  • level
    Djarno,
    No I still have it. Just don't have the large toroids setup yet. I do want to get some type of test done, so was thinking to use the core Level just posted and wind it with some 17 awg I have. Not sure the number of turns needed for 120 v 60Hz. Google says 12 ohms or so many Henry's but will see what I can find out.
    According to Ariovaldo, Barbosa and Leal said the primary should be 'between 0.6 and 0.8 Henries', however I am not sure what primary voltage that was specified for as when I looked up Brazil it said they use both 110V and 220V mains voltages. Wikipedia lists 127V and 220V at 60 Hz for Brazil. Apparently some regions in Brazil use 110/120V and some regions use 220V. The 0.6 to 0.8 Henries might be specified for 220V, but I don't know for certain.
  • wantomake
    still have it
    Originally posted by djarno View Post
    Thanks. Almost done stripping the second toroid.
    I hope my father allows me to blow 9 pipes in the ground tommorow.
    I thought I readed that U had an replicate but U killed/destroyed it ?
    Djarno,
    I do want to be safe here, so will not try just any crazy tests.
    So keep up the good work and post your results as you can,
    wantomake
    Edit: I just calculated that 17 awg magnetic wire has .005 ohms per foot. But 26 awg is .041 ohms per foot. Will think about it.
  • djarno
    Originally posted by level View Post
    [/font]
    Ariovaldo"
    Energy from the Ground - Self powered generator by Barbosa and LealEnergy from the Ground - Self powered generator by Barbosa and LealEnergy from the Ground - Self powered generator by Barbosa and LealEnergy from the Ground - Self powered generator by Barbosa and Leal
    You can read through that whole section of the thread if you want more details about Ariovaldo's investigation of the single transformer device made by Barbosa and Leal...
    Thanks I suppose. I gonna read all the comments in that topic at OU.
    I was signed up there and asked several serious questions regarding floyd sweet, toroids and stuff. People either ignored is sed impossible.
    They indirectly holded me back. Going through with this
  • djarno
    [/font]
    Ariovaldo"
    Fml I got 9 copper rods of 12MM....
    I try to find how long rods they put into the ground.
  • level
    Could you please give me link to the source ?
    Not saying its a lie or anything but perhaps I can't find more information there.
    [/font]
    Ariovaldo"
  • djarno
    Hello to All,
    I just paid my power bill. The amount is way too high for a family to afford these days!!!
    Why should I wait any longer? I will be aggressively replicating this setup to offset the high cost for electricity. I have a solar setup for my shop but the inverter is too small to run any appliances in the house. It's more of an emergency backup for storm outages.
    @Djarno,
    Hope your setup works great, sorry I can't a help with any info. Keep us informed of your progress.
    wantomake
  • wantomake
    power company leeches!!!
    Hello to All,
    @Djarno,
    wantomake
  • djarno
    Originally posted by totoalas View Post
    free energy generator barbosa device by ariovaldo - 01 youtube I think he is the one who disassembled the unit
    totoalas
    Thanks I google, well YT, it later when done with the toroids.
    Hello djarno. Barbosa and Leal were said to have told one customer who purchased one of their single transformer units to use "40 rods of 35 to 50 mm thickness, in an area of 30 x 50 meters." That is the device that was later disassembled by another guy who later obtained that device, and this is a picture of the toroid that was used in it. It is apparently a stator core from a large electric motor. That is probably a heavy iron core. Neither the customer that purchased the device from Barbosa and Leal nor the second owner who disassembled the device could get it to work, according to the second owner.
    I'm strippin down the toroids as I write.
    Thanks.
  • level
    totoalas
    Yes, Ariovaldo made that video before it was explained to him that you can connect the mains phase hot wire to a lightbulb to earth ground and light the bulb without the captor transformer used at all. It seems several people have tried that captor transformer setup using the mains, but never bothered to try just conencting the mains hot wire to the load to earth ground to compare results without the captor transformer used at all. Those clamp on ammeters are not very accurate at low currents, unless you have one that is designed for low currents, but Ariovaldo's video still showed an increase in the phase current when the load was connected from the phase to ground, which is what would be expected for an ordinary ground loop.
