Originally posted by totoalas
Barbosa and Leal Devices - Info and Replication Details
Hello totoalas, if you check the notes again, that 40Ah battery specification is the minimum recommended battery capacity for the specific model of Xantrex 20 Amp battery charger that Clarence is using. I read a comment by Clarence on ou.com that Clarence is using a 70 Ah battery in his own setup, if I recall correctly. Clarence can confirm.level
Hello totoalas, on the schematic it shows that the two outer sets of grounds of 28 rods each are all wired together, so they are really one set of ground rods. The other set of ground rods is the 4 grounds in the center which are tied together. I don't think Clarence has posted a diagram of his current ground rod layout, but Clarence posted an earlier ground rod layout in the diagram that is attached to this post:Originally posted by totoalas View PostHave you checked the earth resistance of the three set of rod connection so we can have an idea if ever we are near to your arrangement....???
@Clarence, I think totoalas was asking what the measured resistance is between the input and output set of ground rods you have installed, as a rough idea of how much resistance there is between your two sets of ground rods. I don't know if a typical multimeter can measure earth resistance very reliably, but it might still give a rough idea for comparison purposes.Last edited by level; 04-13-2015, 06:57 PM.level
Hello Clarence. If I understand correctly, you are sometimes at least not able to run your setup for more than about 4 hours without the battery voltage falling down to 12 volts or less, but actual performance varies in relation to whether it has been raining or not, and maybe other factors as well? The one piece of information on your setup we are still missing is how long you typically can run your setup before the battery voltage starts to fall noticeably. If you can help clarify this any further by maybe running some more tests for longer times like 12 hours or more, that would be very helpful to prospective replicators. Maybe you can compare tests results from a rainy day to tests results for the same test conditions for a sunny day. That might help to shed more light on the effect of the weather or dampness on the performance.Originally posted by clarence View PostHello a.King21,
the next later thing I learned was that I simply needed a LARGER AH battery.
I already they knew they were using the Captor output to self run the device - they openly said so various times. that wasn't a hidden secret
as far as I'm concerned. the charger keeps the batt at 12-13 v up and down.
my location here for ground potential is lousy to say the least and at times
even with sixty rods I can tell that I need another 10 to 20.
when it rains here the potential drops off to under the needed rms voltage
to consistently carry higher loads. and it has been raining here the last 3 days. so what that does is keep the charger from max performance
power wise and the battery voltage because of it will ever sooooo slowly
drop. the last time during rain time I ran it for over 4 + hours and it went
from 13+ to 12 so i removed the loads and let it charge.
so you SEE I have to take my OWN advice about how to MAKE SURE that enough rods + about ten more or so are in place to prevent problems!!
BUT know definitely that this type unit is a winner.
Hope all that helps. I did not mean to ignore you - the time delay was because i simply overlooked your post . I apologize for that Sir.
Thanks for listening.
Clarence
Hello LEVEL,Originally posted by level View PostHello totoalas, on the schematic it shows that the two outer sets of grounds of 28 rods each are all wired together, so they are really one set of ground rods. The other set of ground rods is the 4 grounds in the center which are tied together. I don't think Clarence has posted a diagram of his current ground rod layout, but Clarence posted an earlier ground rod layout in the diagram that is attached to this post:
you are completely accurate about ALL the points you noted on your last two posts to totoalas.
on the DVMM - correct again. in the past whenever i tried with it wouldn't give me any readings so I don't go that way any more.
just as a reliable method, I would start with 10 rods linked in series (without looping it yet ) and attach the Captor 2 1/2 green return earth neutral to it and read across that output leads and find the rms voltage shown. if it doesn't match the inverter rms voltage then keep adding rods until it does.
THEN complete the loop. make SURE you add about ten more rods before looping or you WILL be back to do so. thats by experience.
that's why I have said this devise is self teaching. it won't let you get away with anything - and that's good not bad in my view.
thanks again Sir.
Clarence
Hello LEVELOriginally posted by level View PostHello Clarence. If I understand correctly, you are sometimes at least not able to run your setup for more than about 4 hours without the battery voltage falling down to 12 volts or less, but actual performance varies in relation to whether it has been raining or not and maybe other factors as well? The one piece of information on your setup we are still missing is how long you typically can run your setup before the battery voltage starts to fall noticeably. If you can help clarify this any further by maybe running some more tests for longer times like 12 hours or more, that would be very helpful to prospective replicators. Maybe you can compare tests results from a rainy day to tests results for the same test conditions for a sunny day. That might help to shed more light on the effect of the weather or dampness on the performance.
the word sometimes is a good usage but that should not imply always.
