Originally posted by BroMikey
Motor Generators
In this working shooting, the transition to self-propelled mode was demonstrated, directly. But the system stopped after a short period of time. The author (my reader) was the question of how to fix it. A more detailed analysis in his system was the voltage drop in the closed circuit of the motor and generator. What was given, the recommendation to connect the motor through the inverter from the battery. Generator to charge the battery, through an adjustable charger. No longer had contact with the author of the device. The system is calculated correctly, the voltage drop is solved by the buffer source, from the buffer source and the excess energy that accumulate on it is removed.Last edited by Rakarskiy; 12-23-2019, 07:12 AM.
Pendulum in the Rain
Hey guys,
Here's a video of my pendulum system charging a battery while being run on solar panels (two 12v, 15W panels in series) in the rain:
The amp draw doesn't even show on the meter (which is the wrong size, but I burned up my last two 500mA meters). The last time I checked it, it was .08v higher after about an hour of charging. That's on the same 500CCA (105Ah) battery that I have shown which had been sitting over night (because I modified the core of the coil that runs the pendulum by adding a small magnet on top of the core so that it will repulse the pendulum arm magnet so that it will not sit in front of the points magnet if it stops swinging. Being stopped at that point closes the points, which sends a constant current and burns up the coil. Been there, done that.)
Hey, concerning Dave's stuff: Dave doesn't fake anything. His generator is for real and the concept is simple, but you have to spend the time and money to make it big enough, close tolerance and efficient. Pay attention to the details that Dave gives you. Everything matters.
OU is simple, but most guys aren't building things that are efficient. If you throw something together from a few boards you found in the backyard, a beer can (empty, of course), and an old washing machine motor, you probably won't get it. The worst component is the lead acid battery with its high impedance, especially when small and in poor condition. JB always said to use big battery banks...ya gotta get the impedance down. Get away from batteries as much as possible and use batteries that are low impedance when you need them.
OK...that's my 2 cents. Take care and happy holidays to all,
Bob
Obsolete
Bro,
I am responding to you on your thread rather than bi’s thread as I told him I wouldn’t be back there until after the Jan 6th meeting.
Out of date, outmoded, and (since I am the only one who has one) definitely OUT OF USE. Or do you know of one in operation anywhere that I don’t know about?
As to money, I realize you were kidding about that. I have probably around $30,000 invested in the generator. The owner of the independent testing lab, who has seen it run, has offered to give me $100,000 for more research the day the gen self runs. He believes this tech need to go forward. And getting it to self run may be a bit of a trick, but we will get there in the next couple weeks. The output is definitely already there. Now if only bistander would make such an offer, since he KNOWS it is not possible.
Anyway, have another project that is going to require the same capital outlay but over a much shorter time frame so the next year is going to be very interesting.
Dang, I didn't know you had THAT much money was going into this project.
I guess I learn something everyday. Can't wait to see the old clunker run,
looped and tucked away on the mantle. It should at least do what all relics
do? Stir up a good conversation?
Bi is no fun, he doesn't even know what we are talking about like most.
Just another fairy tale perpetual motion machine teacher says can't work.
There goes the university jersey if yuppies admit.
Have a holly jolly Turion and wait till after to loosen up a bit, that is the
way to win the war.
May God richly Bless you.
Pendulum w/ Higher Frequency
Hello again and Happy Holidays,
I have simplified the system some and will post the circuit later (forgot to draw it up for posting). But this short video shows a faster frequency obtained by placing a rubber band on either side of the pendulum arm to catch the momentum and use it to reverse the direction at a higher rate of speed. Works great. I replaced the caps with just a 1000uF cap which, because of the faster action, lowered the amp draw and raised the charging considerably. In less than 30 mins. the battery was over 1320v which was its highest to that point due to rain. In a few more minutes it was at 1326v before I shut it down for the day.
Video (11 sec.): https://youtu.be/OY80qbehHNU
Because I have previously run larger caps on this machine, the points have become pitted and will stick at times. I am testing different size caps now to see the biggest cap that will not damage the points. The higher frequency allows for good results without the large caps, so I am hoping that I can determine the best size in short order.
The smaller the cap, the higher the open voltage of the solar stays. So, a smaller cap hits with higher voltage. Soon I will be using two 24v solar panels in series to give me an open voltage that I think will be around 80v. Raising the frequency even more will probably help too.
Alright, that's it for now.
