Single Wire Power - A Search for Ambient Power to do Wwork
  • Interesting. Here's another plasma treatment link:
    Is hi voltage dielectricity (HV without amperage) not also quite capable of producing plasma? I see the alternative energy link here, and the potential for producing clean water that comes with it.
    Here's another talk on use of plasma-treated water to replace pesticides:
    The problem is that this comes up against the powerful chemical companies.
    I also see the possibility for harnessing plasma for single wire power transfer.
    Bob
    • Duncan
      Amen brother! Preaching to the choir . Your line of reasoning around water has me thinking about the proliferation of towers and the frequencies they broadcast. I've been aware of Emoto's work for years, but somehow never put the two together.
      I believe that a body in a weakened state -energetically or otherwise - will be more susceptible to pathogenic assaults. Perhaps drinking properly structured and charged water is one answer.
      I also believe that the single wire power effect described at the start of this thread is a kind of energy transmission which can have helpful effects on the body. I also come back to resonance as an important factor in this SWP process. I'll get more into this in the coming days if time permits. It's been a very busy month for me.
      Bob
      • Originally posted by Bob Smith View Post
        Bob
        really amazing videos, Thanks for sharing
        • I ran into the following while researching barium ferrite cores and magnets vis-a-vis Floyd Sweet's VTA. It led me into barium titanate (BaTiO3) and lead titanate (PbTiO3) also which have some very interesting properties regarding electricity.
          But this post is about titanium dioxide (TiO2) which will purify air and water and not be consumed in the process. Simply speaking, UV light stimulates the TiO2 which emits an electron and leaves a "hole" in the TiO2 which is then filled from the environment to self replenish the TiO2. The freed electron reacts with organic matter in the air or water being purified and this reaction oxidizes the organic matter rendering it harmless. Apparently, it requires no outside power source other than the UV light that can be obtained from the sun so it could work wonders in 3rd world countries.
          Virgin Breeze VI FAQ - Mold Mildew Odor Removal Virgin Islands | Virgin Breeze VI | Caribbean
          • Originally posted by thx1138 View Post
            The subject can start out simple and end up complex.
            when niobium is doped into the abbsorbing material such as Tio2 further kinetic enhancement is possible. It is hoped that large scale system could clean nasty pollutants from water.
            • One Man's 'plasma' another's dielectric breakdown ?
              Just how good is water as an insulator ? Very good it seems (as long as the water is clean and pure) its given a relative dielectric strength somewhere around about 80. (no wonder those Tesla 'coilers' have used water bucket capacitors.)
              As I watched these video's you kindly posted I was reminded of this clip from some time ago
              I guess what puzzled and intrigued me at the time is the response is far from linear and like UFO politics I'm aware things asymmetric have great potential still for some reason I didn't tarry or dwell on the issue but its always nagged at the back of my mind.
              anyway following your clips I revisited this and started varying plate sizes separation distances and plotting graphs.
              Keeping these year two electrical principles in mind .. A capacitor causes a 90 deg phase shift
              AC Capacitor Circuits : Reactance And Impedance -- Capacitive - Electronics Textbook
              and P=VIcos φ (real power) and cos φ = 0 for a 90 phase shift
              I managed to get to a point where I could hear 'mains hum' and things started rattling (just as Peter
              describes.)
              I have got to a stage now where a Gallon Demijohn of water is boiling for a mere 12 watts of power. and have it in mind to coil micro bore pipe around the Jar and use it as a heat exchanger in order feed a radiator by natural conduction.
              I start to suspect there's something of great merit here but its obviously difficult to confirm until I've cobbled something along these lines together and sucked it to see.
              I have hopes of a simple, safe, easy build I can share -- ah but hope springs eternal.
              • Duncan happy to hear that one of your projects is progressing.
                The Peter Davy device does not have very many builds and 12 watts
                in resistive terms is comparable to a small soldering iron so there is
                hope that an evaluation will bring out new properties. Even a small success
                can be accomplishment to embelished a spirit of positive energy because
                quantifying is not everything here. Finding new constraints might be
                interesting to explore.
                Conventionally we think about kinetic theory that chemically water has
                high capacity to store heat but some contemporary theories view water as
                having a high affinity to store memory in the form of structure according to the late Rustum Roy.
                In contrast to chemical there are structured attributes:
                When water is structured to form clusters it has a fractal field
                that expands its boundaries with the help of certain acoustics.
                some bowls shape are helpful
                But is there a thermal relationship ?
                When heat is removed from water it expands unlike metal which contracts.
                There may be an acoustically derived water structure where water is compact.
                so the wave part seems plausable.