  • totoalas
    totoalas
  • level
    Edit, I quote from translated source;
    "2) - Consuming only 2000 W 220 V the collector generates a power of 282.700 kW 220V
    Weight: 40 kg
    Measurements: 60x40x20 cm"
    Okay, they weight is probably due the filled epoxy resin.
  • djarno
    Hello @ All,
    Took a little longer than I thought for the SELF MADE EXPERT to make his usual speech attempting to speak about what I say.
    But be it noted he was incorrect as usual. I purposely only commented on the CAPTOR BUILD! I never commented on the way it was used by the video person and the bait worked. when I finished looking at the schematic he used it was already apparent that no ground rods were in use! some people catch on slow and then want to blow and claim its new info! HA1 HA!
    OH WELL.
    Later,
    Clarence
    I don't understand why they toar down 1 variant, instead of simply letting it soak in acetate as it would completly solve the epoxy. (ofcourse in an closed plastic bag because it vaporates).
    Also seems theyre still 'active' (at least 10 months ago....).
    Their site; Evoluções Energia - DESCOBRIMOS UMA NOVAS FONTES DE ENERGIA
    Their YTC; https://www.youtube.com/user/evolucoesenergia
    Nevertheless they nowhere anywhere anything says/talks about a ground rod system/raster. Only an 'proper earth connection'.
    When I get the toroids today, and get the system working, I actually gonna try hooking it to an (lighting) iron rod going for like 60 meters, if not more, into the ground.
    Weight: 40 kg
    Okay, they weight is probably due the filled epoxy resin. Anyway, clarence, did you try creating a larger primary ? (4 toroids) with same earth connection thus 'upgrading' the secondary aswell ?
  • BroMikey
    Hello @ All,
    OH WELL.
    Later,
    Clarence
    Yes Clarence keep up the great job. The same ones chime in
    repeating the same disingenuous rhetoric for fear their
    world might crumble
    Many are catching on about how to get the extra as well
    as watching a few be upset over all of the attention
    you are getting Clarence. Aint dat just to bad?
    It seems there are those who can not stand a warm
    peaceable communication taking place so they must
    dishonor others.
    The work that the guys are doing is a great achievement
    that puts them on the road to success. Keeping the door
    open to an experiment with one or more toroids is a smart
    way to get new workers.
    You guys are great out there. Working together is fun.
    We are watching.
    MikeyU-da-Man Clarence keep these guys goin
  • clarence
    Originally posted by meetglass View Post
    https://www.youtube.com/watch?v=nK9yVl8xw-g
    (Bez uziemienia?) No Ground?
    Hello @ All,
    OH WELL.
    Later,
    Clarence
  • level
    the plug and outlet have ground connection
    either he replaced his rcd cb to an ordinary one as he has done in his previous video
    the primary L and N of the toroid is being measured
    the secondary L same phase connected and ground instead of Neutral is not measured by the input power meter as there is no return path
    the output of secondary measures higher wattage
    so without captor ( L + E) L N measures higher wattage due to close loop with load
    With captor ( L + E) No Neutral the input is measuring only the toroid
    Live and ground will still run the vacuum with out the captor
    Live and ground is still illegal in our country and with permanent disconnection/ penalty even jail time is the punishment
    so Clarence design is the best option if we are to replicate
    my opinion only happy experimenting
    This is most likely the correct explanation for that video. It is just a ground loop. The ground loop bypasses the wattmeter, so that is probably why it doesn't register the power used by the vacuum cleaner on the wattmeter. This has been pointed out a number of times already in this thread. The 'captor' transformer is probably doing nothing in that demo except wasting some power. Ignore video demos where the captor loop is powered from the mains, as that just shows the person doing the demo is either just trying to fool people, or they have no understanding of what they are doing.
