Understanding John Searl's SEG
  • #46
    Thank you for replying. A slow step by step explanation works.
    The ring
Name:	ring magnet.JPG
    I am still not clear about torus ?
    Possibly an eddy field ?
    including a standard eddy current drawing. (using menu item paperclip icon)
    • #47
      There are 2 poles to a standard magnet. Each pole has it's own torus. (donut)
      • #48
        A roller magnetically couples (as a gear) orbiting outside circumference of the plate.
        The stack makes up the roller contributing more flux by having multiple tracks.
        Possibly 12 times per rotation of the large circumference or every 30 degrees.
        The roller maintains a dynamic symmetry.
        The gap set by ?
        The relationship to the interior ?
        The E-field interior from center perpendicular would make sense.
        Bravo !
        • #49
          The gap set by ?
          The gap is set-up by the equilibrium between the repulsive eddy currents and magnetic attraction. The forces find a mid-point where the magnet says, "come close", but the copper says, "but not too close".
          John Searl says:
          If the mass of the SEG stator were equal to the Earth... and if the mass of the roller were equal to the moon... the distance between stator and roller would be 238,000 miles.
          The same as the actual distance between Earth and Moon.
          What about the relationship of the interior?
          The relationship between the rollers and inside of stator?
          • #50
            John G. Trump discovered back in the 50's that the force between 2 capacitor plates changes exponentially with the voltage difference between them. I believe this is also what Eric Dollard talks about with his "energy synthesis" & that Chris Carson built a sort of motorized variable capacitor that generated energy by varying the distance between the plates.
            I was thinking about the SEG & it occurred to me that it might use a similar principle. The different layers of rings/rollers act as concentric capacitor plates. The alignment & misalignment of the magnetic fields may change the capacitance of the space between the rollers & rings without need for any physical change in distance. The extra energy further accelerate the rollers & add to the effect.
            • #51
              John Searl says:
              The gap between the Moon and the earth, Ohhh beautiful, I love it.
              Quite an accomplishment.
              The next question is about the relationship between the roller
              and the inside of the stator. The sequence and the description
              of the electrical nature.
              • #52
                The inside of the stator is the positive terminal.
                The outer periphery of the unit would be negative relative to that.
                Absorption at the poles at the core.
                And emission from the equator at the rim.
                GIF:
                Explanation of GIF:
                Negative is attracted to Positive.
                As a load is drawn, an electric current moves through the concentric layers.
                The valence "electrons" are pulled from the atoms making up the Neodymium core.
                But at the same time, that positively charges the neodymium... which then attracts negatively charged "electrons" right back to it.
                The air is the medium by which the current flows and loops back.
                Constant flow. Similar to the analogy of the cycle of water in and out of a hydroelectric dam.
                The sequence is Neodymium, Teflon, Magnet, Copper.
                The magnets are initially pushed to make them move. Which generates electron emissions.
                As emissions are generated, it makes radial electric currents flow through the layers. (outward from the equator like Saturn's rings)
                As currents flow, the rollers must move. Just like how a motor must spin if a current is put through it.
                What is a “Mockup”? And what does the SEG Mockup demonstrate? SEG stands for Searl Effect Generator. But in this… by verbz
                It's like a snowball effect. Cascading and building up of energy from an initial push. Like how a small spark can ignite a whole forest fire. Chain-reactions until an idle charge and speed is reached. The energy increases with more load to compensate.
                • #53
                  Jason,
                  Updating the latest video on imprinting magnetic rings.
                  Saying hello, Happy to see John Searl's program is hanging in there.
                  12,471 views on 5/5/18
                  • #54
                    Jason,
                    That video was taken a year ago or so, but we've made leaps since then as well. Definitely still here. In it for the long haul.
                    • #55
                      Jason, Thanks for the quick reply. You are a gentleman and scholar.
                      Line up shows excitement is possibly symbiotic to Searl technology.
                      Conferencing and presentations are exciting events.
                      2018 Energy Science & Technology Conference ? Exclusive conference with the Pioneers of the modern day Tesla & free energy movement!
