High field around transformer - Energy extraction
  • High field around transformer - Energy extraction
    Hi folks, I've recently seen a video that I want to share.
    It's about an interesting effect that happens when you put a closed loop wire around a microwave transformer on idle while the output is in shortcircuit.
    If you measure the amps in that closed loop of wire you'll read a high amount of amperes.
    This effect is quite strange because has some interesting effects:
    • This effect is additive (more wires more amperage)
    • Ohmic law doesn't apply (more lenght wire = more resistance =more amps)
    Have anyone experienced something similar or have any explanation?
    "A knot cannot be undone, without knowing the way it was made" Aristotle
    Can you send us the link to the video?
      Of course, here you've:
      https://www.youtube.com/watch?v=EDH7s3IMTtE
      Tell me your opinions. It's in non-english language but you can understand what the guy is doing by simply watching at the video.
        already a thread
        Magnethos,
        There's already a thread started about Barbosa and Leal. That is the setup some are using.
        But please do experiment anything you think may be an area to check out. Just thought you would be interested in that thread.
        Happy experimenting,
        wantomake
          Originally posted by wantomake View Post
          Magnethos,
          wantomake
          Thank you very much wantomake for the information. I knew about the thread about Barbosa and Leal (I haven't read it all the thread).
          Apart from Barbosa, this is also very related to Don Smith work IMO (in my oppinion).
          Smith said several times that there was a field that was emitter from transformers that was wasted. The video is a prove that there is an energy field that is wasted and ignored in conventional systems and it could be possible to extract energy from it.
            agree
            Hey Mag,
            Yes I do see what you mean.
            I've been studying transformers, flux, electrostatic, electromagnetic and etc for the last while. Currently trying to test a triflilar coil with a generator (old car) as the core. The coil has a large aluminum capacitor wrapped around it. Want to influence the capacitor with the coils electromagnetic flux and cause a transformer action on field coils of generator.
            Yes the primary test shows the capacitor does get residual energy from the coil. But not on the field coils.
            But need more test.
            Hope this is in same area as the transformer thought pattern.
            wantomake
              microwave oven transformers leak a huge amount of magnetic energy
              more than anything else I have tested,
              but then again I did not test a welding setup
                Great topic, Magnethos.
                I wonder if an Avramenko plug could be connected to the shorted coil, where the two ends come together. If the shorted secondary does not affect the primary, perhaps an AV plug could be used to draw charge from the coil, which could be dumped into a capacitor bank.
                Bob
                  Bob
                  Hello Bob, anyone can also visit the overunity thread opened about the same field:
                  -----> Massive Amperage From OUTSIDE The Transformer Core Lamination's.
                  The AV plug can be connected to the output of the MOT (not shorted). I think it would be better to connect the AV plug to the output of a neon transformer (it's high voltage, high frequency). BUT ONLY TO ONE WIRE IN THE OUTPUT (I think it would be the possitive wire).
                  About connecting to the shorted output, the other day I watched a video about a russian using the shorted output of the MOT to extract energy connecting one end to the shorted output. He added 2 diodes to the shorted output and he connected one end between the 2 diodes.
                    If someone understand Russian language let me know here or with a private message.
                    I've found a video where a man uses this effect to extract energy from it.
