From the tesla switch document, it said:
"It is likely that additional circuitry is needed to cut off the extra power when the energy in the batteries rises to the point where it could endanger the equipment which it is powering or component in the circuit...It might be sensible to have the control circuitry to kick in at 14 or 15 volts and drop out again when the battery voltage drops back to 12.5 volts or so."
Another tesla switch document said that:
"If left undisturbed, each battery would charge up to nearly 36 volts. Control circuitry is needed to prevent over-charging.
1. What sort of electronic component can help me achieve this? Tell me please.
2. How can I use one ne555 timer to operate 3 opto-isolator in ON state while another 3 opto-isolator in OFF state? How to invert the ne555 timer?
3. What is the maxi. voltage that can be allowed for each battery in tesla switch? 12 volts, or 36 volts or even higher, I am confused? Any comments?
4. Is having a higher switching frequency, the tesla switch will have a higher maxi power output? (note: not to exceed 800 Hz and must above 200 Hz)
Your opinion is invaluable to me. Please share your opinion.
