Gerard Morin Energy
  • Hey Gerard
    Good video talk. Looking forward to your next video when
    you get more time. Don't let the trolls drive you over the edge
    to where you keep wasting time addressing them.
    Did the cap on the HV system improve OU? I assume so.
    We don't have any 25kva units or 50 kva but we have
    some 5kva and some 10kva cans. Our McCulloch is a 3300 watt.
    We did not use a cap yet we can not get OU from our 10kva.
    Can you get OU from a small HV transformer? I assume you
    have smaller ones?
    Okay that is where me and Hitby are, big can's plenty of
    money tied up in transformers for the pole and no OU.
    I think we have a cap but have not tried that yet.
    Thank you for your efforts. It is good to see somebody
    who is not wandering around in the world, shell shocked
    worried around being filmed or who is going to get them.
    You are the man for this job.
    The amplifier has 2 channels for stereo so if your 2 phase
    motor gets channel one directly and channel 2 is connected
    to the second phase of the motor through a cap to delay
    the RF, the motor might run. The motor should run if it is
    a 2 phase motor being fed 2 signals.
    You just have to play with the cap values to get the delay
    timing for THAT frequency.
    Also add a ground fault contactor for your HV systems, so if a HV
    short to ground occurs the system will have it's own safety
    shut down mechanism. This way if you start the HV can's with
    an improper short the systems shuts off as soon as it is started.
    Maybe this one is to small, but if all you
    are sending into the prime mover transformer from the McCulloch
    is 1200 watts then this basic unit from Lowes or Home depot
    will automatically shut off the LV side and thus the HV side.
    Hook this one to the GENSET. If the HV leaks anywhere that
    it should not, the switch inside will stop the input power.
    Think of it as your guardian Angel
    You will note the GREEN wire that is common ground for can 1 and
    can 2 and GENSET. Any trickle of 14,000 volts, throws the breaker.
    Hot tubs use extra safety switches also because your are sitting
    in water and some of those elements run on 240vac.
    Gerard Morin RF Update and discussion with tests - Part 2
    Gerard Morin
    Gerard Morin
    6,161
    Published on Aug 8, 2015
    We are receiving confirmation of this new understanding of what energy is.. from outside sources, and experiences emailed to us everyday. As soon as I mentioned RF, the emails started to come in with thanks for speaking the truth, and encouragement that we are going in the right direction.
    We have shown Over Unity before and proven it. We have done it again, but this time not every experiment was captured with the camera. I was leaving the province when I finally got ready to capture the footage.. and the generator as I explained will need replaced. It will have to wait until I return. But I will post the video showing the lighting up of 6000 watt worth of bulbs in an upcoming video. I made these videos to show a few tests with frequency and sound, to get peoples understanding of where we are going with this.. to best answer the enormous amount of emails we receive daily.
    These experiments were put together last minute... It's a shame about the Generator, but that is an easy fix when I return. We had our results confirmed by eye witness industry workers, with Jaws on the floor. We are releasing these 2 part videos to keep the subscribers in the loop, and progress is still nearing completion with the self loop generator. Which is the ultimate goal.. to free people.
    • More experimental data
      [VIDEO]https://www.youtube.com/watch?v=h-Qe6uzcIqY[/VIDEO]
      • New Gerard Morin experiments.
        This one takes a 30vdc @400ma Printer adapter then sends
        that power to a 28vdc regulator.
        His power out MAX is 10watts and he is powering 19 watts?
        No measurements given.
        [VIDEO]https://www.youtube.com/watch?v=Zk7rrR3ULb0[/VIDEO]
        [VIDEO]https://www.youtube.com/watch?v=uGv4fLyWfao[/VIDEO]
        • Gerard Morin device test 1 - 1 bulb lit
          [VIDEO]https://www.youtube.com/watch?v=5IQvXNFPt1o[/VIDEO]
          Gerard Morin device test 2 - 4 bulbs lit
          [VIDEO]https://www.youtube.com/watch?v=Y63kJSkizaI[/VIDEO]
          Gerard Morin device test 3 - 4 bulbs continued
          [VIDEO]https://www.youtube.com/watch?v=gencQ2xTK40[/VIDEO]
          • GrumC is showing scope shots of 12v car blower magnet motors
            Showing resonance, calling this a ROTARY TRANSFORMER
            Of course these magnet motors use brushes.
