If the outside ring of magnets were going by the CENTER of the coils, then the machine would have to be bigger in all directions in order to hold the coils. That's the issue. Right now the coil holder can be made out of a specific size sheet of plastic cut into four pieces. Bigger pieces of plastic (+3" taller and +3" wider) would be needed, and that would be much more expensive.
As to what you said about the speed of the outside magnets, A single magnet on the outside moves FASTER past a specific point, but 20 magnets on the outside go past a specific point the same number of times in one rotation as 20 magnets on the inside circle. They just cover MORE DISTANCE in that rotation, so are moving FASTER. Yes, the outside magnets, because they travel faster would give you speed up under load at a lower speed, but my machine can still reach that speed. That's not an issue. I HAVE posted videos of speed up under load. My FIRST one was over ten years ago. If people don't want to believe it's possible, they can build something and see for themselves. I'm not babysitting anyone. My cut up finger is healing. The one that is giving me problems is the one I broke from the drill flipping around. Testing my coil for output tomorrow. When that is done, I will be testing for what the speed up under load RPM is for this new coil material. When I find it, I will post a video of it.