Take care,
Bob
I haven't followed the thread much, so I don't know all the history you guys have with Bistander, but maybe we shouldn't be so hard on him. I can only think of 2 reasons he is saying the things that he does: 1) He has been too indoctrinated by classical electrical theory, or 2) He is a paid misinformation plant to misdirect people and keep them spinning their wheels until they get discouraged.
If he is #1, then he doesn't have free energy and never will. This is sad and maybe we should have some compassion for him.
If he is #2, then he has decided to flush his own kids and grandkids down the toilet with the rest of humanity as big industry continues to pollute the planet and hold everybody hostage economically. This is even more sad. To work against the health and happiness of your own species for money is very short-sighted and lacks virtue.
Hopefully, there is some other option that I haven't thought of that has some redeeming value in his actions.
I don't know him and I have nothing against him, but if he doesn't hold with the possibility of OU, his presence on this forum seems odd.
Take care all,
Bob
Looks like about 250hz, you could over charge the battery fastOriginally posted by BobFrench View PostHello again and Happy Holidays,
Take care,
Bob
if left unattended.
On the subject of bisexual or byproduct as some have called him I
think both #1 and #2 apply. Especially #2 his favorite number. But we
won't get into that.
Openly Bi and proud of it. Go figure.
Now back to testing. Glad you are getting some good results. Do you
think that gravity or the weight of the arm and magnet helps the
process? You know as compared or VS. an osc to cap dump?
That is what you have there. It's a slow cap dump circuit.
Who cares and why?
Hi Bob,Originally posted by BobFrench View PostI haven't followed the thread much, so I don't know all the history you guys have with Bistander, but maybe we shouldn't be so hard on him. I can only think of 2 reasons he is saying the things that he does: 1) He has been too indoctrinated by classical electrical theory, or 2) He is a paid misinformation plant to misdirect people and keep them spinning their wheels until they get discouraged.
Take care all,
Bob
I still don't see why it matters. Why can't members just discuss the topic, the science, the energy goals and methods? When I ask for proof of a claim, or evidence, or offer a solution based on the work of Faraday, why must a member ask for my identity, or belittle and insult me? Why can't the member just answer my question and support his statement or claim?
This is the renewable energy forum on this board, not a social club.
Regards and happy New year.
When
Hi Turion,
What happens when you fail to loop it and cannot measure more real power output than input power? Then the comments I made look like fact instead of name-calling.
But I knew your claim was false when I made those statements, so I never was name-calling, just stating fact.
Just using talking points like the media does today and ignore facts.
The facts are more important than talking points. Facts bring down
the house of cards or talking points, same thing.
All generators today loaded draw more current exponentially as the load
increases. On the other hand our coils do not affect the drive current.
Generator coils that deliver real power without increasing drive input
are a phenomena conventional science is unaware of because they have
deliberately turned a blind eye.
It is a very simple idea but the indoctrination (Religion) of University
minds has caused a block in some cases. In other case these so called
professors of scientific method can do nothing outside govt curriculum.
They may find (And have) contradictory evidence that makes the books
obsolete but would not dare to jeopardize their careers.
Political correctness and dumbing down thru the use of cliche's, trigger
words and practically story rhyme scenarios doubled down on out of 6th
grade reading books. All higher learning at the college level is held to
the roots of 6th grade science. If any higher learning is found to be in
conflict with these root experiments, it is thrown out.
Therefore no progress can be made thru scientific method as all roads
lead to the foundational teaching in early school.
In conventional science all generator coils slug down the drive input
causing a proportionate increase as generated power climbs.
Using N. Tesla's 2nd coil findings (That were buried and rejected) we see
that a generator can offer large amounts of utility power without the
old relationships of increased HP (Horse Power). This finding among
others would have lead to development of high COP (Coefficient or Power)
on the order of limitless but was not a cost effective strategy for the
businessmen of the day. It was at this point their media machine was
used to cripple Tesla's influence in offering any additional findings. Total
scientific stagnation has persisted ever since.
Everything taught in schools is based on lies and built on them. The good
things learned in schools is a beginning only. 6th grade up to 10th or 12th
grade are the cutoff where we become aware of many scientist findings
as far back as the 16 hundreds. This is fine but only the starting point.
In many cases college level instructors are nothing more than parrot's
boardering on babbling idiots.
Energy will be free. Generators setup with coils that do not change drive
input is only one very simple choice for average guys like me. There
are many examples of different system already doing this.
The reason we discuss this particular approach to extra energy producing
systems is to get our foot in the doorway far beyond the closed doors of the
blind guides standing in our way.Last edited by BroMikey; 12-29-2019, 09:17 AM.
