LaserSaber is going loopy
  • LaserSaber is going loopy
    being discussed here also
    Lasesaber strikes again. A joule thief king ?
    here is an ongoing replication /investigation from member Slyder
    thx for looking
    Chet
    BE that change !!
    A "long Runner" from Igor
    enjoy
    Chet
    BE that change !!
      exploration of odd behavior
      for those who are interested a thread has been set up to explore
      this in more depth
      Experiments and Anomalies
      thx
      Chet
      BE that change !!
        several updates
        lasersaber
        Slider
        SJR Looper/Akula based coil - 19 minutes ! - YouTube
        several more very skilled builders are getting into the mix this work is
        evolving from "akula"[Russian scientist] contributions as well as the
        skills and intuition of these replicators.
        of course we have these ongoing discussion's here
        and here
        thx
        Chet
        BE that change !!
          Hi
          I hope Lasersaber pop by and can answer some Question.
          I would like to know if he wound all Coils into the same direction and what sizes he used for his second build.
            update
            enjoy
            Chet
            PS
            Joit I believe all the minutia of this build has been shared on the links
            in the first post [read thru for clarity]
            BE that change !!
              Hi ramset,
              i checked all the videos and links but nothing really mentioned there, only the usual crap at ou.com
              He said something that he plays around with #18 and #24 but written down it would be more nice.
                HI Bromikey
                What ringers are that, the one they are shown with this transistors?
                And what you mean with charging up, they run only from a Cap?
                I now did ofc build one, actuallly 2nd layout. I got 3 coils on them.
                But i replaced the copper foil with another winding, so i got 5 coils right now.
                Empty coil #14. replacement for first layer copper.
                Coil 1, #16, 4 Layers.
                Coil 2, #24, filled up the spool close to the end.
                Empty coil, #14. replacement as copper again.
                Coil 3, #14, 1 Layer.
                It rings for about 15 sec with 7V, Led is half or 1/4 bright.
                Strange thing still is, when i connect one from the empty coils with one wire
                to one of the power coils, it either goes off or stay on.
                So, it seems has an effect, when you have something like copper around it.
                I assume it gets a charge and builds a potential like an antenna.
                But there is a lot what i could play with, either change the size from the caps, that it rings on different frequencys, try to connect caps in parallel with the coils, trying pots at certain places aso.
                I saw too that it seems he has wound all coils into one direction, i am curious if that can make a different too, or if its better to stay like that in a way.
                Reminds anyhow at a standing waveform after that build.
                And well, my fight is almost over, to try to tell ppls what funny things you can build there.
                For me they are a bunch of retarded idiots, and can wait until they can buy her crap at walmart.
                I only need to look at one from this links from ouresearch. the last 2 pages are only that 2 guys what bloat herself out about what led driver they did build. Who f** cares about that crap dim blinky led before 20 years.
                The rest from the comments what you see at videos are the same retarded and only repeat the same bull****, where it is not worth to read further.
                  Ringer 2.0 Joule Thief Mod
                  Originally posted by Joit View Post
                  HI Bromikey
                  Sounds like you are very close. Did you ever do a joule thief?
                  Yup Yup and Yup. Alot of people who are just tying on a buzz, not serious. But there are also a few guys who are genius. Like you.
                  Winding the transformer
                  How to build the Joule Ringer transformer. - YouTube
                  And here is the diagram I used but I will add a few more down at the bottom.
                  These are Lasersaber drawings
                  Maybe you have one wrong wire or not enough resistance in the base to form an oscillation?
                  Put a cap across the base resistor. Try swapping the ends of the coils around.
                  You are building a forced oscillator. Once you build a tiny joule thief powering 1 L.E.D. you will be able to make the bigger ones.
                  I don't call it free energy anymore, I call it EXTRA energy and that is good enough for me.
                  Making the Super Joule Ringer 2 - YouTube
                  Mike
                    Ringer Mods
                    Here is the good stuff
                    Xee2 Joulethief inverter with relay coil - YouTube
                    Xee2 transformer joulethief with diode/cap-xenon bulb test - YouTube
                    Mike
