Gravity motor - what do you think?
  • Gravity motor - what do you think?
    Hi Peter and all,
    I heard the interview with you and Stirling.
    Heard you were doing research on the gravity engines.
    Well I have been doing some work on that as well.
    Here you can see an idea I had.
    http://home.planet.nl/~sintt000/MagneticWheel.wmvhttp://www1.istockphoto.com/file_thu...n_s_cradle.jpg
    And
    billard ball pendulum
    Try This...
    Originally posted by nali2001 View Post
    Hi Peter and all,
    And
    Steven,
    Very good! If the ball will travel up the ramp and past the top, I suggest that you simply continue the track, but from about the 1 o'clock position, start moving the magnets further away from the ball and then stop the track at about the 3 o'clock position. The ball should be able to just "fall" out of the magnetic field at that point, assisted by gravity, and enter the bottom of the track again to begin another cycle. Once you are over the top, you do not have to keep making the magnets closer and closer to the ball.
    See if this helps.
    Peter
    Peter Lindemann, D.Sc.
      Cool Video
      Hi Steven, Peter, and all!
      Steven, great video. You have given me a few ideas.
      Here is an idea I had for a gravity chain, but to understand
      it fully, I suggest you watch this Youtube video showing the ability
      of small magnets ability to make large magnets totally defy gravity.
      YouTube - Magnetic Launcher
      It is also largely based on the "Murilo Luciano" gravity chain here:
      http://www.panaceauniversity.org/D21.pdf (page 7)
      Anyway, here is my idea/photo. I wish I knew how to make a
      cool 3-D video like yours. Can you tell me what program you use?
      The mechanics of this
      are still being tweaked, but try to imagine all the balls below circulating
      inside of a clear plastic tube. On the outside of the tube are the smaller
      magnets propelling the larger magnets similar to the Youtube video.
      Basically, magnets lift the weights on the right hand side of the chain,
      and several forces drive the weights down on the left of the chain. The
      sprocketed wheel at the bottom can be used to drive a generator.
      I am pretty sure that it will work, but I just have NO CLUE what kind of
      force it might produce. It could obviously be scaled up, or scaled down,
      but as it is drawn, the small 1/2" square magnets are only about .50 cents
      each, but those large 1.5" magnets are very pricey at around $35 each!
      (somebody please tell me if you can find them cheaper)
      This is not to scale at all, nor are the number of magnets, but hopefully
      you all will get the idea.
      Thoughts please.
      Thanks, Bob
        A document about gravity engines
        Hi
        I found this document somewhere on the net.
        So I thought to share it with those interested in this stuff.
        See the attachment
        Elias
        http://blog.hexaheart.org
          Gravity and Buoyancy
          Combine Gravity and Buoyancy to get double the force.
          This has been the engine used by Kings for thousands of years to elevate water. The input is Buoyancy and Gravity free of charge.
          100's of tonnes of force to produce work.
          https://www.youtube.com/watch?v=4UoaFXyKN54
          https://www.youtube.com/watch?v=0cFywU1zvQc
          https://www.youtube.com/watch?v=UahM1G3GkCA
            Gravity Buoyancy Bird
            Free energy bird is an engine using many forces including heat.
            https://www.youtube.com/watch?v=Rq3K6Ma0wIU
            The Bird is the word for free power.
            Mike
              Several years back, I redesigned a drinking bird as a form of energy generator. Although mine didn't use evaporization as the power behind the movement. I used levers and a fulcrum to harness gravity totally. although I never build one larger than a toy sized model, I feel that it had great potential of being a self rum generator. If only I had kept all those prototypes from back then instead of cannibalizing them for other projects. At the time I was really trying understand the principles behind gravity, magnetism and other free energy available from nature. I have investigated many phenomena over the years and found what works for me. None of my machines have been replicated as far as I know. Most are obscure drawing on paper and CAD. Good Luck. stealth
                Gravity plus magnetic force
                Several years back Matt Jones posted an arrangement of magnets that once you pushed the magnet through the magnetic "gate" at the beginning of the track, would shoot a magnet down the track and out the end without stopping. Look at all the other "V track" videos out there. You will see one of two things.
                1. The force needed to enter the gate is considerable, but the object shoots out of the end of the track.
                2. The force needed to enter the gate is reduced, but the projectile stops at the end of the track.
                Matt started a thread on it here at the forum with a parts list of the magnets and a diagram of how to place them. I believe he has since removed that information from the public record.
                I replicated his design and even made a YouTube video of the replication.
                The attraction of his design for me was that because of the arrangement of magnets, the force required to "enter" the gate was far less than the force with which the magnet exited the gate at the other end. I used a couple devices I constructed that measure foot pounds of pressure to determine this. (Just some scales really, slightly modified.)
