Single Wire Power - A Search for Ambient Power to do Wwork
  • Bob, if you haven't already done so you might want to read Tesla's description of the stout copper bars experiment and what he thinks about it. It's in one of the articles in this book, along with other similar experiments:
    The Inventions, Researches and Writings of Nikola Tesla, With Special Reference to His Work in Polyphase Currents and High Potential Lighting: Amazon.co.uk: Nikola Tesla, Thomas Commerford Martin: 9781614270607: Books
    Beware other editions containing photocopied and entirely black/unrecognisable diagrams.
    • Hair pin circuit particles ?
      Tesla showed that with cold electricity the higher the ohm in the light bulb brighter the bulb.
      lumen - naughty.
      not really AC
      Battery ? understands tesla uses the s word and says "we need to make devices that can use this "
      supposedly there is some other stuff in the e-field.
Name:	parallel plate.gif
ID:	457483Click image for larger version
ID:	457483 Also in common with pancake versions.
      Mckay says there is an annomalous particle between the plates lasts 38 mSec.
      other design concepts use the same anomaly found at dielectric between pancake and primary.
      In the 80hp EV Gray motor Mark Mckay explains the ground could be removed and the capacitor
      replaced by a battery. McKay has the replications of Dollards original cold electricity demo.
      • That is exactly how this usually goes.
        Someone reads something he does not understand, makes up his own explanation and then says that "Tesla said... " followed by some utter nonsense.
        This one does it even better by saying that if you'd dare to disagree with him, you are also disagreeing with some great names.
        Now instead of entering this ridiculous game on these absurd terms, let's try to get a basis for a more intelligent discussion and show me the exact quote where Tesla said that in a hairpin circuit the load is pulling in dielectric energy from the environment.
        And/or show me the exact quote by Steinmetz or Heaviside.
        I am pretty sure that none of the above ever said anything like this.
        So that is what I mean when I say this discussion is about the colour of sheep on Mars.
        First show me the Martian sheep!
        Yes, we must all have an open mind, I know. But don't open your mind to have it stuffed with stupidity.
        Ernst.
        • "Doesn't matter how many times you kick the coyote in the head, it's still gonna eat chickens". - EPD
          • Originally posted by mikrovolt View Post
            lumen - naughty.
            not really AC
            [ATTACH]15944[/ATTACH][ATTACH]15944[/ATTACH] Also in common with pancake versions.
            https://www.youtube.com/watch?v=sLRnWbvcjvY
            Mikrovolt
            Thanks very much for posting these links. I found them extremely helpful. I'd encourage anyone to watch them. Below are some notes I took from the first video clip you listed, from Karl Palsness, with some bold added to highlight some relevant statements.
            Thanks again!
            Bob
            What you have is a sine wave going through this thing [hairpin circuit]. The spark gap is chopping up the sine wave into little teeny, teeny, teeny pieces: plus-minus, plus-minus, plus-minus, up-down, up-down. And then it goes the other way, from the bottom side, and back to this side. This is an AC pulse going in here producing a DC field - not an AC field. It is a DC field, always a DC field, and you'll see that.
            And that was really surprising to me when I saw that. How can you have a DC field on an AC coil? Always to the coil. So it's causing the _____ pumping the local environment. It's pumping, it's drawing energy in - from us, from the metal objects, like-metal objects, you realize. It'll pump from us, it'll pump from anything in the vicinity.
            My big coil at home has a field, a blue field about ten feet out when it's pulsing. You can't see it in the daylight. In the daylight, you don't see it at all. And Tesla says to try and avoid making arcs. The big arc in the Tesla coil is wrong. He says you want to avoid that. You put the ball on the top to give a bigger capacitance field to prevent the breakout - the wire breaks out; the ball doesn't. He [Tesla] wanted to pump the environment with his coils. And that's what he was getting into - how to...how to do that.
            You don't have to tune these coils. They self-tune. Now, the capacitance you have to adjust. I use a 256bit capacitor. ... It's a variable capacitor that a friend of mine designed.
            4:25They're not driving cars from this yet, but this opens the way to collect energy from the environment, just like a solar panel. Solar panel collects energy from the sun, windmills collect energy from the wind, this collects energy from the local environment - twenty-four-seven, daylight-night; it actually works better at night, but twenty-four hours a day. It collects the energy while it's running.
