Basic Free Energy Device
  • gotoluc
    Hi all, so if the current is 1 amp for simplicity sake, that is 24 watts taken from the input series batteries.
    However, 1 amp powering a load between the batteries, is 12 watts and isn't 12 watts entering the 3rd charging battery.
    Since it appears you were making a veiled statement gotoluc, does this make sense, that 24 watts of work is being done.
    peace love light
    Hi SkyWatcher
    Yes, that is generally what I wanted to know if Satyam108 understood since he only posted in and out current measurement which may indicate he's under the impression the charge battery is receiving the same amount of power then the input batteries?
    However, until he replies we won't know why he posted just the current measurements and if he understands that current is not a measurement of power.
    But you do know that and I generally agree with what you posted but here is how I understand it and measured it.
    If battery 1 & 2 are connected in series and are 12 volts each = 24 volts and the current is measured at 1 amp = 24 watts entering the motor and if battery 3 is at 12 volts and the current entering it is measured at 1 amp = 12 watts entering battery 3.
    So if we have 24 watts coming out from input batteries and 12 watts going in the charge battery it means half of the input power is being used by the motor and potentially half recovered by the charge battery.
    However, the motor has converted part of those 12 watts to mechanical power and at best 80% if it is available at the motor shaft which means we have about 9.6 watts in mechanical power at the motor shaft which we can recover back to electrical if we attach a generator to it and can recover at best 80% if it = 7.7 watts and add it to the charge battery which gives a potential total of 19.7 watts recovered from the 24 watts put into the system.
    So things are not looking very good and we also have an other loss factor not yet considered which is Battery charge losses.
    Example: if you load test a new fully charged 5 amp hour 12v battery you may get 60 watts hour out of it. However, to charge that battery back you will need to use about 74 watts hour which means a lead acid battery is also about 80% efficient to recover meaning the true potential to the charge battery will be 80% of the 19.7 watts = 15.76 watts of potential recovery of the 24 watts from input batteries giving a score of around 65% energy conversion from the input to the output charge battery.
    One may simplify his life and get better results to just use a battery charger to charge the 3rd battery?
    So what is it and can you demonstrate it that can make the reality any better then what I've explained and tested?
    Luc
  • Matthew Jones
    Hi Satyam108,
    Is the input voltage to the motor 24 volts (battery 1 & 2 in series) and the voltage to the charge battery is 12 volts (battery 3)?
    Luc
    See, this is why we decided you weren't worth the time it takes to listen to you.
    You do not measure a battery no matter the arrangement in 2 parts. You always measure the difference between the lowest and the highest potential. That is Voltage on a meter, period!
    If you put 10 batteries in series the potential of the system is measure between the ground pole of battery 1 and the positive pole of battery 10.
    If you put 10 batteries in parallel you still measure the difference between the ground pole and the hot pole.
    This setup is no different except you have excluded the ground poles from measurement and your difference is measured between 2 positive poles. There is not method for knowing the voltage drop before battery 3.
    Show me a textbook engineering reference that states otherwise? You cannot make up the rules as you see fit. Voltage is the difference between the highest point and the lowest point in an electrical system.
  • Turion
    Motor
    Or PM me with an address and I will mail you one. I have several.
  • jim glinski
    Motor
    Hi guys found the 250 watt DC motors but none with a "b" designation on the end what's up with that .is it needed any one know what it means ? Cliff hanger.
  • SkyWatcher
    peace love light
  • gotoluc
    Originally posted by Satyam108 View Post
    PS: Attached is proof that current in to the motor (in 3BSP (split positive) = current out (into the battery being charged.)
    Hi Satyam108,
    Luc
  • citfta
    Only have time for a quick reply. 3 Battery Generating System.
  • Satyam108
    What is GS?
    Hi Jim,
    There is no reason to do that. My experience with the 3BGS is that it will many times actually restore batteries that are sulphated. It is of course better to use good batteries but there is nothing about the 3BGS that harms batteries. The pulsing from using a pulse motor and this system actually removes the sulphation and greatly extends the life of the batteries.
    The one post you may have seen about this system damaging batteries was posted by a buffoon that can't even do simple high school math. He also has never put together a 3BGS system so he has no idea what he is talking about.
    He of course will now come back with a bunch of cursing and other garbage like he always does and will be ignored just like you would any 5 year old throwing a temper tantrum.
