Magnet motor revelation
  • I tried Rue's method and used two magnets that I tested with my clamp on amp meter. They measured out within .01 of each other. I had a variation of 2.5 from the lowest reading to the highest reading. I checked all 11 magnets. It didn't help. I am having the same problem. With the two rotor magnets in one position they both go easiy back and forth through the magnetic gate with NO lock up. But spin the rotor 180 degrees, and now I have to force them through the gate. I don't get it. It's like my rotor is out of balance, but that isn't the case. I am really puzzled by this. Maybe the two magnets on the rotor are not exactly 180 degrees from each other. It is the only thing that makes sense to me, but I will sleep on it. Right now I see that as the only thing it COULD be.
    Edit: Duh. It is probably the STATORS that are not exactly 180 degrees apart. Oh it's always the little things that get ya!
    On another note, I have a couple ideas for ways to change this build and improve on it, but I am not going to post pictures and diagrams. I am going to BUILD the basic unit. Get it to balance. Then add more rotor magnets and get them to balance until I have the three pairs. Then add the ramps and test with them. If I get all that working THEN I might make a change and see if it works. If not, I will keep it to myself. If it works, THEN I will post it here. But I believe in getting the BASIC unit working. If you start making changes, and it doesn't work, how do you know it isn't working because of the changes you made? This is what we went through with all the Bedini stuff. John told people how to build and they used different wire and different transistors and then whined like babies because theirs didn't do what his did. Better to replicate EXACTLY and then if it doesn't work, you go back to the source of your information to find out WHY it didn't work like they said it would or what YOU might have done wrong. But you can't expect Mack to know why a design he had nothing to do with does not work if it ends up not working. I think we need a drawing that at least MOST agree represents the basic model, and then we should all build it. I am not sure we have one yet that most of us would agree on. But I will go back through the posts again.
      This is going to sound harsh maybe but when I watched your video's
      I expected more than what I saw. I expected something completely
      different. Oh by the way I got another piece done tonight right at the
      end of the day, you know how it is.
      Okay this is what I expected.
      I thought and it is only a thought, that when the two forces of attraction
      VS repulsion were set up to balance out that you wouldn't even know
      there were magnets there. I thought that I was suppose to work at this
      balancing act until the full traveled area of push would coincide with the
      full area arc on the pulling side til nothing can be felt when the rotor
      is turned. thus "no cogging" RESPECTFULLY SIR it looks like you have
      cogging.
      Can you understand my beginners view of the explanation given for
      zero cogging? Like I said I am a green horn when it comes to this stuff
      but doesn't that make any sense?
      Especially only using the 2 poles this zero cogging should be attainable.
      Here is what is on my mind. I made a stator ring 1" thick that is
      somewhere around 18" dia with a 12" hole for the rotor.
      The magnet need to be adjustable using identical parts and same screws
      to hold down with. The holders need to be slotted as well as being
      able to pivot.
      Find and document the repulsion side first. Take off the attraction
      side stator magnet. Using a pencil mark on the board the area arc
      and the relative strength on that arc if you can. Such as very strong
      starting here and weak way over there.
      Then remove the repulsion side stator magnet and repeat the same test
      on the attraction side. When you are done you will know where to move
      your stator magnets to balance your rig.
      Maybe this is what you have already done, I don't know.
      Maybe or maybe not, just my thoughts.
      My paint is about dry, gonna go admire my work, C-ya soon
      • Charly2 posted this diagram,http://www.energeticforum.com/attach...revelation-jpg
        Mack said,Charly2, yes that is what I described. Think bigger diameter & more side spacing between magnets.
        Hope that worked
        artv
        • G.o.e.s.
          Dear All.
          A fundamental part to the success or failure of this motor totally hinges on the right material used for the shunts.
          Any ordinary Steel used will get magnetised permanently !!
          I have obtained some G.O.E.S. ( Grain Oriented Electrical Steel ) from a local Transformer stamping business.
          But you could use some " I' s " from a MOV Transformer too.
          The above link shows how to neatly remove the top!
          I am working in a similar area ATM, I will be joining in soon once the Magnets have arrived from Germany.
          Cheers Grum.
          • food for thought
            we should also remember the part motion could play ...[gyroscopic]
            everything seems to change when in motion ?
            thx to JimBoot for the link.
            sorry for the perhaps off topic...but perhaps NOT ??
            Chet K
            BE that change !!
            • Originally posted by RAMSET View Post
              Chet K
              Hi Chet
              Good point because as we review Dave's rotor it can be seen that
              when he spins it fast the cogging does no appear to be noticeable.
              His rotor does not lurch in a cogging fashion by a visual judgement.
              So Dave must be very close to the proper alignment.
              This is a point I did not address in my earlier post on cogging.
              • I worked on the cogging on this all day and still cannot figure it out. I Tried SEVERAL different methods of determining where the 180 degree spot was on the rotor. They had all been pre drilled for mounting eight magnets at the machine shop, so I was pretty sure the holes in the rotor were correct, and as far as I can tell, they are. I measured hole to hole with callipers, and they were all equal. So it is the angle of my magnets or something else! I can get it pretty minimal, but I can't get it to go away. I even remounted my stators trying to make sure they are perfectly aligned. Wah, wah, wah.
                I'll get it. If there is one thing I am, it's persistent.
                I also built a second unit with the magnets flat on the rotor and the stator magnets angled. It has a sticky spot too. Minimal, like the other setup, but still there. This one performs better, but that is because the stator magnets are set at 45 degrees rather than 30 degrees like the other setup. more force pushing the magnets out of there. ZOOM!
                • Round Magnets
                  Originally posted by MadMack View Post
                  ...Ewizard, round magnets might not make a difference but I can't say. I always used square or rectangular magnets, much easier to work with...
