Hi Bob You are right- there seems to be a concentration of some kind of energy near the center. The smallest pancake- lower right picture- produces the most output.
Series Wound Bifilar Coil a Doorway for Dielectric Influx?
Hi Asollid,Originally posted by asollid View PostHi Bob You are right- there seems to be a concentration of some kind of energy near the center. The smallest pancake- lower right picture- produces the most output.
Thanks for the reply. I now believe the center of a coil is where a lot of things happen - even in a single strand air cored coil. It would make sense that the same is true of the swbifi (flat or air core), but only higher.
I don't see a link to a picture.
Bob
Double Joule T.
Here we go for an opposing winding on what looks like a toroidal core. These cores keep everything inside so maybe the fields still neutralize even though they are not right on top of each other.
There must be a canceling of self induction to lower impedance, drawing in extra.
Self exciting transformer - YouTube
MikeLast edited by BroMikey; 09-06-2014, 11:29 PM.
Good video
Thanks Mike,Originally posted by BroMikey View PostHere we go for an opposing winding on what looks like a toroidal core. These cores keep everything inside so maybe the fields still neutralize even though they are not right on top of each other.
Mike
Good video and so interesting.
I have built some JT circuits but never seen that setup. Did the gap in the toroid cause the continuous flux( or whatever) to bounce back and forth? Thus the long time the leds were on. Or were those supercaps he used there?
Still trying with the coil configurations and such,
wantomake
Coil Names
Thanks Dog-One
I saw that name but being the green horn it didn't register, Thanks for the low down on the name. It is pretty wild on YOUTUBE in the last couple of years.
I did a search on O.U. Transformer, Tesla Transformer, Kapagen transformer, Resonance transformer. Overunity transformer, BiTT. Bi-toroid, toroidal or TPU trans and on and on------------ and wow wee everybody and their brother is getting on the band wagon making these things.
Mike
Using Bifilar Coil For Healing
The swbifi and caduceus/tensor coils produce scalar vectors/impulses of energy. Used in the proper way, with the proper intention, this kind of technology can promote rapid healing in the body.
To understand this, we need to take a step back and look at the dielectric medium in which we live. The dielectric or aether is the great energetic reservoir which keeps us all alive. All living things take energy from the dielectric medium in order to stay alive and thrive. Injury, disease or inflammation impedes the organism's ability to avail itself of the dielectric's life-sustaining property.
The swbifi and tensor/caduceus coils produce scalar impulses of energy. This energy operates at superluminal, if not instantaneous velocity. It is said that our thoughts and intentions/intentionality are nothing more than scalar impulses. There are many documented stories online in print and video format that show persons promoting healing through a focusing of the will and intentionality, often through a laying on of hands.
How might the swbifi and caduceus coils help us with this?
More later...
Bob
Quantumfuel
Hey Bob I found this from the energetic forum last year
Originally posted by quantumfuel View PostThis is an extremely relevant point Hobby Eon!
To be more explicit let's call the parallel-bifilar the counter-wound bifilar and the series-bifilar the adding-wound. The caduceus coil is a variant topology of adding-wound that deserves to be discussed also, but later.
What the paper doesn't say is that counter-wound bifilar coils only deploy their "scalar" effects above the limit of aether compressibility limit. You may therefore use your bifilar at saying 60Hz, 12V without observing nothing weird.
Not only Paul Stowe in his papers has identified the true basis of aether-mechanics, but he also determined a compressibility limit of the EM medium. In other words, below the compressibility limit, the permittivity epsilon is a constant and Maxwell equations apply.
Above this limit, not only epsilon does locally vary, but Maxwell equations require to be extended to the EM-quantum case. There scalar waves appear and there they enclose the local ZPE to produce photons and there the local energy materializes into photons by yielding additional energy to material systems. This is a kind of quantum-heat-pump a quantum-Carnot-cycle.
Paul Stowe establishes the compressibility limit around the UV frequency, which also corresponds to the UV catastrophe.
There's another approach to understand how to reach that compressibility limit and how to create brand-new photons and to suck-up back their energy into the circuitry. The DON SMITH system is fairly eligible to this approach.
My point is to consider the Lorenz gauge condition as universally true, because it is the root-cause law that says that "The aether is neutral and any attempt to split it in opposite charges triggers on best efforts to recover neutrality". What says Lorentz gauge is the following:
1/eps.dU/dt = -mu div( A) (or Nabla.A according to your education style)
I won't detail here the calculations, but there is a compressible limit to both left-hand and right-hand of this relation.
The left-hand corresponds to strong dU/dt as obtained in spark gaps, as already discussed.
The right-hand corresponds to current scissor that can be obtained in a counter-wound bifilar. Indeed, even if no outer magnetism is produced, the local aether momentum A is locally so much varying that you impose the permittivity epsilon to vary. You then create that kind of perturbation, poorly called a scalar wave, which should be more exactly renamed a compressibility wave or a gravitation wave.
To position clearly the various pieces of the jigsaw. The adding bifilar coil did interest TESLA because it allows to define an LC resonator per se and resonance is important to maintain high-voltage oscillation at lowest cost in his systems. The counter-bifilar coil has been developed with Bearden's Time Energy Pump. But Bearden mixed up with relativity and he neither understood the true physical meaning of his proposals. Naudin tried some experiments involving a counter bifilar (see here), but with 12V at the entry he could only observe vanilla things. Moreover adding ferrite is like introducing a blocked hand-brake in your sport car.
