Frequency and overunity
  • Frequency and overunity
    Below is a schematic of my circuit a fellow in South Africa has up scaled and is powering homes with. Tis circuit is shown as a pulse motor circuit but basically is a generator. You can hear frequency changes coming from within the coil as it operates. The coil is 24awg PVC coated double strand twisted cross connect wire already twisted at the factory on a 1000 ft spool.
    Cut off what you need so you measure 19 ohms through each wire on your coil spool. I am looking for replications in the USA and am open sourcing the below schematic diagram.
    Originally posted by magnetman12003 View Post
    Hello magnetman12003. You can't post a link to an attachment in your webmail account. You have to either attach the picture as a file to your post from your computer's hard drive, or upload the picture to a picture file hosting web site and then provide a link to the picture on the picture hosting web site.
    level
      https://web.mail.comcast.net/service...1079071&part=2
      Both links are broken and dont work.
      You can try to upload it at ImageShack - Best place for all of your image hosting and image sharing needs, PasteAll.org or any other service for free filehosting.
      Not sure if you can change access rights on webmail on the files, like you can at googlemail, to make them public available.
        In making a musical instrument the choice of materials often reflect the quality of the sound.
        Whether it is cold fusion or battery charging the electrical scheme depends on the material.
        Because hydrogen gives off energy upon impact various elements require higher amplitude
        to get the ringing (resonance) to happen. After the impact and release of energy there can be more
        collisions that produce an additional electro-chemical event. The extra event along with the
        radiantly charged hydrogen use the resonant state to achieve the higher level hydrogen and
        the maximum transfer.
        So yes a coil often reflects the harmonic increase instead of dampening.
        In batteries that are different amp hours type and different types of crystal structure
        still an identical pulse with radiant spike operates at an atomic scale resonance
        which involves hydrogen and lead.
        In another example a Bedini solar powered SG circuit uses a very mild slow pulse.
        A very nice waveform. The batteries are well maintained and the circuit is cool.
        The method of charging is not the same and this is why it is recommended to
        keep the circuit the way it is.
        https://www.youtube.com/watch?v=pFdYK7sU5hs
