Understanding magnets - with EFD and the SPM lens
  • #16
    Originally posted by amigo View Post
    This by Steve Bowman, very nice document on how magnets work, attached here for posterity.
    And I must say we all gotta get a hold of that Superparamagnetic Lens
    Just thought I would provide a link to the updated paper that Steve Bowman has written on "How magnets work": http://www.nanomagnetics.us/Understa...0-2008-1.1.pdf
    • #17
      Thanks for the update.
      • #18
        [QUOTE=Aaron;10787]
        • #19
          voltage without current and current without voltage
          Hi Rectified,
          Was the context of that about voltage and current existing independent of each other?
          If so, any battery with voltage at the terminals is voltage existing with current. In a form being used to do something, voltage potential like an inductive spike ideally is also voltage without current and is therefore "cold."
          A permanent magnet is magnetic current at zero voltage so there is current with no voltage.
          For example, here is an electromagnet that is charged and connected in such a way that after it is charged, the current continues to remain at several amps constantly forever until the circuit is disconnected and the field collapses giving an inductive voltage spike...but until then..the current exists with zero voltage while the magnetic field is there doing work holding onto a bar with zero other input.
          Emery Version - Leedskalnin Perpetual Motion Holder - KeelyNet 06/05/03
          • #20
            Hi Rectified,
            If so, any battery with voltage at the terminals is voltage existing without (meant to say without) current. In a form being used to do something, voltage potential like an inductive spike ideally is also voltage without current and is therefore "cold."
            There are other systems with current and zero to negative voltage again showing they can each do things on their own without the other.
            • #21
              Hi Rectified,
              • #22
                voltage and current
                Rectified,
                I edited one word in my 2nd sentence in my post...voltage at a battery is the potential withOUT current.
                "Voltage is defined as the potential difference across a conductor when a current flows"
                Voltage is the potential difference regardless of if there is current is flowing or not. If you measure a 12v battery and it is at 12 volts...you have a 12 volt potential difference between the terminals with zero current flowing in an open loop. If you close this loop with a light bulb, maybe the battery will show 11.5 volts...so you have 11.5 volts of potential difference between the terminals in this closed loop with current flowing. Bottom line is that a voltage can be there with no current.
                "Electromotive Force (EMF) is measured in Volts that causes the flow of electricity from one point to another. Whenever the charge potential moves it can then be measured in Volts, that = amps times ohms"
                This depends on your definition of electricity...normal "electricity" is made of three components...the positive potential moving over a closed loop from pos to neg terminal...the negative potential moving over a closed loop from the neg to pos terminal...the electrons moving from the copper atoms that make up the wire moving to the positive terminal. The voltage doesn't directly cause the flow of this "electricity"...closing the loop in a typical circuit is what allows the current (electron flow) to flow. Again, you can measure a potential difference from any potential source and the voltage is there whether or not there is any amperage moving or not.
                "The faster the Voltage moves, the higher the amperage."
                In a closed loop, the voltage potential is pretty much fixed at a little below light speed and you're not going to change that in a typical circuit. The amperage has nothing to do with the "speed" of voltage as you can have higher or lower amperage in a circuit at the same voltage and the voltage is going to be the same speed. Inversely, you can have a certain amperage with low or high voltage...and again...the speed of the voltage is the same in both cases.
                • #23
                  Aron We are not on the same page yet
                  "Voltage is the potential difference regardless of if there is current is flowing or not. If you measure a 12v battery and it is at 12 volts...you have a 12 volt potential difference between the terminals with zero current flowing in an open loop. If you close this loop with a light bulb, maybe the battery will show 11.5 volts...so you have 11.5 volts of potential difference between the terminals in this closed loop with current flowing. Bottom line is that a voltage can be there with no current.
                  You are putting a load on the battery with your meter closing the loop
                  As I previously stated Voltage is a unit of measurment of the EMF. OHMS law! Will reply to this statment with more info soon.
                  Another misconception.. do the math and you will see
                  The amperage has nothing to do with the "speed" of voltage as you can have higher or lower amperage in a circuit at the same voltage and the voltage is going to be the same speed. Inversely, you can have a certain amperage with low or high voltage...and again...the speed of the voltage is the same in both cases.[/QUOTE]
                  • #24
                    current
                    Originally posted by Rectified View Post
                    You will be shocked when you learn just how slow current is compared to the speed of light.
                    Just on one point here, in normal terms...voltage isn't current...voltage is voltage and electron current is the current or amperage...the electron current, which is rated in amperage is moving at a few inches per hour while the voltage is moving at a little under light speed.
                    Everything I told you is accurate.
                    For one, if you are trying to point out to me that I would be shocked to learn how slow current is compared to the speed of light, what is apparent is that you have not understood anything I wrote, respectfully.
                    • #25
                      diople and classical fundamental flaws
                      The potential on a dipole is there with or without a meter closing the loop.
                      Here are 34 fundamental flaws in conventional EM theory:
                      Flaws in Classical EM Theory 1. Eliminates the Internal EM Inside the
                      Scalar Potential.
                      2. No Definition of Electrical Charge or
                      of Scalar Potential.
