Data
OK, I made two videos. You'll just have to put up with the noise of my setup because it is going to be noisy until I get some connectors. I am spending money on other things I need more.
The first shows my generator running with all 12 coils in place. None of them are connected to loads and none of them are shorted out
Coil testing baseline setup - YouTube
Stats are as follows
RPM 1900
Voltage 15.32
Amp draw .67 (I had the clamp on meter on AC by accident, so this is not accurate...you will see that in the video if you look close. Fortunately, I also shot a picture of the front panel meter on the power supply, which showed DC output as 5.85 amps)
Then I tore the sucker apart and ran the motor with the same output from the power supply, and here is what my meter showed, WITH NO COILS NEAR THE ROTOR.
Coil testing baseline setup 2 - YouTube
RPM 1998
Voltage 15.35
Amp draw .62 (Again, a wrong setting on the meter. Sorry about that. I ran the motor a while ago to see what the panel meter on the front of the power supply showed, and it was 3.67 amps with NO COILS near the rotors)
So basically it cost me 2.18 amps or 33.5 watts to run 12 coils or .18 amps per coil. Each coil slowed the motor by 8 RPM.
I am trying to give accurate data here Farmhand, and this shows that there IS a slowing down of the motor in the presence of the coils, which my smaller setup with just a couple coils did not show. This means you were correct and I was WRONG. It won't be the last time.
What remains to be seen is how much will putting a single coil under load speed the motor up? These are different coils than on my small rig, so I have no idea what the answer will be, but that is what I will be testing first thing tomorrow.
I will test one air core coil, and then I will break the machine back down and put in one of the specially treated coils Matt and I have been working on and see how it does. I want to see the output of each and see how each affects the speed of the rotor and the amp draw of the motor.
I'll be looking for a speed up under load of at LEAST 8 RPM per coil. I am trying to give accurate data guys, and I apologize for the screw up with the meter. I KNOW the motor runs on 5 amps. It always has. It pulls more on start up, but it runs on about 5.5 amps with all the coils. Why I didn't catch the error sooner I do not know. No excuse.
RPM 1900
Voltage 15.32
RPM 1998
Voltage 15.35