            Now we have to design, there are several people I know are designing devices to collect energy. Again, you run this on 8 watts and you're collecting 5,000 watts in the field... ...the energy is here, and it's different.
            See also the last video Mikrovolt links. He explains at 28:30, that a battery connection (as virtual ground) for the receiver can be used instead of earth ground, as specified by Tesla.
            • Experiments With Alternate Currents Of Very High Frequency And Their Application To Methods Of Artificial Illumination
              Impedance Phenomena
              On Electrical Resonance
              • Originally posted by dR-Green View Post
                Impedance Phenomena
                i need a copy of this amazing book !
                • Maybe the high voltage from the one wire can be used to trigger a gas multipactiion, and something can be done with the electron movement from the cascade.
                  it might work better if the end of the wire is wrapped around the glass rather than connected to one of the terminals of the neon tube, and the terminals conected to the harvesting mechanism.
                  • Thanks dR-Green! So now we have Tesla's explanation in this thread, perhaps someone can point out the line where he says that this circuit "pumps energy from the environment"?
                    Seems like there are people here who insist on believing in magic, even when perfectly logical and complete explanations are available.
                    If you write how this thing really works you get boo-ed. People don't want to hear a normal explanation. If instead I would write about dark electrons quantum tunnelling from counterspace (yes, I love that one!) to convey zeropoint plasma energy, everyone would applaud and spread the word.
                    Now someone said dR-Green is having some secret agenda to keep us all from finding the truth. While I am convinced that this agenda is already firmly imprinted into your minds. You do not need anyone anymore to keep you from finding the truth, this secret agenda has already become a part of you.
                    No dR-Green, not anyone can help you anymore.
                    med.3012.... both that book and all the articles and lectures in it can be found on internet.
                    In fact, most of Tesla's work that has become public can be found on the web. But I doubt if anyone would ever take the trouble of reading it. It does not contain the flashwords that you'd be looking for, just simple and straightforward explanations. The ones that you boo at, but also the ones that could help you find the truth.
                    Good luck to y'all!
                    Ernst.
                    • Energy from the Dielectric Realm
                      Over here, what makes this possible is this dielectric realm. See, the electricity is coming from the dielectric realm. Because the energy is coming from where you see this blue line. Okay? Right here. This is what's making all this happen over here [after the doorknob capacitors]. 'Cause it's coming from the dielectric part of the capacitors. Here, it's the capacitors that are splitting the circuit here.
                      • RADIANT ELECTRICITY
                        Tesla returned to New York exultant. He was about to establish a new world precedent. Venture capitalists were everywhere, looking for their opportunity to enter the "new energy" market. Unknown to Tesla, his station, its tower, the large coils, the capacitors, and all the other marvelous apparatus, which demonstrated free aetheric power to the world, had been acquired for demolition. Tesla simply went forward, securing new funds from Morgan and others toward the development of a fully functional industry sized station in Long Island. Wardenclyffe Station. Wardenclyffe would be his greatest achievement. Here he would broadcast power to the world, along with a communications network, which could span the globe with innumerable available channels. Aether wave communications.
                        Of a truth, dielectric energy was native source of incredible proportion and virtually eternal duration. Able to use such a kinetic source, one could dispense entirely with the Power Transmitters necessary in stimulating and impressing "extra pulsations" on the aether flow. Tesla often defined the dielectric field as a natural flow of aether particles, one that seemed impossible to utilize through lack of appropriate resistive materials. In order to obtain momentum from the flowing particles of a dielectric field, one required special matter poised in equally special symmetries. The otherwise continuous flow could be absorbed directly, being exchanged to utilities, appliances, and other applications.Tesla had already considered the condition of charged particles, each representing a tightly constricted whorl of aether. The force necessarily exerted at close distances by such aetheric constrictions was incalculably large. Aetheric ponderance maintained particulate stability.
                        • OK, you are right, I forgot "dielectric realm", "free aetheric power", and let's also not forget "one dimensional electricity".
                          Without those words an explanation is not worth reading.
                          Ernst
                          • You need to think clearly not deeply
                            How can SWP circuit interact with ambient medium when it is forcibly connected to your power source ? How can bell sound loud if its attached to the rubber handle ? The spark gap in Tesla circuits loosen connection....
                            • Originally posted by Ernst View Post
                              Good luck to y'all!
                              Ernst.
                              i already have a copy of this book , but the quality of e-book i had make it painful for my eyes! anyway thanks a lot
                                Ernst