                I built a four foot wooden wheel out of 3/4 inch plywood with a short shaft bolted through the center that rode in bearings on either side of the wheel, and six neo magnets on the rim. If I placed the noes just past TDC and let the weight of the magnets rotate the wheel until the magnet engaged the track, and the magnetic action of the track rotated the wheel, the magnets would spin around almost to the top. Every try ended with the wheel eventually stopping.
                  I hope you know that gravity motor or magnetic motor is too costly to be more then a toy when build and working
                  I can give you one very important hint : you can do it with combining two forces or you can do it with adding new "degree of freedom" (I don't know how is that called in English technical dictionary).
                    Toy Motor
                    I guess you are right.
                    50kW Buoyancy Free Energy Generators for Sale -- Hidro+ Floating to the Top | Free Energy
                    https://www.lhup.edu/~dsimanek/museum/unwork.htm
                    Waterwheel power generating device
                      Almost all of these designs have been around for many years. Not many have become available lately. I have built most of these design, TOMI, Hampster Cage, Leopolds Ball wheel, Bedini's magnet motor, Bowman's magnetic motor,and many versions of other magnetic and gravity motors. What I found is that it is feasible to build one that will self run, but you can't draw any power off it. Using two types of energy, magnetic and gravity, such as the Hampster cage motor, or one of the other exotic designs, it is capable of producing over COP 1. I have a free energy book that I acquired some 20 years ago. It has many designs of magnetic and gravity motors, some are patented and some are not. Many have been replicated but very few have posted their results. While all this was going on no computers or internet existed. The information highway was slow to non exixtent. Snail mail, and telephone being the only forms of communication for most. Most of the information I acquired came from work associates and friends. In those days it was hard to nail down a lead and see a demo or prototype of a machine running. Many of these machine probably worked, but so many details were left out that a replication is nearly impossible. The buzzsaw wheel, The Besslers wheel and some others were seen by many and were reported to work without any human intervention. Good Luck. stealth
                        Good to hear from a seasoned Experimenter
                        Hey Stealth
                        Yes all true those days were harder to get details. All I had was the GOV/RUN books from the local library. We all know and have heard that in the last 100 years everyone has become educated to where they can all read but before this men were not so dumbbed down.
                        Men of the past 5000 years had to be observers of their own experimental data and didn't have all of this buzzing in their ear that "it won't work". Since they had only their experiments to work on from day to day it didn't matter when they succeeded, as long as they did.
                        The way it went was something like this:
                        The King wanted water pumping, period. End of statement.
                        He was going to have it if it killed the donkeys and oxen to get it. So everyday some sort of input was needed.
                        When the Mules were not available the slaves were used to drive the input.
                        @ Everyone
                        Now is everyone ready for the answer?
                        You guessed it, the slaves figure out everything so as to lighted their burden and the experiment was running at every minute right in their faces.
                        Hello Slaves
                        So what does that say? How series are we?
                        Sure many things are lost just like Tesla's work notes. They are hidden and lost because the ruling body wants to control and beat the slaves.
                        Year after year slaves died of broken bodies and replaced by a younger man.
                        Now as the generations rolled by it is not hard to understand that the father who passed the job onto his son wanted to make the pump work on it's own
                        That is what happened.
                        @Stealth
                        I am pleased to see someone has tried so many of these.
                        It does seem with these forces at our disposal like magnetism, buoyancy, gravity, and so many new ones, that some combination should easily go O.U.
                        The expense to build is the first obstacle.
                        The way the Kings and Pharaoh's started was with buckets of water hanging from a peg on a large wheel to bring about a continuous flow of water. As time went on they used buoyancy with upside down buckets.
                        Mike
                        • #14
                          Hi Stealth,
                          May I ask what the exact title and / or the author or publisher or ISBN number of that free energy book you have? Perhaps it is still available in a remote library...
                          Perhaps you could write some patent numbers mentioned in it too.
                          Thanks, Gyula
                          • #15
                            Buoyancy Testing
                            Hi Stealth and ALL
                            I hope I didn't sound to cynical about people not seeming to be able to build a working pump.
                            Check these guys out. Look at all of the power in water and how little the input is on this video. They use air and water.
                            https://www.youtube.com/watch?v=fpfjOs0IZfk
                            I know that other means exist to supply the air and whoever comes up with a way to introduce air in between sections of water in a column gets the gold.
                            With all of that force coming from the water column there must be a way to create enough air from it to make enough air to provide a never ending run cycle.
                            The people have not stopped trying to do this. In fact even a solar air pump with a ting battery could invoke enough buoyancy to lift many 100's of pounds of water, if not 100,000's.
                            https://www.youtube.com/watch?v=riiaaWnfzSg
                            Mike