                      3. Equations Still Assume Material Ether
                      Per Maxwell (Unchanged).
                      4. Use of Force Fields in Vacuum is False
                      (and Known to be So).
                      6. Confuses Massless Potential Gradients
                      as Forces (See #3, #4).
                      7. Does Not Utilize Mass as a Component
                      of Force (See #23).
                      8. Erroneously Assumes EM Force Field as
                      Primary Causes.
                      9. Topology of EM Model Has Been Substantially
                      Reduced.
                      10. Does Not Include Quantum Potential or Action
                      at a Distance.
                      11. Does Not Include Superluminal Velocity of Inner
                      EM Components.
                      12. Does Not Utilize Extended Near-Field Coulomb
                      Gauge Effects.
                      13. Does Not Include EM Generatrix Mechanism
                      For Time Flow.
                      14. Does Not Unify Photon and Wave Aspects
                      (Requires 7-D Model).
                      15. Does Not Include Electron Spin and Precession
                      (See #19, #24).
                      16. Treats EM Energy As Existing in "Chunks,"
                      Instead of as Flow.
                      17. Confuses Energy and Energy Collection
                      (See #16).
                      18. Discards Half of Every EM Wave in Vacuum
                      (See #22).
                      19. Erroneously Uses Transverse Vacuum Wave;
                      It's Quasi-Longitudinal.
                      20. Arbitrarily Regauges Maxwell's Equations to
                      Eliminate Overunity Maxwellian Systems.
                      21. Omits Phase Conjugate Optics Effects
                      (Which are the Rule in Internal EM).
                      22. Does Not Include EM Cause of Newtonian
                      Reaction Force.
                      23. Erroneously Assumes Separate Force Acting
                      on Separate Mass.
                      24. Confuses Detected Electron Precession Waves
                      as Proving Transverse EM Waves in Vacuum
                      (Remnant of Old "EM Fluid" Concept).
                      25. Due to Error in String Wave, Omits the
                      Ubiquitous Antiwave.
                      26. Assumes Equilibrium; Not True Unless Include
                      Vacuum Interactions.
                      27. Higher Toplogy Required, to Model
                      Electromagnetic Reality.
                      28. Lorentz surface integration discards Poynting
                      energy transport.
                      29. Has nothing at all to say about form of
                      EM entities in massless space.
                      30. Eliminates the infolded general relativity using
                      EM-force as curve agent.
                      31. Does not include longitudinal EM wave phase
                      conjugate pairs as time domain oscillations.
                      32. Does not include EM mechanism that generates
                      time flow and flow rate.
                      33. Does not include time-excitation charging
                      and decay.
                      34. Does not include time-reversal zones.
                      @ T.E.BEARDEN 1999
                      • #26
                        @ Rectified
                        There's a difference between the electrostatic phenomenon, magnetism phenomenon and electromagnetic phenomenon. Electrostatic has got to do with your potentials, magnetisim has got to do with your current and electromagnetism is a combination of the two phenomenon.
                        Think of it like this, I have an electret in a state of equilibrium and a coil of wire which is attached to an incandescent bulb. Nothing happens. If I have a magnet in a state of equilibrium and a coil of wire which is attached to a an incandescent bulb nothing happens either.
                        If this magnet however is spun the measurements read on your meter are as follows;
                        Current is proportional TO THE STRENGTH OF THE MAGNET.
                        Voltage is proportional to the velocity of the magnet.
                        I don't have an electret to test with otherwise I am sure I could find an analogy to magnetism where the strength of the electret is proportional to the voltage and current proportional to the change in equilibrium of the electret. If anyone doesn't understand what I am saying I'll reword.
                        Raui
                        Scribd account; http://www.scribd.com/raui
                        • #27
                          • #28
                            And now you say
                            post # 24
                            • #29
                              @Rectified, are you trying to say that current must be accompanied with voltage?
                              @Aaron, can you give another example of current without voltage, not involving magnet?
                              Are there any example of current generator or current storage? From any generator example, it is possible to generate very high potential (voltage) with very low current. How do we generate/store very high current without voltage?
                              • #30
                                Rectified,
                                While I am not Aaron I might be able to offer a neutral response to what you've said. Folks like Aaron and myself experiment with circuits and effects which are different to what you have most probably worked with for the past 50 years.
                                I'd say we know just about everything there is to know about closed loop systems, which is what you and every other qualified electrician/EE works with. We however approach circuits with an open loop and a perfect open loop system will almost every time/never be in an equilibrium state.
                                It is due to this fact the laws of thermodynamics might not hold for 2 reasons, 1 they were formulated before we even discovered the electromagnetic phenomenon and 2 because we are not dealing with a system in equilibrium.
                                Also why is Ohms Law going to hold when we don't have current? Your used to dealing with circuits that utilize electricity and magnetic compnents (the electromagnetic phenomenon) whilst most of us deal with purely an electrical phenomenon.
                                Hope this clears any misunderstanding up. Also I might point out to you that I don't have am only 17 and don't have a thorough education on what science currently accepts which I suppose is advantageous to me as I am not bound by the laws that you are. This has allowed me to investigate other phenomenon and not just pass it off because it breaks the 'known laws of physics'.
                                Raui
