Up date motor magnetic MadMack four pole version
Magnet motor revelation
That image is completely wrong.Originally posted by mkt3920 View PostThis picture was found online from 1949 Navy training manual on magnetism, and it shows the "ramp" (soft iron) to have south pole (inflowing) on bottom end and north pole (outflow) on top end, closest edge to magnet....and little/no fields on the side. Is this a correct representation of the polarities of a ramp next to a South facing Stator magnet? The earlier posts have me a little confused on this issue of induction. I also understand that the ramps induction could change with the influence of a close passing rotor magnet but trying to grasp just the stator and ramp.
Kent
First they are showing a full North to South flow...which never takes place like that...those are iron filings based theories, and that is wrong method to "see" magnets...and believe me...all this kind of images will do is confuse you even more...to a point you will never understand what would develop here very soon.
Where is the Domain Wall, Bloch Wall and low pressure flow from center of magnet towards both poles?...
nowhere.
Bad info, old info...trash, rubbish, garbage
My opinion
UfopoliticsLast edited by Ufopolitics; 09-11-2015, 10:36 PM.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
On a 12" diameter circle the circumference is 37.7" and this divided by 8 (magnet ever 45 degrees) equals 4.71", the curved distance between magnets. He describes the rotor length at 30 degrees (37.7 / 12) would equal 3.14".end of rampthe space between "end of stator-beginning of next ramp" as Mack refers on above (complete) paragraph in red
mkt,
Is there a typo above in the underlined word rotor and you meant ramp...correct?
Originally posted by MadMack View Post
...so as a rotor magnet passes a stator magnet you need a space before the beginning of the next ramp. The distance of this space varies with magnet strengths but a rule of thumb is a minimum of 1.5 to 2 times the gap between the rotor magnet and the ramp, at its widest point. In my 8 pole motor, with magnets every 45 degrees, the ramp length was about 30 degrees. Yours may be a little different.Originally posted by mkt3920 View PostI do not quite understand this length measurement in degrees so calculated this to see what the possibilities were. If you look at this as a ramp coming off the 0 degree mark (pointed toward 45 degrees) then its length would be about 3.14", less 1/2 the width of the magnet if it touched the side. If you look at this as a ramp coming from the 45 degree mark pointing back toward the 0 degree then this ramp length could be (4.71" - 3.14") 1.57".
Anyone else looked at this?
KentIf we have "the space" then the gap between rotor magnet and ramp at its widest point is 1.57" divided by either 1.5 or 2 as minimum distance. From here we can know approximately the ramp curvature...couldn't we?(Space calculation): a rule of thumb is a minimum of 1.5 to 2 times the gap between the rotor magnet and the ramp, at its widest point
But this could not be that simple...I believe the ramps not necessarily follow a perfect circumference along rotation line...to then "smoothly bend over to a perfect calculated gap...life would be too good always...but, unfortunately it is not like that...
Read the latest Mack's post last part:
So, if we are just considering x,y diagrams so far to render ramps (2D)...stop, and think 3D...or using the vertical or z axis...and all kind of curves that could generate between all three of their planes ...
UfopoliticsPrinciples for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Originally posted by lorinrandone View PostUp date motor magnetic MadMack four pole version
https://www.youtube.com/channel/UCJG...yR589k-CeBYetwPrinciples for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
UFO,
Correct on the typo, it should read "ramp length" and I agree that it is not the actual length but rather a point where the ramp comes to. Just trying to effectively use the info given.
Also, thanks for your comment on magnetic flow diagram.
Kent
Thanks UFO, I know how I sound. Redundant questioningOriginally posted by Ufopolitics View PostExcellent Mikey!!
Yes, the Attraction Forces PULL not Push...so we need to pull opposite to our Push Vector Forces...
Yes the Red "Shunts"...
Take care
I got
to be sure on the foundation of the terminology and you are the man
who has it all. OH, Except for the rest of the ramp connection to the magnet.
Come on UFO think
Me, I'm still doin my A,B C's
Oh Mack there you go again keeping us on the straight and narrowOriginally posted by MadMack View PostUfo,
YES! Almost 100%.
The 2 pole test rig, I refrain from calling it a motor, is to TEST with.
Mack
Okay so X, Y and Z axes on the magnet to Ramp connection
Mack, Mack............Humm..............
Originally posted by Stealth View PostIn all my trials I have discovered what I think is the ideal shape for the ramp. I call it a butterfly pattern. Observe the shape of a butterflies wings. I have also found it is easier to use both wing shapes, one on top, one on bottom to easily balance the rotor. Good Luck. stealth
Great pointer Stealth
that pattern is like UFO's Ramps.
I think it will turn out great, Dave will be on top the entire time.Originally posted by MadMack View PostDave I am so sorry for your loss, and happy to hear that everyone is safe.
I hope this setback will turn into a blessing for you somehow.
Mack
You can't keep a good man down. May THE LORD bless you Dave
and I pray for your success in your recovery.
Michael Rowland (Central Kansas USA)Last edited by BroMikey; 09-12-2015, 04:06 AM.
Tonight I used a weak/cheap compass to look at the magnetic field of simulated ramp. I used 4 "long" (.5x.5x1) magnets joined end to end for simulated stator magnet and the 12" steel shaft as ramp. I learned a lot from watching the compass needle as I moved it around the ramp. I had the ramp about 1"-2" from south end of magnet, at an angle. (And later touching the side) As the compass traveled in pattern similar to rotor magnet it pointed to end of shaft then straight toward side of shaft until about 2/3rds down shaft then it pointed toward the stator magnet end.
It was easy to see the magnetic field with the compass and it was similar to the drawing I posted but, as stated by UFOpolitics, there was not a change of the magnetic pole at the end of the shaft near the magnet. Polarity stayed the same. The ramp bent the field on the entrance side and left the exit side of magnet as it was. The field at the entrance end of shaft did seem stronger than the field along shaft's side as I moved compass down (parallel to) the shaft.
I realize the rotor magnet will also induce the ramp but I wanted to see the base field first.
Kent
Originally posted by Stealth View PostAfter many years experimenting''''''''''''''''''''''''''''''''''''' '''''''''''''''''''''''''''''''''''''''''''''''
LIKE THIS STEALTH???? Correct this diagram please.
YES! Almost 100%.
Mack
Hi all
I am not sure if anyone knows this video and if it is real,but it looks like.
Here is a thread through the MadMack motor. The video presented has nothing to do with the system proposed by Mad.Originally posted by forelle View PostHi all
https://www.youtube.com/watch?v=PIvZJ9xGutI