                • Interesting video and reflections, Duncan. Dielectric breakdown sounds to me to be the key. EPD spoke about dissolving the molecular bonds of water using dielectricity to liberate huge quantities of energy. Here's the cued up link:
                  https://youtu.be/lWoLH21ITys?t=5868 He starts talking about it at 1:37:48.
                  So what does dielectric breakdown and single wire power (SWP) have in common... I think it's in the realm of potential difference. Lightning is a classic example. I see it in Dave Bowling and Matt's work on the potential difference between positive terminals in the 3BGS and 5BGS system.
                  When we widen the window of potential difference and discharge it in a pulsed fashion, we disturb the aether/ambient realm/dielectric realm and cause an imbalance. The aether of course ain't havin' none of that, and rushes in to restore energetic equilibrium.
                  So your 12 watt boiling setup doesn't surprise me. As EPD says, it's not in the amount of wattage going in, but rather in the wave form. And potential difference is much more critical and essential, and amperage much, much less so.
                  My 2cents...
                  Bob
                  • Harmonics and Harmonic Frequency in AC Circuits
                    It also offers credence to Peter's 'musical' tuning. Of course reactive power should not be capable of 'doing work' If it does the books will have to be re-written ( and about time)
                    keeping in mind that I have what's (in theory) a pretty much purely capacitive circuit
                    P = V.I.cos φ
                    should be zero (ish) it isn't, other things are at play here . In fact not much is happening here as the books predict Can the odd balls be put to heating a radiator remains to be seen 'but ahh hope springs eternal' and Barkiss is willing
                    • little steps ..
                      To make a thing that is reproducible is not proving easy . Resonant to what ? Here's am example someone else playing about with this peculiar resonant state.
                      zero amps of course = zero 'real power'
                      still I am specifically searching for something very easy,effective and useful that can be reproduced by a lot of people. Not things involving phase locked loops and complex construction.
                      At the moment I am struggling a/ to reproduce identical results and I am considering making a large submersible variable capacitor to try and find a 'best option' for a 'Volksproject'
                      And then there's this very nice picture of Peter
                      taken from this Polish researchers web site
                      Shocking history of the revolutionary boiler which bits all possible records (in English)
                      I'm glad to say the photo shots of Peter's ammeter concur with the video I showed earlier .. that is -current drops when boiling ... still much to be seen & done however
                      • RE Polish Boiler
                        Very like John Keely's "Dissociation of Water" but produced electrically. A fellow named Hans von Lieven figured out what Keely was actually doing. He explains it very well but it is a long read. It's rather amazing what Keely sussed out in relation to molecular and atomic structure using sound in the 1800's. It's well worth the read in regard to kinetic harmonics and sound.
                        HANS VON LIEVEN
                        The main question I have about the "Polish Boiler" is, was the water actually boiling from heat or was it dissociating to form the bubbles? Admittedly, I only took a quick read through it from the link Duncan provided. I saw a lot of talk about bubbles but not about heat.
                        The first time I read the Hans von Lieven web site it definitely grabbed my attention so I thought I would pass it along.
                        • Its only required that we make something simple and reproducible that is obviously COP >1 but of course that's easier said than done
                          • Originally posted by Duncan View Post
                            World class researcher, no yoyo, maybe, projects.
                            Good to C-U round but as an underclassmen I am not sure how
                            one wire energy works in this setup. If only I could find the
                            page where a one wire setup works in basic form even in a small
                            way.
                            • ' in a small way' I suggest this simple easy build.
                              I did build it and showed it earlier in this thread, quite good enough to run a small quartz clock. Of course what's really wanted by most folks is thousands of watts, controllable and on demand (which I guess is the star we aim for) still Bromikey if single wire energy Patent US603058 - Electrical retort - Google Patents
                              The technology later adopted by Prof Santilli and demonstrated in this clip
                              The technology of course should be in every home but that's not going to happen any time soon.
                              or Is it?
                              • Boiling water at altitude
                                This video actually shows that he is not boiling water. The water is not going through a phase change from liquid to vapor. Although we see some kind of vapor rising from the bowl, the temperature of the water that he shows is 66C. The charts that show at what temperature water boils for a given altitude usually start a bit above 70C for an altitude of around 9000 meters (29527 Ft). It's safe, I think, to assume he is nowhere near that kind of altitude. Even at 3000 meters he would need to get much nearer 90C to cause water to boil. Considering the size of his electrodes I don't think he is causing a plasma between the plates. What he is probably showing is electrolysis.
                                https://www.google.com/search?q=boil...FeFE_ninoQM%3A
