Motor Generators
Originally posted by Turion View PostThe other day I said my machinist ran a 120 volt 1.8 amp AC motor from the wall at 1600 RPM and then ran it on two coils from the generator at 1700 RPM. Today he disconnected the MY1020 DC razor scooter motor and tried running that AC motor connected to the wall to turn the generator.
Seems like you told us one time way back it took 100+ amps to start up
your first rig. Which would translate into 36V TIMES 100 amps = up
in smoke.
So yeah those tiny induction motors don't have the balls.
Thanks 4 the update/letting us know on progress.
Now-a-days CANCELLATION implementation has lowered that some.
The scooter motors are for pulling varying loads at all different speeds
without damage. A universal brush style induction motor would work,
but you would still have to vary the voltage. Oh and they eat power.
Probably cost 500w vs a pmm at 300w.
experiencia
HiOriginally posted by Turion View PostThe other day I said my machinist ran a 120 volt 1.8 amp AC motor from the wall at 1600 RPM and then ran it on two coils from the generator at 1700 RPM. Today he disconnected the MY1020 DC razor scooter motor and tried running that AC motor connected to the wall to turn the generator. Of course it didn’t have enough get up and go. Since it’s a 1.8 amp motor, I didn’t expect that it would. But he’s trying all kinds of stuff. He may make something happen to get a self runner before I get down there or maybe not. Either way I can prove what I say about the generator is true. The 6th is rapidly approaching. I can hardly wait.
I comment on my experience:
I have a 500 watt car alternator.
the minimum to charge the battery must work at 2000 rpm.
well I link it to an AC motor ... 120 volts, 1.5 -1.8 amp at 1800 rpm.
when operating with the alternator without energizing the inductor coil of the alternator, the engine speed did not decrease, but when energizing the alternator coil, and starting to generate, as is logical, it decreased the revolutions to about 1600 to 1500 rpm, giving a voltage the alternator from 9 to the output, of course not used to charge the battery.
To the motor of changing of pulley by a greater one to give greater speed to the alternator, improvement but it did not reach the optimum speed, the voltage of the alternator was like of about 10 volts.
Well I said to myself, I look for a motor with more speed, if there are any but they consume some current.
120 v, 13 amperes 3000 rpm
220v 6.5 amperes 3000 rpm
For my purposes, it did not help me the maximum that seeks consumption of about 2 amps.
but I have a cd engine. I can power from 12 to 130 volts, 7099 rpm, 17 amp.
As you can see the speed is high, but that will also depend on the load that can perform well.
I tested a disc with magnets 12 magnets of 20 mm x 20 mm. , with a voltage of 60 volts. consumed 2 amp. at 2500 rpm, of course the disc is not very heavy. They were tests that I did to see what this engine can offer me, is that I plan to use it as a test in the generator proposed by Turion.
I believe that if the generator project is done well, that:
1.- the coil accelerates under load
2.- the appropriate revolutions proposed
3.-Cancellation of core and magnet drag
The weight of the disk with the magnets would be only
remembering turion once you said that you had a generator configuration that worked for you at less speed I don't know if it was 1800 or 1400 rpm there the engine can work well that your assistant is testing
greetings and happy new yearAttached FilesLast edited by alexelectric; 01-01-2020, 05:05 AM.
alexelectric,
My first version of the coil contained three strands each 1,000 feet long. Wound in parallel and connected in parallel. With those coils loaded at 2800+ RPM the motor would speed up about 100 RPM per coil.
With a 12 strand coil, each strand 250 feet long, three groups of four strands connected in series, the motor would speed up under load at 1140 RPM and possibly LOWER. It wasn't tested at lower RPM, so I don't know.
If you wind a 24 strand coil or a 30 strand coil, you might get the RPM's even lower, if that is your goal.
turion:
This configuration is the one I made with the coil, and if it accelerates under load at the speed you are commenting, it is fine, since I want a generator that does not have so many revolutions, we already know that several factors influence, to remember among them:
number of magnets
coil configuration
As I said in the next few weeks I will have the generator ready to test and perform the tests, it depends on the results I advance on other ideas that I have.
thanks for your orientations
Backyard tinkering powering a treadmill motor.
The young man is quite practical in his thinking. This is my
kind of fun. However when using a 130v input you need other
components to stabilize or lower to 120v so looping takes
some doing.
[VIDEO]https://www.youtube.com/watch?v=ASywVBU0ZwE[/VIDEO]
happy new year friends
if so, as you say, they are tests that will be performed, and then adapts, alternatives are sought, for example I will also use the ac motor, and I will also test with the engine that has turion
The important thing is that I do it, try.
In these projects it takes time to complete them, hours of work, resources, etc. but it is a satisfaction to achieve them.
thank you for your comment
turion comment:
Aaron has invited me to present my machine at the conference in July
Congratulations and much success, what a great satisfaction to demonstrate your project, and demonstrate your achievements.
We remain attentive to your comments and contributions that help us understand and move forward in the projects
thanks for your contributions
Old Patent
I was looking through some of my old stuff and I finally ran across that old patent that shows magnetic neutralization in use. Here is the patent info and an actual picture from the patent of how he used magnetic neutralization many, many moons ago:
MAGNETIC BATTERY
WO9414237
1994-06-23
Inventor(s): WERJEFELT BERTIL R L [US]; YONOVER ROBERT N
Classification: - international: H02P9/04; H02P9/04; (IPC1-7): H02P9/04 - European: H02P9/04
Also published as:AU5736994
Inventors: WERJEFELT, Bertil, R., L.; (US). // YONOVER, Robert, N.; (US).
If you look at the "C" shape on the left, you will see a coil in the center of it. A magnet is rotated between the two ends of the "C" shape. At the exact moment the magnet is aligned in attraction, look at the unit on the right where the North is aligned with the North and the South with the South. This is what gave me the idea of having magnets aligned in repulsion when the rotor magnet is attracted to the core. It was this drawing, NOT Mad Max's stuff that led me to do the research I did. Although what Max showed reinforced the idea.
Who cares and why?
Happy New Year all..
Hello bi,
I agree that there is no need for insults and other disruptive activvity on this forum. My hope is that we can all work together respectfully. No one owes anybody anything here. If something is posted, it is there for all to be benefitted. No one needs to prove anything. If someone can't reproduce it, they can post their findings, b 's not proof of anything. The devil's in the details, as they say. Nothing can be proved with posts, theories, or videos on a forum. It is a waste of time arguing any of that. All we can do is share our experience and if others can gain from that and reproduce the benefits for themselves, then great! If not, c'est la vie.
I have a good feeling about this coming year. We should be able to see more good things this year...after all it is 2020.😁
Good luck all and take care,
Bob
Lenz avoidance generator
I have no idea if this even works, so I hesitate to post the link here, but there is more than one way to avoid Lenz. Outrun it as my generator does or kill it when it is just a baby before it has time to grow up and become a pain in the butt as they claim to do on this model. In theory, it should work.
Both take advantage of the fact that Lenz is a reaction and NOT a law. It CAN be avoided. You just have to get up off the couch and go build something before you see it. Do you imagine investors would sink hundreds of thousands of development dollars int something that has NO CHANCE of working?
Oops! Forgot to post the link
By the way, ever hear of the “Law of Gravity”? But planes still fly don’t they?Last edited by Turion; 01-04-2020, 07:53 PM.