                  Hi Dave,
                  Maybe it's not the angle of the rotor or stator magnets. Maybe the magnet shape is just too unforgiving for the strength of the magnets.
                  Randy
                  _
                  • Shape
                    That's a really good point Randy. I have some square ones with a hole in them, but they are ceramic. Will give them a try. Looks like I'll be ordering some neos. Carroll got his to balance with round magnets, but I believe he was at 20 degrees and I have tried 30 and 45. He was also using a smaller disk and MUCH smaller neos.
                    • Great thoughts thanks 4 sharing. I did another piece of the
                      puzzle tonight and painted it so the wood does not take on
                      water and change shape.
                      I did the base and the rotor. Now I have to install the main
                      bearing. This bearing has a thrust ball bearing on the bottom
                      as well. Then I need to do some magnet mounts all the same.
                      My magnets are square so maybe they will balance easier.
                      I want everyone to know that I have always wanted to make
                      a test motor like this but never had any direction to cause me
                      to know how to proceed.
                      Many thanks to all of you for each one's entry.
                      • Magnets
                        I spent two full days trying to get the thing to balance with those round neo magnets, and wasn't able to get it done. I think they are VERY unforgiving of even unmeasurable differences in construction. You better have the thing built at a machine shop to use them, because I put micrometers on everything and the farthest off I was on ANYTHING was .001. Suffice to say I am pretty much done with the ROUND neos.
                        I replaced them with rectangular magnets (Ceramic, but that's all I have until I get some in the mail) and it was fairly easy to get balanced. I will get even CLOSER when I tighten things up and spend some time with it, but for right now I am happy to see that it is possible. I was very frustrated. I'm wondering if the stronger the magnets you have the harder it becomes to balance. I'm going to order a couple different sizes to play with on this little rotor and see what happens.
                        "Theoretically" I should be able to put any two matching magnets on my rotors and get them to balance with the stator magnets through adjustments.
                        Anyway, here is the latest video:
                        Oops. In the video I said I got those at Radio Shack. Force of habit. Got these at Lowes.
                        • Woohoo
                          Thanks Dave,
                          I'm using basically the same setup with Lowe's ceramics like yours. I thought there was to be zero cogging to reach "balance". I balanced my setup but still had some cogging and re-set it again.
                          Now I have something to work with. The video helped me to see this.
                          Will post link here if I can upload it.
                          wantomake
                            I replaced them with rectangular magnets (Ceramic, but that's all I have until I get some in the mail) '''''''''''''''''''''''''''''''''''
                            Yes I was thinking that my ceramic motor magnets are 10X weaker than
                            my neos and what looks like cogging with neo's does not seem to look
                            like cogging with ceramic, but it is. It is just weaker so it just seems
                            better but like you say what about acceleration?
                            Great progress. Mack did say that square magnets are his choice.
                            Also I keep thinking about the mapping Howard J. did and how
                            complex his measurements were. Howy had visualization tools
                            no less. The reason I bring this up is the pole reversal that is going
                            on in these motors. As the magnets swing past one another many
                            field changes take place.
                            Mack said he thought of his magnets and their poles as they would
                            go past one another as getting stronger as the approach to the center
                            line (THE STRONGEST POINT) then diminishing or lowering in push or
                            pull.
                            Since attraction and repulsion are not equal, one being stronger, then
                            it also stands to reason that the field lines will be of a slightly different
                            shape.
                            This unequal set of forces might be balances in many ways.
                            For all practical purposes we can say 180 degrees across from the
                            attractive field is the repulsion but this is what we can not see.
                            We can not see that each magnet centerline may be off center by
                            several thousandths of an inch or mm.
                            This thought causes me to make my magnet holder adjustable in
                            both X & Y axes. The picture I have shown is only my first brain
                            storm and is rapidly evolving into a combination of threaded
                            adjusters.
                            Like I said I have wanted to do this one for years and years.
                            Now I can go ahead and finally scratch this itch.
                            Also on another design construction note. I am digging up my SS screws
                            that are non magnetic in case my build might throw off the forces using
                            iron screws.
                            The grain oriented metals for ramps is also very important.
                            • Dave,
                              I have some round magnets that are 1.5"x 1". Very strong but I have infinite adjustment on both my stator and rotor magnets as well as the stator itself and I was able to get it very close to no cogging but my rotor wobbles a little bit.I think that it is possible to do with round magnets but square ones are probably better.Will have to try some square neos.Am building a new rotor to try and get everything as close to perfect as possible.
                              Joe
                              • Ramps added
                                Here's just a little video of the way I did my ramps. You can buy that flat strap steel at Lowes. It comes in about 3 foot lengths. I cut my curved shape out of 3/4 plywood and the circle (if it was a circle) would be about 1 1/2 inches larger in diameter than my rotor---the next step may NOT work with regular 3/4 inch board because it will BREAK if you abuse it to much. Then I laid the piece of metal on the curve and hit it a few times in the middle. It actually curved TOO MUCH doing this, and I had to put it on the cement with the open part of the "C" shape down and tap it a few times to take some of the curve out of it.
                                I haven't worked on any fine adjustments yet, but I can SEE the magnets being pulled toward the stator by the ramp, so that is exciting. Just those ceramics don't have much "pull".
                                So now I am on to the most important part. With the setup I currently have I can adjust until my hair falls out and it will NEVER continue its rotation. Doesn't natter HOW MANY stators I put around that circle. This is where you need to dig into the book on magnetics and do some READING. My next step, while I wait for neos to come by winged messenger is to read that book several times, especially the parts that we were pointed to. They have to do with how to modify that ramp to get it to do what we want it to do.
                                Edit: Oops. Forgot to post the video!!
