Chet, I thought about using the double radiator with low and high both it in. I thought against it because you don't want to add any heat to the refrigerant after the engine due to the compression requirements to liquefy it. looking forward to seeing how it turns out.
Chris Hunter "Alaska Star" releases an O U PDF
Dear Chet,Originally posted by RAMSET View PostAll
after speaking with Rob Mason I will share this here.
One very big moment working with this PDF happened under the
guidance of Rob Mason [ member Evolvingape]
He Observed that The exhaust from an ICE or better yet a diesel ICE
would be a marvelous source of Heat to increase the Delta T in this system...
to put it in his words[if I remember correctly]
The total input to the prime mover will be the fuel to the ICE , from that point on all energy produced in the system , {"system" Here being a combination of the "TWO" techs, the ICE and Refrigeration engine into one symbiotic mechanical engine]
will be put to work first in the ICE stage and next as a heat source [exhaust and water jacket] for the Refrigeration part of the engine , making _THIS_ ICE drastically more efficient than anything the world has seen.[of course the fridge part of the motor will also be harvesting some energy from the local environment in a well engineered system]
so you can forget your Static "Solar" or your "Water" heat sink models [lakes and such]
we can take those static models and make them Mobile with the normally wasted heat from an ICE engine...
Brilliant to say the least
Thank you Rob Mason....
and of course Chris Hunter for the original PDF
Chet
This next below is what we did do some 13-15 years ago, before our Rotary.
heat2power introduction
Manufacturers in US or Europe no interest, and all GreenPeace's are sleeping massive!?
Regards, Johan
Hello my Friend
Johan
Few People Have tried harder Than yourself To change the world
"from the inside" of the Box...
now we work on the outside ,for us there is no money or fame that could ever tempt...for those are but a few of the traps that keep you in the box..
Johan you should write a book , in your link you show "YOUR" technology that would drastically cut fuel consumption and emmisions ,it is easy to do and very dependable technology ..
and yet they "box it" and have no use for it,... while those who hug the trees instead of their children don't consider the part they play in all of this..
To much TV [entertainment] and not enough education....
Write a book Johan your life is full of examples like this one....
Thx
Chet
PS
And thanks for all your help on the other ongoing open source projects, here and elsewhere.Last edited by RAMSET; 06-29-2014, 03:03 PM.If you want to Change the world
BE that change !!
Found a link to some research that MIT did on waste heat in cars. Looks like it may be an interesting read.
DSpace@MIT: Waste heat recovery in automobile engines : potential solutions and benefits
Hi Chet,Originally posted by RAMSET View PostJohan
Thx
Chet
PS
There are books enough, the reading and building, tuning and related time is the biggest problem, to driven for fast, fast results!
Reading tip: Vedi, New Vedic Order
Succes!!
Regards, Johan
Evolution
Johan
your idea of using a single piston centered in the middle of a common Chamber, sharing the same drive shaft or a
" linear" setup is manifesting {sort of]
here by Tommey Reed using A Hydraulic cylinder and his ratchet design.
From here also
The Propane Air Engine Project
Tom has intuitively Known this was a good path since the beginning
Ammonia is being Looked at too
Thank you again
ChetLast edited by RAMSET; 07-06-2014, 12:35 PM.If you want to Change the world
BE that change !!
The Project continues
Tommey Reed Gets it chugging
Thx
ChetIf you want to Change the world
BE that change !!
