Bemf Boost and Buck converters
  • #31
    When you run a battery that has not been formatted on the ground side you dislodge loose lead from the ground plates and you turn the fluid black. If this happens the capacity and overall voltage in battery goes down.
    I know this from running Tesla Switch's for many months.
    Now you can flip a battery but you need to charge it through many repetitions on the ground plates. Even then some batteries do not respond.
    If you value your investment do not run a battery from the ground plate.'
    Or don't believe me.
    Matt
    • #32
      Originally posted by voltan View Post
      hi dave.well spotted.now that you mention it, battery swapping as per 3BGS might turn out to be a good thing to do with this.i read most of that thread recently.
      This being a known to work charger it would be worth a shot.
      • #33
        Hey Matt
        Just some idea's, youv probably tried most.
        But the re emf charger is close
        • #34
          I have built quite a few. Just different name for the same thing.
          Matt
          • #35
            hi matt.would the degradation you describe still happen with the pnp scheme above,all polarities reversed?
            i guess so.i can see that your still pushing juice into the charge battery negative.is there a way to make the circuit pull juice out of the positive if thats whats required for longevity and reliability.
            appreciate your input.cheers
            • #36
              Thats what Dave just posted. Get rid of diodes unless you need that protection diode, which with a regular motor you don't, use an NPN instead of PNP. Run the motor in the correct polarity. Or make it turn clockwise as you face it, which is general for a dc motor.
              This is the same thing as John Bedini's 3 battery setup. Altrez is working on one at this thread : http://www.energeticforum.com/renewa...gy-device.html
              Doesn't matter what your load is.
              Matt
              • #37
                Setting the system up in a buck converter mode may be an option.
                Buck Converters
                • #38
                  • #39
                    • #40
                      Buck converter
                      • #41
                        The notebook is getting full
                        I need to get to work
                        Lots of possibility's
                        • #42
                          If the pos side of the cap builds up a higher voltage than the battery will the electrons flow to the neg side of the cap rather than the battery.
                          • #43
                            Not sure why i cant get images to post
