barbosa leal devices
Hello mr clarence, I have motor stator like core, and this diagram do you think can successfully be in the right way? or I have to change the diagram for good?Thanks wish you the best.
Video: https://www.youtube.com/watch?v=hYQEqzJmSsY
Comedy show
Hello BroMikey,
I hope your last post of this so called "neatpete" creature was meant as a
comedy show for all the members.
I was laughing all over the place at his lunacy!
there were so many mistakes in ALL of that COMEDY so called replication
I couldn't count them all!
If any one follows after that they will all be going down the same road to destruction. you should take note of the CHIEF mistake which is the "OLE HURRY UP THROW IT TOGETHER ROUTE" using a damn microwave transformer!!!
which will NEVER work successfully on this type of devise at all!
everybody always assumes that the CAPTOR unit is just a basic transformer
design which it is NOT! it is TOTALLY different from a normal transformer
and can NEVER BE CONSIDERED AS SUCH!
Oh well. still laughing!
thanks,
Clarence
Here is neatpete
Totally amazed at the captor.
Published on Sep 2, 2015
Here I demonstrate where the power for the transformer comes from.
While most other videos on the subject focus on the power and voltage around the device, the true cost of the power is between the battery and the inverter.
This is not an overunity device!
This is not a device that can power itself.
The only interesting thing about this device is the fact that when you attach a load to the device there is very little consumption of current measurable. This is an anomaly because the true consumption can only be measured between the battery and inverter.
Published on Sep 1, 2015
Part 1 of 2 showing a literal demo of the device.
Here I show how the device can be presented as an over unity device.
It can power a 240 volt 100 watt light bulb for only 32 milliamps and at the same time power a 12 volt battery charger as well as a 500 watt electric drill for only 34 milliamps at 220 volts from the power source.
On the face of it, the unit is indeed an amazing devise, but all is not what it seems.
See part 2 for the truth.
[VIDEO]https://www.youtube.com/watch?v=dRlKRGVMdCA[/VIDEO]
[VIDEO]https://www.youtube.com/watch?v=KsnlBgGwcLk[/VIDEO]
I'm off to Lowe's then. I've been concerned , need to rewire and reload.
Out to the shop when I return,
wantomake
Correction
Hello,
I have to be brief time wise, don't think me rude!
1. I used # 10 -didn't work-too much resistance
2.info from B&L themselves Said use wire that would have 1.0 ohm or less measured with DVMM end to end of open array BEFORE finally connecting
array as a LOOP! the less the better! hence I used #6AWG.
3.my toroid IS wound ONLY 160 degrees! what you see is 1 mil KAPTON tape
by 1 inch wide to protect exposed core area before placing LARGE secondary windings!
bought at Amazon.com in 2014. non conductive.
4. YOU ARE EXTRA FORTUNATE ON THE GEO MAG INFO for your location! HORAY_HORAY_HORAY- sic-em!
5.toroid photos before my Kapton Tape winding!
Got to go,
GlarenceLast edited by clarence; 03-26-2016, 04:11 PM.
Recognized?
Hello dllabarre,Originally posted by clarence View PostHello AGAIN DonL,
1. wire is #6AWG - multi strand tinned - insulated - from PACER GROUP,FLA.
2. YES!
3. Hang ON to Your Things! In about 2 to 3 weeks I should have my parts in
and be able to give results, info , and photos. Chill it!
respects,
Clarence
after I thought about it, I believe I recognized your handle from my past years in posting back and forth on the Don Smith thread? would that be true?
also I recently sent you a PM.
Did you receive - yes or no?
thanks and respects,
Clarence
Hello Bro,Originally posted by BroMikey View PostHey Clarence
I see you are back with a fervor. Good to know someone who is like
a big brother is leading the way.
This site really is a good
place to share openly without all of the filthy comments. Intelligent
folks who are all grown up don't have to prove their manhood using
foolish remarks and then proceed to throw you off their board if it
looks like cool headed reasoning is prevailing.
They become furious
at that point.
I see the new roll around all set for the next success story.
This is going to be a great increase in harvesting the earth currents.
There really are many ways to cook up some of that earth bound energy
and the human spirit will never give up, even in the face of being thrown
into the snake pit with vipers all around trying to correct our every move.
Fat chance, we shall prevail.
I can't wait till you get her all warmed up.
Yeah I,m looking forward to all of the efforts and results and info and photos!
I feel sure it will be positive as I said I,m going to pass it thru my present CAPTOR build to give it whatever amperage needs it may have.
lovin your posts as always!
Clarence
Hang on - it"s coming!
Hello AGAIN DonL,Originally posted by dllabarre View PostThank you for your quick response.
I checked the magnetic map in my area and I'm one notch off of zero.
