BiTT OverUnity Transformer Bi-Toroid Thane H. Bill A.
  • Originally posted by kEhYo77 View Post
    I understand a bit of Russian.
    You do aay? Can you help with this video?
    Closed caption translation leaves a lot to be desired.
    • NetePete45 response
      Here is neatpete's response to my post to him
      First me then Pete
      Hi Pete
      Good Man , now listen to this. You may get better or worse COP results from input output multiplications but your phase will shift over on you and without the COS of the phase angle you would be fooled. Yes I see all your videos on the scope for the scopians
      Unless you have a 2 channel scope (Obviously you do) you can't get the phase angle of the PRIMARY. Forget the secondaries, watch that PRIMARY especially when loading you will see it shift with every alteration to the circuit. Yes a resistive load is the best and diodes are not resistors only.
      The filament bulbs are what we all use, as instructed in the BiTT plans.
      Also tuning with caps may improve voltages on the output but don't run the phase angle to far. Try to keep the phase angle shift closest to 90 degrees. This will give you the best results.
      Michael Central USA
      Hi Michael.
      I deleted the video because there were some issues with 180 out of phase. The unit switches at the drop of a hat just like you said it would. I have purchased some 1 ohm ceramic resisters, hope they are the right ones for testing. The guy at the electronics shop had no idea of what I was talking about when I asked him for current sensing resisters. LOL. I have come to a stand still with things because I do not have a variac so I will have to make one or spend another $250 on one. Will have to consider my options before going ahead.
      • Here is another OVER-UNITY TRANSFORMER
        https://www.youtube.com/watch?v=X-JC99uqQEU
        • 1929 bi-toroidal transformer Patent
          https://www.youtube.com/watch?v=FvV40BWgByw
          • BiTT testing
            https://www.youtube.com/watch?v=DCti5C1Rqjw
            • BiTT setup FINISHED!
              Hi.
              Finally I have just finished wiring my BiTT setup!
              Testing soon so stay tuned...
                Hi.
                Yeah that is so nice. I like your setup a lot. You have put forth much effort.
                I look forward to your results and measurements. I like your choice of bulbs.
                Mikey
                • Originally posted by broli View Post
                  C cores are very cheap things to get, especially from Alibaba suppliers who are sometimes even willing to send custom made free samples (if you can convince them you'll be buying many).
                  In my opinion this effect remained for too long in the mW and perhaps slight W range. Noone has ever took this to even near kW range due to core and design limitations. This could be easily solved by using cut low loss amorphous C-cores that are readily available. Attached is such design example.
                  What this design doesn't show is the extra cut line, so essentially the C core is cut in half again in order to facilitate the insertion of the coil AND the equalization of the reluctance of the flux path.
                  thanks for putting that forward. Any developments on this application
                  of cut low loss amorphous C-cores? this sounds intriguing, does
                  anyone have any thoughts on this?
                  • Bill Alek research work website
                    Multi-Spark Gap Experiments
                    • OverUnity transformer by Marc
                      https://www.youtube.com/watch?v=uIk_24tOAf4
                      • Flux switch transformer
                        https://www.youtube.com/watch?v=SoA_5n-n56E
                        • BiTT
                          Upload
                          5:48 / 6:00
                          Bi-toroid Transformer replication (over unity transformer)
                          Naoki Kashima
                          Naoki Kashima
                          382
                          1,822
                          Published on Jun 30, 2015
                          In this video I explore the bi-toroid transformer. The transformer has 2 secondary coils and 1 primary. This gives the magnetic flux an alternate route to travel. When the two secondaries are under load you'll be using less power than if just 1 secondary was under load! This does mean that the transformer is operating at over 100% efficiency. I was not the first person to discover this. I will provide links to other videos of people who managed to replicate this effect.
                          Here is a video by Thane Heinsvideo the bi-toroid transformer is explained using mathematics: https://www.youtube.com/watch?v=IdL5E...
                          Here is a video by theENERGYDREAM titled "377% efficiency bi-toroid transformer": https://www.youtube.com/watch?v=aVYiTBi-toroid Transformer replication (over unity transformer)
                          [VIDEO]https://www.youtube.com/watch?v=e2p58tWIxNc[/VIDEO]
                          Here is a video by theENERGYDREAM titled "377% efficiency bi-toroid transformer": https://www.youtube.com/watch?v=aVYiT...
                          • BiTT Part 2 Operates at Infinite Efficiency Proves
                            Energy Can Be Created...
                            [VIDEO]https://www.youtube.com/watch?v=yY_Jl7pC0_E[/VIDEO]
                            Thane Heins 8 months ago
                            Bi-Toroid Transformer (BiTT) Patent: Patent US20140253271 - Bi-Toroidal Topology Transformer - Google Patents
                            BiTT Replication France: BiTT JLN Labs_Report Independent Third Party Test FRANCE
                            Dr. Fusina Defence Research and Development Canada Independent BiTT Test Data:
                            BiTT Test Dr. Fusina Defence Research and Development Canada Bi-Toro?
                            Kurt's DC Powered BiTT: 39C Bitoroid For HV Resonant Drive Transformer, Tune and Testing - YouTube
                            • Billy Bad Boy Transformer Thane, another God awful home-run dude.
                              Atta Boy Thane kickin butt and takin names.
                              It ain't over til it's over. Look out world.
                              And people say energy can't be created out of thin air.
                              [VIDEO]https://www.youtube.com/watch?v=k2H5BerC9Go[/VIDEO]
                              • No Load and loaded conditions verified. Phase angle scope shots.
                                [VIDEO]https://www.youtube.com/watch?v=OjHKjmHrSWM[/VIDEO]