    Take care,
    Carroll
    Hi Carroll,
    I know I'm going to regret asking this, because it will probably be glaringly obvious, but GS in 3BGS is abbreviation for ? Obviously 3B is Three Battery - referring to the basic technology of this "BASIC FREE ENERGY DEVICE" thread. But scratching my head on the GS. Thanks in advance.
    Jim
  • jim glinski
    Pulse motor
    Thanks Carroll ....about the pulse motor of Matt's ...is that the rewind DC motor the one from eBay ??and there was a four battery system around why are you guys focusing just on the three battery system ?? Have you any understanding concerning that lenz less generator ?? There is one on the ?? Pure power systems ?? but its just a large Newman motor . I'm going to start pulling this together this fall/ winter ...that's when I'm in the weeds energy wise .so I'll start with the rewind motor . then the buck converters . the thing about the bibarb battery is getting bad sulfated battery's on the cheap and rejuvenating them . but will see I'm going put put my work in GRAPH'S on the string just to get past this issue . jim
  • Satyam108
    If there's a 50-50 chance . . . .
    LOL
    Yeah I can relate to the 99% thing. Murphy's OTHER Law:
    If you have a 50-50 chance, 9 out of 10 times you're wrong.
  • Satyam108
    But Bedini Used "Toy Batteries" in his cigar box in '84
    Hi Dave,
    At one time somewhere I saw a very bad copy of a photo that was originally on newsprint I think, of Bedini's "Cigar Box" Split the Positive 3 battery system, that he demonstrated at that first symposium (1984?) in Colorado Springs - on Tesla's Birthday. I have read that the batteries were NiCads and either 1.5 volt AA or 9 volt, and that they ran a small motor in that same cigar box for 6 months following the symposium. Peter Lindemann referenced transistors to switch the batteries around, and then discussions of this Cigar Box veer off into a Ron Cole "bipolar switch" - and the fictitious "Tesla Switch" (you are correct - it should be called The Benitez Switch - Bedini himself stated that he didn't know how that 4 battery switch ever came to be known as a Tesla Switch.)
    I think it's pretty clear that Bedini's Cigar Box did not use a boost converter - nor did he say or write anything about needing to re-wrap the coils on the armature of what I suspect - from my own experiments, and from what I've read, that he obtained his pulses from a permanent magnet motor - USING the reactive power from Mr. Lenz. Cudos to you and Matt for discovering those improvements.
    SO
    In my attempts to go back to basics in order to understand this thing - the 3 +2 battery switch - Split the Positive, as nearly as possible I need - for my own edification - to try to recreate the Bedini Cigar Box as closely as I can. If anyone reading this has a photo of it or more information about it, I will greatly appreciate getting that.
    Thanks and good luck to all of us.
    Liberty, Peace, Prosperity and Love
    Jim
  • citfta
    Originally posted by jim glinski View Post
    One way is to convert them to bicarbonate lead battery's you lose some voltage like from 12.6 down to 11 but you can run them down to zero then back up. no sulfate no crystals .google it saw it on you tube .
    Hi Jim,
    Take care,
    Carroll
  • jim glinski
    Batterys
  • jettis
    Turion, I have a couple of questions...
    When you arrive at 80 percent recovery to the charge bank, using splitting the positive, are you using all of one through six below?
    Again with the 80 percent figure... When you test your setup to get 80 percent recovery I take it you start with a fully charged battery that runs the boost converter and motor. But what state of charge is your large charge battery bank?
    Are these larger charge battery banks resistively drained (discharged under load) to 10 volts, 12 volts or some other voltage before starting the charging (recovery) test run to achieve the 80 percent recovery?
    1)Matt's pulse motor.
    2)C-20 or lower discharge rates.
    3)Battery resting after partial charge (removed completely out of the loop, not connected to anything, thus the battery continues to self charge via the ions still moving in the charge direction.)
    4)Battery rotation.
    5)Boost converter for higher voltage sent through charging bank.
    6)Heavy flywheel.
    Thank you,
    Dave Wing
  • Allen Burgess
    Bad batteries.
    Quote from GlenWV:
    "When I tried Dave's 3BGS with poor quality batteries, it didn't work very well at all. With good batteries, the setup works very well indeed".
    Come on Man! People found a way to wear good batteries out. Whoopy do!
    How long can we extend run time before we need to replace our batteries? Maybe it's cheaper to avoid the extra expense.