But I have a question. What type of wire do you use to connect your ground rods: bare copper ground wire or an insulated wire?
Are you working on a device that has promise of working for us living in non-magnetic anomaly areas? I'd be interested in working on a replication even if it's not totally complete and proven.
Thank you,
DonL
2. YES!
respects,
Clarence
Hey ClarenceOriginally posted by clarence View Post
3.YES - this is the best thread - OU sucks!
4.unless your location has a magnetic anamoly of a HIGH Value -
don't waste your time ''''''''''''''''''''''''''''''''''
So my advise if you have taken ALL these things into consideration-DON'T!
Photos attached.
respectfully ,
Clarence
They become furious
at that point.
Originally posted by clarence View PostHello dllabarre,
I.NO - my current build is attached.
2.NO - I don't do you tube or any such.
don't waste your time trying to replicate as of the present I have
60 (SIXTY) ground rods in my ground rod array and it was DAMN well
expensive and still wasn't enough to get the job done!!!!
Photos attached.
respectfully ,
Clarence
Thank you,
DonL
Hello dllabarre,Originally posted by dllabarre View PostHi Clarence and the room.
I just found this thread and very happy I did. I've built several Barbosa/Leal replications that didn't work for what turned out to be obvious reasons after the fact.
I'm intrigued with your build found in PJKBook.
Is that still your current build?
Do you post videos on youtube or anyplace else?
Is this the best thread to follow your work or is there one on OU website?
Looking forward to working with you.
Thank you
DonL
Photos attached.
respectfully ,
ClarenceLast edited by clarence; 03-26-2016, 04:11 PM.
Introduction
Originally posted by clarence View PostHello BroMikey,
for my first choice I'm going to use the ZVS drive to Power my pancake should make the perfect setup to in turn power my TBC and give me the necessary results I'M looking for.
The TBCs are not know for a lot of amperage involved after their frequency has been filtered to match the 60.1HZ on my inverter, however that is where my GOOD OLE CAPTOR comes in!
Before hand when needed amperage was required the 2 1/2 wraps of the neutral earth return induced that instantaneous amperage to all the load requirements with ease.
In this case the TBC neutral will get the same treatment as a means to supply its amperage shortcomings.
After all of this is accomplished I DO intend also to address the problem of the powering of any IGBT circuit as you are correct in stating that they are a VERY NICE POWER SWITCHING method that does not seem to be addressed in a single board form . I may be able to apply that method also to the
CAPTOR design. WILL SEE!
anyway after the MID of next week I will be looking for my parts to arrive and get busy!
again times wasting!
Thanks and respects,
Clarence
Thank you
DonL
Igbt control board
Hello BroMikey,Originally posted by BroMikey View PostYes, ENDGAME is a good word for it and without going into great
detail the planners are moving so fast to squelch the population
I dare say we have much quality time left. However all we need is a
positive connection in the power of friendship to out do the other
side who runs like a scared chicken in the face of warmth or
kindness.
The subject of inverter mode IGBT hacking
I really did not
see my way through that program code, shutdown sensing section
but if I ever do the driver won't know what to do anymore.
I heard there was manual version of those machines but then again
I can't believe that no one has produced a generic control board for
IGBT's that are everywhere and all common power component part
numbers.
Glad to see you back kickin. I was wondering why I couldn't stop
choking for the last 2 months and found out that my airconditioner
was growing a nasty mold colony.
Very uncommon for the midwest but we are very humid this year.
I am looking forward to seeing great things.
for my first choice I'm going to use the ZVS drive to Power my pancake (since the ZVS IS THE TYPE THAT DOES NOT REQUIRE A CENTER TAP AT ALL!) and the pancake not having ANY center tap it should make the perfect
for.
the TBCs are not know for a lot of amperage involved after their frequency has been filtered to match the 60.1HZ on my inverter, however that is where my GOOD OLE CAPTOR comes in!
before hand when needed amperage was required the 2 1/2 wraps of the neutral earth return induced that instantaneous amperage to all the load requirements with ease.
after all of this is accomplished I DO intend also to address the problem of the powering of any IGBT circuit as you are correct in stating that they are a VERY NICE POWER SWITCHING method that does not seem to be addressed in a single board form . I may be able to apply that method also to the
Clarence
Yes, ENDGAME is a good word for it and without going into greatOriginally posted by clarence View PostHello BroMikey,
found what I needed on E-Bay of all places.
I was referred there by a highly knowledgeable person from another site and advised exactly what to look for and how to use it. will order the parts in a short and then make myself busy again as my ankle wound has finally healed so I can get around and get back to things now. after parts come in I will be back on my alternate voltage system to pursue the end game I started with.
As we all know time is running out.
thanks for listening.
respects,
Clarence
kindness.
I really did not
numbers.
