Motor Generators
    Hi bistander,
    Any alternator in terms of inducing EMF is overunity, since to this day we do not know whether the magnetic field is spent to induce EMF or not. I will simply quote what I wrote to one of my opponents, a physicist from Ukraine:
    ...mechanical rotation of the rotor with permanent magnets or electromagnets is a condition for the constant magnetic excitation field to move in the stator core. When it rotates, the orientation of the Anapol foci changes (2, 4, etc. paired closed flows), and the lines of force simply physically cannot cut the conductor, they are always redistributed in the rotor and stator core. Rotation of this field is possible without mechanical rotation according to the algorithm for switching electromagnets. But there is a mandatory condition that, by the way, is implemented in any anchor of a DC motor. That is why Figuera combined everything with one another.
    That is why this simple engineering solution is not applied is simply incomprehensible. The mechanical force of rotation of the rotor is a condition, although very expensive, and not a type of energy for transformation.
    Regarding Figuer, Holcomb and others, I have long ago described the algorithm, even made calculations for the manufacture of this or that device. The question of whether to believe or not is a matter of choice, I do not insist. The Creator gave everyone the right to choose. One of my friends is also a stubborn admirer of the foundations of traditional electrodynamics, when he saw a drop in excitation current on his own devices when connecting the load to the phase wires and repeated the tests several times, now he just builds his own. I went further and calculated the most optimal design for a solid-state alternator. Now not only synchronous but also symmetrical.
    Electromagnetic generator, without rotation of the magnetic rotor in self-propelled mode. | Patreon
    Dear Rakarskiy,
    You say
    "The question of whether to believe or not is a matter of choice, I do not insist."
    Yes. One can believe, or not. Their choice. But there is no choice for truth.
    And "Any alternator in terms of inducing EMF is overunity"
    is false. It does not produce more energy than what is input. Regardless of what you believe.
    • Dear bistander,
      Don't be so generalised. Distinguish all kinds of phenomena at mechanical generation of EMF (E). The mechanical power [P=Fv], applied to rotate a magnetic rotor with excited constant magnetic flux [Bm], is not converted into electric power [W=IU]. The conversion takes place according to the EMF (E) formula (of electromagnetic induction [curl E = -dBm/dt], where [Bm] is the magnetic induction of the external field). The magnetic field in the phase loop [Bi], arises from another phenomenon of electromagnetic induction (Maxwell's formula for Ampere's law [curl H = dD/dt + J], which I have expressed more precisely [curl Bi = -dE/dt]). The force of mechanical rotation is a condition, not a transformation. It is possible to rotate the field without mechanical force, it is enough to rotate not the collector in the brushes and the armature, but the brushes around the collector with a fixed armature , inserted stator with phase windings.
      Electromagnetic generator OverUnity
      Facebook
      When you rotate the brushes around the armature collector, which is inserted into the stator with slots and windings, you get a similar pattern of magnetic field movement as when the magnetic rotor is mechanically rotated. (illustration from my edition Motionless ALTERNATOR)
      Click image for larger version  Name:	86215320.jpg Views:	0 Size:	116.0 KB ID:	515663
        Dear bistander,
        Don't be so generalised. Distinguish all kinds of phenomena at mechanical generation of EMF. The mechanical power P=Fv, applied to rotate a magnetic rotor with excited constant magnetic flux Bm, is not converted into electric power W=IU. The conversion takes place according to the EMF (E) formula (of electromagnetic induction curl E = -dBm/dt, where Bm is the magnetic induction of the external field). The magnetic field in the phase loop Bi, arises from another phenomenon of electromagnetic induction (Maxwell's formula for Ampere's law curl H = dD/dt + J, which I have expressed more precisely curl Bi = -dE/dt). The force of mechanical rotation is a condition, not a transformation. It is possible to rotate the field without mechanical force, it is enough to rotate not the collector in the brushes and the armature, but the brushes around the collector with a fixed armature , inserted stator with phase windings.
        Facebook
        Rakarskiy,
        What you describe amounts to a transformer. Real power output will never exceed power input.
        Please show the world proof. Sorry, but nobody can. Because these OU/FE claims are false.
        • Getting intercurrent mutual induction is also very possible if you do the electronic controller wrong. But if you put the correct armature from a DC motor, and organise the rotation of the brushes around the collector, you will get just the generation. My friend was also puzzled why at mechanical commutation generation, but having already replaced by transistors got mutual induction. I had to explain the difference in excitations. This question can be checked only practically.
          • I am definitely not going to prove anything to anyone, convince or dissuade anyone. The question is why? I have given enough information!
            If someone doesn't want to think, then I made a project with calculations (core, windings, the simplest electronic controller), which you can make yourself. You can change it at your own discretion. Making your own core will cost you a decent amount of money.
            Any synchronous generator based on closed magnetic systems works on this principle.
            Click image for larger version  Name:	512287900.jpg Views:	0 Size:	63.8 KB ID:	515667
            Click image for larger version  Name:	831566774.jpg Views:	0 Size:	232.5 KB ID:	515668
            Another drawing of mine that I gave to explain the magnetic system of Robert Holcomb's generator back in 2021.
            Click image for larger version  Name:	182282156.jpg Views:	0 Size:	242.0 KB ID:	515669
            Everyone gets out of being fooled on their own. Moreover, the general education system of teaching electromagnetism to the average student will not help you with this.
            A very clear example of an anapole moment, when the core closes a magnetic closed flux in itself, when this core is broken, an EMF impulse will arise at the ends of the conductor. Edward Leedskalnin - Magnetic-Current | PDF | Nature
            "Magnetic Current/Magnetic Keeper" by Edward Leedskalnin.
