It is absolutely Not your fault...at all.
Mack,
It is absolutely NOT Your fault that WE, all replicators on this Thread,(and any other around) have NOT come up as of now with EXACTLY the same spec set up as you have described in your first, second and third posts.
So far I have NOT seen ONE SINGLE identical replication based on your description...
I, include Myself, of course, within that group of members here that are NOT doing the supposed work.
Assuming that it "should" work with "similar" components...IS NOT the EXACT WAY.
I assumed that 1/4 cubes as long as they would be of N-52 would work...however, the pulling force from this magnets does NOT work the same way -in scale- as the geometry does.
It is NOT the same a magnet that can pull 20 pounds as one that can ONLY pulls 3.0 pounds...
You have rendered here a motor that has work for you with certain spec's...but the actual relationship based on required pulling force to be either scaled up or down has not been established as of now...and maybe you don't even know it yourself, just because if something WORKS for you a certain way...THEN, WHY IN THIS WORLD SHOULD WE CHANGE IT BEFORE MAKING WHAT WORKS TO PERFORM ??!!
I believe You should just IGNORE all comments from the stupid People...unfortunately this world is FULL OF THEM...a MAIN REASON WHY...we are ALL still dependent of OIL, GAS and Diesel Farting Machines!!
Until someone comes up with the IDENTICAL setup you have described here...and claims it don't work...ONLY THEN...We should pay attention to...BUT no comments Till WE ALL SEE IT ON A VIDEO...Period.
Otherwise is just PURE BS.
Kind Regards
Originally posted by MadMack
Mack,
Kind Regards
It would be brilliant if we could work out a kind of To Do list or Check List for the ramps to improve them faster, means what to do, if the rotor behaves like this or that for repulsion side and attraction side.
Excuse Me.
@ UFO