            [VIDEO]https://www.youtube.com/watch?v=IZiP0JoMub0[/VIDEO]
            • How to build a brushless motor from a washing
              machine direct drive motor
              [VIDEO]https://www.youtube.com/watch?v=AUhnlcJzDE8[/VIDEO]
              Published on Jul 24, 2015
              How to convert a standard 240V washing machine motor
              to a 24V DC brushless motor of many useful uses, including
              a power generator.
              • A new announcement video is coming, in keeping with being transparent with everyone.. the theme is to free people, and empower them with the knowledge of how to do it themselves.
                The new Announcement video will be short.. will be completed soon.
                • Originally posted by Gerard_Morin View Post
                  No problem Gerard, atta-boy keep showing up with what
                  the people need. You are the talk of the town.
                  Everybody is counting on hearing something positive from
                  you Gerard. We all have high hopes that you can take us
                  all a little bit further.
                  • Ready to build
                    Thanks Gerard,
                    Ready to build your next machine. This is what the world needs. Freely sharing so all can study, experiment, exchange ideas. All this will lead to free alternative energy.
                    Ready and waiting,
                    wantomake
                    • Motor/Generator closed loop
                      here the motor is geared and the generator is the flat pancake
                      type to send power back to the mains. Battery stays the same.
                      [VIDEO]https://www.youtube.com/watch?v=2oGwrzR_zb0&index=11&list=PLdo-mD6-Nu4yMipRBFk7tc8y9S4D4C2pc[/VIDEO]
                      • I gotcha THROW SOMETHING great video's a picture is worth
                        a thousand words.
                        [VIDEO]https://www.youtube.com/watch?v=LpHgd4-lTkM[/VIDEO]
                        [VIDEO]https://www.youtube.com/watch?v=2Sbw6kTd1-A[/VIDEO]
                        [VIDEO]https://www.youtube.com/watch?v=oYtILriORgM[/VIDEO]
                        • Hello all
                          First I must say thank you to Gerald for bring this information to the public forum . It has been overlooked by so many including myself . And also thank you to the people the post videos of there experiments that I like so much to see as we all do not think alike .
                          That being said without values of input and output of power consumption and production a true statement of performance can not be had. And to make claims of over unity are not valid and only invites the trolls to pay you a visit .
                          I believe in what Gerald has posted and I also feel he has shown an effect that is valid.
                          I say this because of my own tests run on the RF pump .
                          It seems that impedance is of great importance and with the correct parameters over unity is a valid statement.
                          So to those that are not in agreement try for yourself for is the only way most will believe.
                          I look forward to hearing more from Gerald
                          Good luck to all.
                          Jeff
                          • Gerard has gone home to BC to rebuild his McCulloch then
                            he wil be redoing the HV experiment again when he gets back to
                            his new lab with the penthouse. Gerard is moving up to where
                            he belongs. Gerard has promised to show his test results for the
                            transformers power companies put on their customers poles
                            for electrical consumption. These large utility devices are 14,500 vac
                            on the high side and 240/120vac on the users side.
                            Soon we will have Gerard's new result. In the mean while
                            look at how this man was able to modify that simple water pump
                            Gerard has tested with. He can get 520volts instead of 220volts.
                            Magnet wire is often rated at 600volts or better depending
                            on the BUILD. The investigator is shocked when his modified
                            pump output of +520volts goes to a -520volt upon connecting
                            it up to a simple form of Tesla coil.
                            [VIDEO]https://www.youtube.com/watch?v=hOy-64lAPr0[/VIDEO]
                            [VIDEO]https://www.youtube.com/watch?v=LtKvaWxTWVg[/VIDEO]
                            • Them naughty pole pigs and their fearless leaders.
                              Don't buy a pig and try this one. Aimless arcs.
                              Tesla Arc's out into space, personally I always considered
                              fool hearty. But Gerard has got me thinking now.
                              [VIDEO]https://www.youtube.com/watch?v=_nt1d4TQ4k4[/VIDEO]
                              [VIDEO]https://www.youtube.com/watch?v=Pgm003zUAYQ[/VIDEO]
                              [VIDEO]https://www.youtube.com/watch?v=PwqRCPoGDAo[/VIDEO]
                              [VIDEO]https://www.youtube.com/watch?v=S-ya85nliE4[/VIDEO]
                              [VIDEO]https://www.youtube.com/watch?v=mvN_muHZrEI[/VIDEO]
                              [VIDEO]https://www.youtube.com/watch?v=bn1kocu1BI8[/VIDEO]
                              • Marc Belanger is also giving a go at it!
                                [VIDEO]https://www.youtube.com/watch?v=t6ucFJJGSmc[/VIDEO]
