and it didn't work, so I'm lying about magnetic neutralization. Señor Eunuco needs remedial classes
Some people need to go back to the 7th grade.
Wire just came in. And my buddy has core material done for me. Just have to get to Sacramento to pick it up. Today is shot and two doctor appointments tomorrow, so probably not until Saturday.
Edit: REMEMBER, I spend HOURS perfectly adjusting the opposition magnets because you can bring them in too far, and then THEY are a problem.
Because I have coils on BOTH sides of my rotor, I have opposition magnets on both sides of my rotor.Last edited by Turion; 02-03-2022, 11:06 PM.“Advances are made by answering questions. Discoveries are made by questioning answers.”
- Likes 1
Hi there peoples
I been looking at the coil info of this 66 amp regenX video. That is not a continuous drain value but is a dc pulsed figure. Like semiconductor data sheets will give a pulsed amp max of 200a and the transistor leg measures a whopping thickness of a tooth pick
We all know a 66 amp continuous flow of current takes a large conductor the size of your smallest finger. This is for those not skilled in the art of DC pulse engineering
My buddy is dropping off the core material for the coils tomorrow, so no more excuses for delays I guess. Now it’s on me to get the two coils put together and tested. Have not felt much like doing anything the last week.