            This is exactly the thesis that I gave in my research, explaining the actions of the anapole moment when it changes. The invention of the electromagnetic generator | Patreon
            Edward Leedskalnin Perpetual Motion | Magnetic Currents & Polarity Change
            When changing the magnetic intensity H (magnetic flux B ) in the focus, the electric field vector E appears . When superimposed on the model of a closed magnetic circuit, in the focus of which a conductor is laid, we have the induction of an electric field limited by the volume of this focus. Thus, if simply in the hole of a closed ferromagnetic core, in which the field moment of magnetic intensity H changes , an electric moment is formed in the focus of this core. If there is a conductor in the focus of the magnetic circuit, a difference in electric potentials appears on it. Which is actually a contactless method of electromagnetic induction.
            Click image for larger version  Name:	2023-08-12_092437.jpg Views:	0 Size:	11.2 KB ID:	515670
            The American version of this action is called differently and is veiled a little differently, but it is the same phenomenon
            Dynamic toroidal dipole - Wikipedia
            Anapolle moment in American physics terminology Toroidal moment - Wikipedia
            Magnetic toroidal moment and its relation to the magnetoelectric effect
            The presence of a magnetic toroidic dipole moment T in condensed matter is due to the presence of a magnetoelectric effect: Application of a magnetic field H in the plane of a toroidal solenoid leads via the Lorentz force to an accumulation of current loops and thus to an electric polarization perpendicular to both T and H. The resulting polarization has the form Pi = εijkTjHk (with ε being the Levi-Civita symbol). The resulting magnetoelectric tensor describing the cross-correlated response is thus antisymmetric.
              Very interesting but I see nothing to support your claim "Any alternator in terms of inducing EMF is overunity". Please point out specifically where any of this shows real power output exceeding power input (overunity).
              Thanks.
              • I've always wondered if it's innate or feigned. By the way, all the adherents of the Commission on Combating Pseudoscience had a clear instruction to ignore me and silence me.
                Excitation is very important for generator operation, as the setting of the excitation current controls the final voltage spread and therefore the reactive power that the generator can supply to the grid (active power is determined by the turbine speed and its torque). For turbine generators, the excitation power is approximately 0.5% to 3% of the generator output.
                  Power factor correction is not OU.
                  BTW, I support free speech, worldwide, including you. But you are wrong about some basics and about your method.
                  Please point out specifically where any of this shows real power output exceeding power input (overunity). Thanks.
                  • I don't think you know anything about power generation. Excitation is the creation of an excitation magnetic field. And the magnetic field induces EMF. It is explicitly stated that excitation for a turbine generator is 3% of the output power of the generation. It is not difficult to calculate the efficiency, which is 3333%.
                    And the steam turbine drive is a condition for rotation of the excitation electromagnet in the stator of the turbine generator. We provide rotation of the excitation field in the stator without mechanical rotation we get direct efficiency.
                    Just about the method of generation in such an oscillator without phyical rotation is my publication.
                      https://www.patreon.com/user/shop/mo...970?u=75063604
                      Dear Rakarskiy,
                      You have been misinformed. The power required for excitation is just a portion of the total input power. In the case of an alternator using permanent magnet field, excitation power is zero. Calculate efficiency for that.
                      "active power is determined by the turbine speed and its torque"
                      Above is a quote from yesterday's post by you. It is in the same paragraph which told 3% excitation.
                      A generator, or alternator, is a device which converts mechanical energy into electrical energy. Any excitation, or control, power is considered as portion of the total power input, or most often simply routed from the device's output, thereby disappearing from the classic efficiency formula, efficiency = real power output / input power. Look it up.
                      • Also, Rakarskiy,
                        You said
                        "We provide rotation of the excitation field in the stator without mechanical rotation we get direct efficiency."
                        Doesn't work, does it? All you get is a transformer with sucky efficiency.
                        • Dear bistander ,
                          You either deliberately ignore or your professional level does not allow you to make judgments.
                          The production of electricity through the rotation of a magnetic rotor in the stator of a mechanical alternator is not the transformation of mechanical power [P=Fv] into electrical power [W=IU].
                          This is the greatest disenformation of people on the planet, in which you are participating intentionally or through stupidity.
                          The production of electricity consists of two parts, electromagnetic induction [E=-dФ/dt] -generation, in the phase conductor when the magnetic field changes, and ensuring the rotation of the excited constant magnetic flux [Ф] in the magnetic system of closed alternator circuits. Thus, simply replacing the physical rotation of the anchor magnetic field with the switchable rotation of the magnetic field in the armature inserted into the stator with phase windings, we exclude the expensive method of physical rotation of the field.
                          Let them wipe their asses with what physicists and marauders of people have taken for a constant.
                          It works very well if everything is done correctly, at least to provide mechanical switching of brushes and collector lamellas when the brushes rotate around the non-rotating anchor. Now to make a consumer machine, an engineering approach is needed.
                            Dear bistander ,
                            Why is there no proof?
                            You posted this:
                            It means that turbine's torque and speed (the product of which is mechanical power) is converted into the alternator's electrical output power. The magnetic excitation just facilitates this conversion process.
                            Wake up.
                            • Do you have different components for torque and mechanical power? You surprise me even more.
                              The frequency of generation depends on the speed of rotation of the two-pole rotor of the turbine generator. Does it matter if it is rotated mechanically or by switching armature windings in the manner of a DC motor armature.
                                What?
                                I learned torque and mechanical power from conventional physics. Torque is the rotational analogue to force. The S.I. unit is the newton meter abbreviation Nm assigned as a vector. Torque is a necessary component of rotational power, which is found by the product of torque times angular velocity. Angular velocity carries units of radians per second, r/s. The product of torque times angular velocity yields the mechanical power with units of watts.
                                Basic stuff. No?