I have let it run unloaded ( actually it was loaded by the charger) before for around twelve hours and it stayed around the 12+ for that period. when you do get to being able to build yours you definitely wont have to ask anyone anymore questions. you'll have your own answers. also I have stated that to overcome weather and other earth difficulties I have pointed out to myself that I need at least 10 more rods because of my location but I am not going to do that at this time,
I've had enough rod pushing and connecting for awhile. also I don't do testing anymore - i'm out of that category, instead I do using. I use it to run various household items to reduce my electric bill. that was its purpose and that is what I use
it for. think on it - a micro uses 15.5 amps at 1640 watts. use that off and on through out the day and it isn't free. it costs if it is run on mains. It doesn't for me. I power it by my unit.
till then,
the best.
Clarence
Clarence, Ok, from your reply it seems you are not much interested in investigating and sharing more details on how your setup performs beyond just a short time, but from what I can gather from some of your comments it appears you have not been able to get your setup to be a continuous self runner. That is important information for people to know however before they go and invest a large sum of money in a replication, and this is the reason I asked twice about the performance now.Originally posted by clarence View PostHello LEVEL
till then,
the best.
Clarence
To tell other people to build your setup if they want to know how your setup might actually perform doesn't make sense.
You need to be fully forthcoming on what your setup can do and what it can't do, based on actual performance testing. To just give people the run around when they ask for specific test results on how your setup is performing, after you have stated more than a few times that your setup is 'working' is not a good sign at all. People should have more than wishful thinking before investing a large sum of money and time and effort into a replication.
Happy experimenting!
level
Clarence and Level,
thanks for the swift replies and flow of info..... at least we know its working....
we dont need an ou ... what we need is how to lessen our burden of electric bills to food in the table ..... thats what matter in my country where power rates is the no 1 highest in Asia for a 3rd world country with some oil and gas and hydro / geothermal plants.......
Battery voltage drop can be topped off with solar/ sg and ssg / cap dump by Mickey's beasty sssg lots of possibilities rain or shine .....
now back to the drawing board..... theres a lot of DIYers out there that can join in
I remember in my test the 10 mm cable in the captor went to 90 deg C in an instant and also the Barbosa first video showed a 90 to 120 mm captor cable
but in your case ur case how is the heat in the captor ?????
for the earthing , ill go first to soil conditioning with salt .....
Now reminiscent with my past experience with old telephone company... we received complaints from a subscriber asking us after the repair their dog bark when the telephone ring??? when we investigated the lineman just wrapped the earth ground to a pipe where the dog is tied,,,,,,, the other complaint if they dont water their plant the telephone doesnt work ... the reason being the earth ground was placed in the pot since they were lazy enough to dig in the concrete lolLast edited by totoalas; 04-13-2015, 09:52 PM.
Hello totoalas ,Originally posted by totoalas View PostClarence and Level,
I just went and checked my unit and the toroid circuit showed 0.08 amps at
6.4 watts. thats why I like them. right size and mighty.
The # 4 AWG black wire showed 1.4 AC amps on the clamp meter.
a good bit of load amperage can be carried by it before it can get warm.
at idle its cool cool cool.
BTW: if your captor loop has more than say 2 amps at Idle you have some some captor windings problems.
if you can shoot a photo I can take a look at it and tell.
Clarence
Thanks ClarenceOriginally posted by clarence View PostHello totoalas ,
Clarence
so can a 1/4 hp ac be used coz thats my goal and quest for this b&l circuit
other household appliances can wait.... for the meantime i just add caps on my ac during operation ( still not using the rectifier type ac).....
the soltution i remember for the captor cable is to insert the cable into a copper pipe for cooling on heavy loads......
sorry totoalas,Originally posted by totoalas View PostThanks Clarence
I did not understand what you meant by a 1/4 hp ac ?
OH now I get it ! a 1/4 HORSE POWER air conditioning unit.
yes as long as the amperage that will be added to the #4 black wire
does not cause it to heat and then if it does simply change the #4 wire to a # 2 wire.
#2 does not wind as easily as #4 but I know you can handle it.
ClarenceLast edited by clarence; 04-13-2015, 10:45 PM.
im talking of at least a 500 watts air conditioner 220 v ac ( one fourth horse power)Originally posted by clarence View Postsorry totoalas,
I didvnot understand what you meant by a 1/4 hp ac ?
Clarence
one more thing , for the inverter with 2 output are they in parallel as in your first schematic ????Last edited by totoalas; 04-13-2015, 10:46 PM.
totoalas,Originally posted by totoalas View Postim talking of at least a 500 watts air conditioner 220 v ac ( one fourth horse power)
you would only be speaking of 2.27 amp + the baseline captor amps of 1.4 amps = 3.67 amps. that should be a breeze (no pun) to do.
always - as long as your ground potential through earth return neutral
supports the inverter phase it should work without problems!
Yes the two inverter plugs have the same phase and neutral just separate circuits.
thanks
ClarenceLast edited by clarence; 04-13-2015, 11:06 PM.
I think this needs an incryption not a translation from the other side lol ...happy to note the healthy discussion.... thanks to Mr Mscoffman and MHOriginally posted by clarence View PostHello LEVEL,
I had sent a PM and I was wondering if you had time to answer.
thanks,
Clarence
totoalas