Therefore, the counter-bifilar coil may successfully complete a DON SMITH system, in lieu of the spark gap, but in that case it is necessary to inject the necessary amperage in it. The only system I saw with such a device is inside the TESTATIKA of P. BAUMAN: what he call the "Electron cascade generator".
Question
Bob,
I have many questions and few answers.
I wrapped a trifilar twisted coil, 28 or 30 awg, don't remember. Then cut wax paper same width as spool. Used aluminium duct tape on the wax paper and wrapped 15 feet (2 pieces) around the spool of wire to create a capacitor with two leads. Filled the core with soft metal strips from a disassemble transformer. Topped with wax to hold metal in place.
Sorry no circuit or coil pictures yet.
But I connected a 9V rechargeable ,the coil, some supercaps, LED, and resistor in series like an LC tank just for learning and testing. Unbalanced of course.
The 9 volt battery is a radiantly recharged. It first lost voltage, but regained charge over a day or so. The LED pulled the amps down but the charge remained same . ?????
I removed the aluminium tape off the coil and the coil would not work in the circuit as before. The LED would not light at all. Is this something to study or normal electronic event?? Will post pictures if you want.
wantomake
Hi Wantomake
I've been sick for awhile so my posts have been almost nil.
That sounds like a really neat setup. I honestly don't know what might be happening. But I could share some thoughts for what it's worth.
Sounds like a lot of capacitance in that coil setup, and I believe capacitance is somehow tied to the dielectric medium we're in. Your aluminum tape wrapped trifi coil with a core got me thinking about the Joe Cell. When the JC is working as it should, it draws in orgone or dielectric energy (I believe Eric Dollard sees them as the same or at least intimately related) from the ambient to achieve its effects. I'm not talking about HHO. I'm referring to the JC as a coherer of orgone/dielectric.
Conventional electrical theory tells us that charge runs from positive to negative in a circuit. However, with radiant, the opposite is true. In the JC, the centre is negative, and outer ring is positive. Something in the config allows it to work the way it does. Joe (JC inventor) says it's simply a microcosm of the earth in relationship with the sun.
Is your twisted trifi coil series-wound or parallel-wound? If series-wound, I wonder if the windings are in fact providing a doorway for more dielectric energy to enter the system.
In some pulsed systems where a lead acid battery (and in some cases caps and other kinds of batteries - see Turion's 3BGS thread) is involved with a rapid on-off pulsating charge, the battery becomes conditioned after a number of depletions until it starts to act as a kind of antenna through which the dielectric enters the system (negative to positive).
It would be interesting to put a scope on it in a few places to see what shows up. Is it DC, pulsed DC or perhaps AC powering the LEDs?
Thanks for the interesting post. I hope you don't mind me sharing my musings. I'm just a pilgrim myself, and feel like we're all in this together to find a way to more fully understand and make things work better in this area.
Please keep us updated. I'll post when I can, health permitting.
Kind regards,
Bob
On a journey
Thanks fellow pilgrim,Originally posted by Bob Smith View PostHi Wantomake
Kind regards,
Bob
Hope the sickness is only temporary and not serious.
I think the capacitor around the trifilar coil helps in some way but don't know how. As stated in post before, I believe this is what I've been looking for. Many are trying to find the device that will give free energy, self run, or be the answer we are all trying to invent. I think there is a device that would be used to boost the output to a usable amount.
The trifilar coil is series connected . Series-wound I guess is the same not sure. It is straight DC powered. No pulsing this time. That's why this was strange to not drain down the battery.
Musings always welcome,
wantomake
Thanks Wantomake
One day at a time... I was just thinking about a remark Groundloop made about twisted multifilar coils over on OU forum. He said that the twisting seemed to increase their capacitive coupling. I would think the series connecting only increases it further, in addition to concentrating magnetic attraction between windings. Ken Wheeler tells us that the dielectric field terminates as magnetism. This tells me that there is a very close relationship between the dielectric field and what's going on between the windings of a series-wound multifilar coil.
It would seem that the aluminum tape winding around your entire coil is crucial to its capacitive nature. Is this not a further entry point for the dielectric's capacitive nature to interact with your coil setup (in addition to the twisted series connected windings)?
Sometimes we have to follow our intuition and the theory will catch up with us later. Hope your work continues to bear fruit.
Happy weekend!
Bob
monofilar
Hi Bob If I understand the patent correctly, the bifilar is a series resonant circuit. As such, all experiments have to be at a specific frequency to get any kind of accurate data. My induction cooker-1500w-uses a monofilar pancake. I have tried to make bifilars resonate at the same frequency as the monofilar cooker but it just seems impossible. So I wound a monofilar the same size as the cooker and it works great. It powers a 1500 w heater easily. Now i am winding a second monifilar coil oppositely. Actually it appears that if I wind another one even in the same direction as the first one, and then just flip it over upside down, then I have an oppositely wound coil. But I'm not sure about that. Just for a visual aid I wound two solenoidal coils of 10 gauge wire 5 turns each-oppositely wound. When I flip one of them overit is still oppositely wound!
